scrubbyj427
Everything posted by scrubbyj427
  1. I think the head rails are going to be the icing on the cake at this point. Very excited to see this part develop.
  2. Don’t worry Glenn... I’ll still probably be rigging guns by the time you get to this point.😁
  3. Thanks Guys. So far I’m happy with the results. Once you get in a rhythm with them, they aren’t bad. The next time around I need to make 12 carriages and rig them all, so much larger task. I had made these carriages months ago.
  4. And finally 12! Easter brought the gift of time to rig guns! So now I will begin chapter 7 and then continue with the rest of the guns when I finish. Looking forward to getting some beams in place and completing my lantern project. JJ
  5. Looks like you could run both ways with it. But I agree with you, perhaps the modeler didn’t want to cut a nice run of moulding. And since it’s not actually functional I think aesthetics take priority. Also the molding and the steps seem to have similar profiles. I checked my drafts for Portland class and it shows the same thing.
  6. That looks really good, I think the dye is a much better way to go than black paint. I will definitely be using that next time.
  7. Those look really good. Often represented just as a slab of wood just glued on the side. I’m curious to see how the steps unfold.
  8. Your figurehead looks excellent Marsalv! In your cnc did you have to carve one side at a time and flip the figure over each time or did the machine cut at all angles in one pass? JJ
  9. Granado Looks very good Tom, well done on splitting the hull.
  10. And then there was six of them.... 30 something more to go!! as soon as I get six completed on the port side I plan to take a gun break and start my long awaited chapter 7 and also pick up and finish my lighting project, now that I can hang the individual lanterns.
  11. I sympathize Frank... between work and family my Winnie has been reduced to a glacial pace, you will probably catch up with me soon. JJ
  12. Looks really good. You’re plank terminations at the bow and the stern look really good too. I struggled with the ends where they meet the counter, it’s definitely not easy.
  13. @jmlyle CAF is a legit Chinese company and Tom appears to do a great job designing his own models and supporting his kits. The other Chinese kits you are referring to are likely pirated ones and therefore would be a mess. There are several build logs going on right now, you should check them out and decide for yourself. I will take a stab at one in the near future, just not sure which yet. But there are many on MSW that are satisfied with them.
  14. Thank you Don! I definitely studied your guns as an example to follow prior to starting mine.
  15. Your planking looks soo good though! I don’t want to distract you from that! It will come together before you know it. This build is just a series of milestones.
  16. Thanks Guys, I appreciate it. I’m not sure, but were you asking for a tutorial on how I did the guns? Or just stating that I already did it?
  17. 🤦‍♂️Lol I’m trying to trick myself with the numbers! One deck at a time.
  18. Way to take away my steam lol! Well at least I get to skip the two in the back and the two way up front!
