Posts posted by mtaylor
I hope youi've had your shoulder looked by some medical types. Take your time and let it heal.
Hellmut,
I hope the hospital time helped your health.
Good luck with the project. AI is still pretty new and experimental. If you can get the memory and processing down to small enough physical size, you might be onto something.
It's been awhile since I've Adam post. I hope he's okay and just busy.
Or, you can do it the hard way, manually (on the computer). Scan the image, open in appropriate program (I use CorelDraw) and manually trace what I want. Takes time but no artifacts, no clean up. And a sense of satisfaction when I pop on the laser and cut.
I'm just cheap so my method is good for everyone.
- rshousha, jud and thibaultron
3
It's possible that this is BHR. As I understand it, ships to the northeast of Britain and even in east part of the channel were considered safe from the worm due the temperature of the water. How true this is, I have no idea. I hope additional research is forthcoming with some solid info instead of what these articles give us which is eyewash for the most part. For now, I'll keep an open mind and some fingers crossed.
- davyboy, uss frolick, Canute and 2 others
5
If I hadn't seen the build log, I wouldn't have believed it was wood. Just impeccable.
- Canute, John Allen and SawdustDave
3
I looked in here and no Sprays are listed. Maybe someone has built one but didn't do a log:
- thibaultron and lmagna
2
Do have a look at the manufacturers as AL and Occre are very similar. Occre was started by former designers of AL when the owner moved the company to Vietnam. So there will be differences.
What Spyglass said. However, captains were free to change the rig such as belaying points, angles of the masts, etc. to maximize performance.
- Kevin, Canute and pontiachedmark
3
I make by zero clearance inserts out of plywood of the correct thickness. I guess i"m just cheap. I also drill holes in the inserts so the shop vac will pull in as much of the sawdust as possible. The picture shows one that hasn't had the holes drilled yet. I find the holes and possibly some bracing under need the unit is need as the suction from shop vac will deform the plats downwards.
I think that many of us have no suitable place to actually put a model into the water. The other thing is type of ships many of build. Put 5 years into building something, you don't want to see it sink. Or at least I don't.
I seriously had to look twice at your ship in the water. I thought I seeing a full sized ship until I read your post. Wow!!!!
- RVB, Mirabell61, pontiachedmark and 3 others
6
Nice work, Bedford. I doubt that perfectly round masting and yards are in the majority, unless they're steel, aluminum or fiberglass.
Have an LOL for your LOL.
I'm just lazy sometimes.
Alan,
If you turn the cannon (or buy them), Chuck has the monograms.... https://www.syrenshipmodelcompany.com/turned-brass-cannon.php At the bottom of the page.
The MM lathe isn't bad for the price. Do clean up the chuck jaws to ensure that everything is round, proper, and centered.
As for a mill, I've the MM "mini" but it wasn't all that great. Odd sized parts, no accessories to speak up. The current one is apparently not bad either but the chucks (unless you're using collet set will need truing up also. Again, not a bad unit for the price and the reviews seem to be good. I did decide to go the LMS mill as a replacement (retirement gift to myself) so I could use some standard tooling... Wow... what a difference. By comparison it's quieter and more precise.
Arabia 1856 by Cathead - FINISHED - Scale 1:64 - sidewheel riverboat from the Missouri River, USA
Valid point. Plus you'll have two deductibles to meed.. this year and next year. The sad part is, it's probably going to get worse than better.
