B-25 Mitchell "Meet Miss Runyon" by Javlin-HK-1/32
Old Collingwood replied to Javlin's topic in Non-ship/categorised builds
Ken will like that top pic bottom left😉 OC. -
Think how much popcorn that will be for Mark to bring............😜 OC. -
I am biased (just a little bit ) but will follow what ever you build with kean interest. OC. -
"Please get the Mossie" heard there are some rather nice kits at that scale.......please please. OC. -
Thank you kindly Mike, I am fully relating to that, I think that is what happened a combination of what EG said and yourself - the laquar layer reacted (made worst by heat) with the Acrylic Tamiya top coat semi gloss. What I will do in future - Not mix laquar with Acrylic, and to finish my mossie off - use the two colour laquar tamiya rattle sprays, sort out some decs - put them down again using my micro set and sol, then after about a week or so use the tamiya laquar flat coat but somehow try not to spray it to thick (not that easy with rattle cans). OC.
Curtiss P-40B Warhawk by Asat- Airfix- 1/48
Old Collingwood replied to ASAT's topic in Non-ship/categorised builds
I know in the European theater the Spit IX was introduced with the more poweful engine, this made it a match for the rather excellent FW190 of the Germans, I assume more poweful spits were shiped out over seas but not sure. OC. -
That is looking very nice my friend - very tidy work. OC.
- 436 replies
- vanguard models
- alert
I put the fuselage aside and tuned my attention to the Black paint underneath both stabs and main wing, this was straight forward as they had already been primed, I decided to hand paint these same as I hand painted the other wing, I masked up a few areas on the wing near the flaps - then painted away. I have the stabs done and part of the main wing - I will finish the rest when the paint is dry and hardened. OC.
So after the disaster, the process to try to turn it around started last night by me trying the old trick of using masking tape to pull the damaged decals off, several tries and to my amazement the worst culprits came away without damaging the paint work underneath. So today after a good sleep, I got some fine wet and dry and soapy warm water, and proceded to work on the areas affected, this worked out quite well as the tamiya laquar layers that had been sprayed on with the rattle cans, had actually formed quite a hard layer - so I carried on. When I was happy with the finish the next stage was to mask off and isolate (thas a good word these days) the front section as that was not affected, so with the aid of a plastic bag and tape - it did the job. So this is the fuslage ready to be masked up for the camo colours. OC.
I have just this minute had a got on the tail, I re - applied the X35 by wide brush I worked it in well but smoothly and started to see the cloudyness smoothout and show the dark Black underneath and same in the decal (that is damaged from rubbing) But, after a few minutes letting it dry on its own the cloudyness is coming back only difference is its a gloss cloudyness not flat. OC.
