Posts posted by Old Collingwood
Or........perhaps I could ease out the set gel water, and re do it but using coloured water gel - with me adding a few drops of wash to the mix before brushing it back in.
I could still do the dry brushing using the dust - sand in areas I can reach.
OC.
- robert952, Jack12477, FriedClams and 4 others
7
Morning all, more pondering s - I decided to play around with my water gel product that I made my pond with, the idea was that the wheel ruts in the road way would probably still had small pools of water sitting in them, - so (not thinking about colour) I brushed in a bit into a few of the wheel ruts, its thick and White at first but after about Ten hours it hardens clear. The problem is it just looks like a clear line not a slightly coloured water like it should have been.
Its got me thinking if I could do a very thinned dark wash all over the base - roadway etc (Yep includes trying to get in with a brush around all the figures) - then if I could go over the top later when the wash has dried thoroughly with my dry brushed sand dust colour as a high light.
Yep would certainly be a job and a half - but it might work to blend it all in together.
What do you think?
OC.
- FriedClams, Canute, Haliburton and 3 others
6
Hi there all, a bit more progress, I have re done the wall extension (well turned it over and added a small piece at the bottom) its been painted White and waiting to dry.
I also added some of my resin water in puddles in the ruts on the road way and against the wall (waiting for these to harden and go transparent)
I have also placed a few more figures in the shape of Four 2nd KGL casualties in the orchard.
OC.
Excellent work Ron.
OC.
- king derelict, Egilman, thibaultron and 1 other
3
1
57 minutes ago, king derelict said:
The photos really capture the feeling of the moment
alan
Thank you Alan, I had Two options due to the depth of field - focus on the 95th rifles or the French 3 feet away, and the house window view that was just a bit different.
OC.
- robert952, Canute, FriedClams and 4 others
7
- Jack12477, chadwijm6, FriedClams and 7 others
10
Right then - I am not too happy with the size of the bricks or the height of the wall - so I may change things - watch this space....
OC.
- Egilman, king derelict, FriedClams and 5 others
8
2 hours ago, Darius359au said:
OC have you see "Napoleon's army 1807 - 1814 as depicted in the prints of Aaron Martinet" by Guy C. Dempsey jr? ,(the titles a mouthful😄)
It's the prints done by Aaron Martinet ,the prints were hand painted and show's pretty much every unit in the French army from Napoleon down through the Marshall's ,the guards ,line units, Cavalry etc, up to Waterloo!
Probably too late to help now😎😄 ,but depending how deep down the Napoleonic rabbit hole you are it's a great reference And it's pretty cool just to browse through it!
Richard
Hi Richard many thanks for the link, I have been using this aswel as Google search and other Napoleonic figure builders for research - http://centjours.mont-saint-jean.com/detail_uniformes_uniteBR.php?rubrique=U&uniformes=112&drapeau=
OC.
- king derelict, FriedClams, mtaylor and 5 others
8
Incidently that section of wall is using larger size bricks, well that's my excuse and im sticking to it.
OC.
- king derelict, robert952, mtaylor and 4 others
7
Evening all, so work has started on my little section of wall - I cleaned the edges then scraped and cut out an area of exposed bricks, and profiled a section of bricks that where just painted over at the bottom, then I painted in the mortar and then the bricks then the first coat of white to replicate the thick white paint.
OC.
- Canute, Jack12477, king derelict and 7 others
10
Evening all I have started work on the wall extension - first I measured the gap and transferred this onto the MDF sheet I have, I then cut it into Two equal pieces and glued them together, they have been put aside to bond, when set I will smooth the edges then start to create some brick profiles exposed under some rendering.
OC.
- mtaylor, FriedClams, Canute and 2 others
5
My next job will be to work on my extension of my wall, I have found some MDF off cuts that will be large enough for me to be able to double up to get the thickness I need.
OC.
- mtaylor, king derelict, Jack12477 and 4 others
7
I will then work on my other British Cavalry figure after placing my Two on the roadway.
OC.
- mtaylor, Haliburton, robert952 and 5 others
8
Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
in Non-ship/categorised builds
Evening all, so here is my water wheel ruts and wall extension.
OC.
