Evening all. or shall I say morning / afternoon to my friends, so after spending an afternoon in the back yard, I decided to work on the bomb bay parts still needed, I started by spraying the bomb bay doors - then put them away in the box to dry, next I put the Four 500Lb HP bombs together inlcuding slimming down the rear fin area, they still need spraying Green and having the Red and white rings painted on. OC.
Military Wrecker - Revell - 1:32 Scale - PLASTIC
Old Collingwood replied to CDW's topic in Non-ship/categorised builds
Thats our family on here for you - looking out for each other. OC. -
Hawker Typhoon by Asat - Airfix- 1/24
Old Collingwood replied to ASAT's topic in Non-ship/categorised builds
That looks like a perfect space. OC. -
Do you know Phil, some people build a kit using normal routines and straight forward precedures, then someone like yourself says "heck that - that aint enough - I want to put my own stamp on it" that is what you are doing - its not just boat building or even scratch building, its Artistry my friend. Keep going this is a Special build. OC.
Hello again, A bit more progress on this - this evening I dry fitted the wings to fuselag, and after doing a bit of filing/sanding - I glued them into place, not quite as good a fit as the Eduard kit - so it will need a bit of filling with putty here and there. No pics as the phone was charging. OC.
Really really nice work Kevin - sure is standing out with all that detail, well worth all the hard work and time you have put into her. OC.
- 337 replies
- finished
- mountfleet models
Evening All, in between working on the Seafire I found the time to check over mossie to see how the flat coats had gone especially over that troubled area we all know well, then answer is Fine, no issues atb all the top spray put on in a couple of fine sprays did the job. Here are two pics just showing "that troubled area" as it is now. OC.
