After a day in the yard charging me Vit D cells I then de masked the fuselage - not too bad, demarcation line had a bit of a ridge so I attacked it with smooth wet and dry soon sorted, then I noticed a bit of camo that needed correcting - so back on went the masking using tape a bag and blu tac and a quick re spray over a tiny area, I then put it away to dry. I then turned my attention to the props and spinners - the spinners was a bit awkward getting a smooth sprayed finish as I kept getting some over spray, so plan number Two hand paint with Nato Black - so this was done, I put them aside and tipped the props yellow after masking. OC.
Just as Edward said your gun ports came out spot on, also I love the shaping of the hull and the smooth work on her, nothing wrong with that in any shape or form, really coming on my friend. OC.
- 436 replies
- vanguard models
- alert
So, more work on her this eve, I put a few coats on the props - I decided to use Flat Nato Black as its actually like a dark flat Grey, I put a few coats on followed by a few watery coats to smooth out the finish, this was put aside then I put some blu tac inside the spinners attached a stick and went outside and sprayed then the same Black as the fuselage. They were then put inside the goody goody box to dry. OC.
Another kit I have my eyes on doing when funds allow and after I have sorted out a few important financial things that are waying heavy on my mind, is to do another kit that falls quite close to this one as they were both FAA service and both based at the same Naval base were my late father worked - the unique one of a kind F4U-1A/-D Corsair, My farther used to chat to me about "the bent wing bird" and how they were like nothing else he had worked on, and how they had initial teething troubles with them that needed quite a bit of sorting out before they could go onto the British carriers. This type - (Off the Net) Will keep you posted. OC.
Evening all, I managed to get more done on the fuselage today - I started by taking off the camo mask and checked the finish, it turned out ok nice and smooth, next stage was to find the front demarcation line for the Black/camo split, I made a mark then ran a mask line towards the tail using Tamiya tape, I did the same both sides then made a curve in front of the tail using blu tack, then I filled in the top camo section with paper and went in the garden and sprayed with my Tamiya rattle can. It was then put inside my box to de gas and harden. OC.
