Evening all, more progress still on the top plate - firstly I had what seemed like Ten Million engine hatch hinges, then there was a few handles that were about 0000000.1mm wide (well not quite) but still minute, the savior was some larger fittings like fuel filler caps and engine exhausts, also a couple of side handles (not as small as the other tiny things). Next was some engine cover Bling that was a pleasure to fix down. I have taken a few pics ot show the massive size of the M1 kit (that I will be pinching the interior from) and also some super detail sets I boright to bring the M1 upto its most modern look, and the Chally tankers I will buid and paint. OC.
Here's the plan over the next day or so - I will attach a few more of the fittings and PE on the top of the hull, then the exciting bit - I have had my other kit arrive including a few bits - modern British tank crew, the plan is I will pinch the internal bits for the turret and drivers cab, and start the process of trying to make them convert from a M1A2 into a Chally 2 interior. Here is the kit -
Evening all, more progress on the frontal armour - I added the two drive lights (fiddly little things) one of them forsted over from getting a bit of glue on it, I removed the glue after it had set with a sharp blade, it doesn't matter too much as I will paint them alum and when I add some dust dry brushing after painting - they will blend in and wont be seen that well. The bottom section of armour was cut off next I decided to glue the Two togther as they lign up better that way, then a tiny bit more bling was added, then it was on with the top section - this has a few fittings including Two PE pieces that needed bending Three times then a couple of lights where fixed in place with a small amount of CA. I then dry fitted the Two togther - a great fit of parts is shown straight out the box. OC.
- 436 replies
- vanguard models
- alert
Any way keeping my mind occupied........the figure I won the seller his going to take it off the base as it will make it easier for me when I come to fix it down onto my dio, I will be doing quite a lot of re painting and face work, to get it the way I want it. The history behind Marshal Ney at Waterloo - he was about Third in command and commanded the Left hand colums, they were responsible not only for attacking Wellingtons center but also Hougoumont Chateau and La Heye Sainte, he gave orders first for an advanced party to attack and take L.H.S but they were driven back, after he was responsible for a couple of attacks on the British/German flanks, also he led the charge with the French cavelry units against the combined British quares, then he was given orders direct off "Boney" to lead an attack on L.H.S and only then did he drive the KGL out due to them running out of ammo. I intend to place Ney close to the Farm along with the attacking French units. OC.
