Posts posted by Old Collingwood
3 hours ago, gsdpic said:
Thanks for the comment CDW and thanks to all the others for the likes and the wows. Not sure my work lives up to a "wow" but I'll take it.
So I said the exhaust was next but I skipped ahead a little bit and worked on painting the wheels. The wheels presented a couple of conundrums.
But first, back when I built the Ferrari shown above, I wondered about the goldish tone of wheels on race cars from around 1970 and google told me all about "DOW 7". For those unfamiliar, the wheels were made of magnesium to reduce weight, but it is fairly reactive to the environment, so the magnesium was coated with some chemical mix to prevent corrosion. "DOW 7" is the current name for one such mix; not sure if that is what it was called back in 1970. It is a sort of non-metallic goldish tan color, sometimes with a little tinge of green, though looking at net pictures of magnesium wheels shows a wide variety of color.
As for the conundrums (conundra?), the various pictures and youtube videos of this car (not to mention models of this car) show a variety of wheels and a variety of schemes for coloration of the wheels, usually with a silver rim along with some parts in a goldish color, and some times black as well. So the first issue was just how to paint the wheels. For the front, as shown, I've gone with a black inner section, gold wheel, with some silver trim around the edge. The rears are a different style and very deep so I did not do the black inner section on them.
The second conundrum is regarding the gold color. Was the gold wheel on the 72D a magnesium wheel coated with DOW 7? Or was the wheel painted gold to match the livery of the car, with the gold stripes? As much as I might have wanted the latter, I assumed the former.
So I started out painting the wheels with the dreaded alclad gloss black, thinking I might be painting some polished aluminum over it, though that did not occur. I then did a light mist coat of flat "German Grey" Tamiya paint just to knock down the gloss and blackness of the inner part a bit. Then I masked the inner wheel section and painted the wheel with Alclad's "pale gold". That was the first time I used it, and I have to say it went on beautifully. At that point I was tempted to pretend the wheels were painted gold to match the livery and let it go. But no, I continued with my original plan to attempt to make the wheels more "DOW 7"ish, and put on a mist coat of Tamiya Flat Earth with a couple of drops of green in it. Finally, I went around the rim of the wheel using the molotow chrome paint marker. Below is what it looks like now. I'll likely go over the rim with another pass or two of the molotow paint marker and then maybe shoot the whole thing with a semi-gloss clear coat. But, even as is, I am quite pleased with how this came out.
If you made it this far, thanks for reading this overly long explanation for painting a wheel
Typical Lotus wheel colours.
OC.
Excellent work Kevin - really nice and tidy.
OC.
- mtaylor and Knocklouder
- 2
Absolutely Gorgeous, spot on work.
OC.
- mtaylor, Canute, king derelict and 2 others
- 5
30 minutes ago, king derelict said:
Most of the floors or courtyards seem to be a gravel surface and Aedes Ars gives you a tiny bag of white ground material which is nowhere near enough to do anything useful with. I could mix it with some ground block material but it would have to be mostly block dust to cover the ground so I think its off to see what Woodland Scenic and others have to offer. Thanks for the help
Alan
Good to know and glad to be of help mate.
OC.
9 hours ago, Kevin said:
lovely to see an update
They are just some re edited old pics Kevin, she no longer lives I past it on some years ago sadly.
OC.
38 minutes ago, GrandpaPhil said:
Nicely done, OC!
Thank you kindly Phil.
OC.
- GrandpaPhil, Canute, mtaylor and 1 other
- 4
Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
in Non-ship/categorised builds
Just adding a few more photo edits including Marshal Ney who will not be displayed as he was further up the field of action untill he rode with the massed cavalry attack on the squares.
OC.
