Old Collingwood
  1. Evening all, I managed to get the bottom of the wokka finished today - this consisted of plenty of blade aerials and the Three cargo hooks, the center one that can carry the most weight is folded up when on the ground (on mine) need to be careful not to knock any of these off while handling her. OC.
  2. Excellent I used to see a few of these (her sister ships) quite often infact they bacame quite a regular sighting - Here is a close up showing procedure Alpha. Top one HMS Monmouth, Bottom HMS Argyl. OC.
  3. Between you and Lou - "Blimy" can imagine a Full on play mayhem Nerfs and potato/tennis balls going everywere.😁 OC.
  4. Blimy Lou - can imagine you lot playing - play battle in your house with Nerf guns and mortars - bet your admiral would be pleased walking into the house - Full on battle of Lou's Land.😊 OC.
  5. All of us? wonder who the cheeky one is?😃☺️ OC.
  6. Certainly is Tom, I would imagine quite effective aswel - sat n the hover with fire in Three consecutive directions. OC.
  7. Was the same for me as a Ten year old with Scalextric slot cars on those tracks with the 12Volt connections from a transformer running through those male/female conectors that were a pain to keep in good order. OC.
  8. Thank you Mark,, I was reading a small article the other day about ACH47s Wow they looked the business almost like AC130 Spooky's in heli form. Yep our little princess is doing better - still on the couch "Feed me dady - I'm too poorly to move" think she is milking it a bit now though. OC.
  9. How you gonna moderate from all the way up there - hope you have one of those long pointing sticks. OC.
  10. I should have worded that better - I meant the 70s style boots with big heals - good for extra hight. OC.
  11. Evening all, a bit more progress this evening - I have made and fitted the Two Flare defence systems and the other Two outer devices, a few more bits and bobs to fit before it can be primed. OC.
  12. Very nice work mate - with the shrouds I made mine the same colour for all, and with the spacing of the deadeyes I used some thick wire with a 90deg bend at each end - I used this to attach at both ends to try to get an even gap between the "Eyes" OC.
  13. And building paper mache tunnels hills etc - tried it as a kid (not very good though) OC.
  14. Fabulous work mate - looks so real. OC.
  15. That's gonna be some kit when she is finished - some size aswel. OC.
  16. Hi, I planked over the plastic decks in my Black Pearl kit - firstly I sanded the details of the plastic deck to get a smooth surface, then I just used wood planks (you would be best converting the scale of the model to get an idea of how (scale wide) the planks would need to be). After the deck/s have been planked (again using wood) you could make up some gratings frames and either buy some gratings kits or somehow mix the plastic ones in with wood frames. It will enhace the decks considerably. OC.
  17. Can I also add another tool that members can use if the normal drag and drop from thier hard drive is giving problems - https://postimages.org/ OC.
  18. Hiya mate, dont know what happened - I must have kept missing your updates on this, thats an exellent bit of work on your false deck, and not an easy route in there - fine job indeed. OC.
  19. I managed to get a tiny bit done today in between hand feeding out little pooch and getting her to drink drops of water of my finger - anyway I fitted a few fittings and bits and bobs. OC.
