Old Collingwood
  1. Can you lightly sand the blue a bit to smooth out the dried on glue, then re paint it? OC.
  2. "What - made" that was bad your workmanship deserves far more than that. OC.
  3. I have some fine fuse wire 3amp I think might try that, it attaches to the leading edge of the tail, what I might do is to drill a pilot hole in the edge of the tail then push the wire into it with a dab of ca, then attache the other end to the pe wireless pole on the fuselage. OC.
  4. Quite an artform for lacing and tuning a wheel using a rig with center blocks you position each side with the wheel center centtered, then you turn the nipple on each spoke increasing or decreasing the tention pulling/releasing the rim till it dead center between the block, you do this all around the rim till its true. (I used to build repair bicyles for a living years ago) OC.
  5. Thank you edward, some way to go yet, but atleast it shows the general finish, she still has to be re - decaled and to have her flat coat over her, then a few small bits and pieces like the bomb bay doors - 500lb bombs, entrance hatch door and ladder, and a radio wire. OC.
  6. Thanks mate, took a bit of fiddling and masking and masking oh and masking, but I'm quite pleased with the finish. OC.
  7. I've laced and tuned cycle wheels but never a motorcycle. OC.
  8. Excellent work, is that a Gpz in the back of that other pic. OC.
  9. Welcome to the club, thats a great kit to kick off with - lots of interesting style and big enough to show its self off, that is superb work with the pe mast (fiddly little fellas - aint they". OC,
  10. Thank You for taking an interest, it so builds one's confidence you know. OC.
  11. Thank you kindly, yep I have been able to rescue that decal situation🙂 OC.
  12. Always a course of forward and backs with out model making, she is coming on lovely despite your little hick up. OC.
  13. Good day all, so - paintwork done on the props and spinners then they were put togther, then "The Big Reveal" the fuslelage camo/Black paintwork came out ok I think. So I dry fitted them all together - here are a few dry fit possing pics. OC.
  14. Time to build some display cabinets Carl. OC.
