kiwiron
Everything posted by kiwiron
  1. Thanks a lot slog,it's good to know how the experts do it.
  2. Thanks very much Pats,Augie and Frank now I know how to do the next step,great ideas.Frank it'll be done by xmas just don't know which one yet.ron.
  3. Thanks a lot Pats,good idea I remember reading your post about that one.I'll have a go at it over the w/end hopefully.ron
  4. Just thinking about the angle to fit the chain plates,should i wait to put the mast on to see what the angle of the shrouds are?ron.
  5. Thanks Denis,I have'nt done anything to them yet,straight out of the packet at the moment.
  6. Deadeyes etc assembled,I need to open up the channels before fitting.
  7. One year into the build,got a bit further than I thought.Just waiting to get motivated again to assemble the deadeyes,chain plates etc.
  8. Dave,you've got a great hull shape there,probably the most important part of the build.
  9. Augie,hope you had a good break,can you put the trout down and put some more photo's up.thanks,ron
  10. Thanks a lot for all your great comments chaps.Denis i'm a complete amateur compared to a lot of other Endeavour builds.Pat looking at Gregs rigging not sure if i want to get to it to quick.Greg i fitted the kit supplied belaying pins but can get some more as i need them.Popeye the tiller rigging is from Cpt Slog and Shipaholic nearly at the end of the deck work.I seem to spent a lot of time re-glueing parts back on.Thanks Augie i'll leave off the anchors,small cannons,flagstaff i can see those being glued back on again and again.Just painting the deadeyes today.
  11. Tiller rigging done the same way as Cpt Slog,kept breaking blocks trying to put wire all the way around.Other odd bits done on the deck cleats,hatch cover,steps,boats lashing rings,anchor pulleys.Chain plates next,I got some Amati ones so time to check out everyone else's builds to see how it's done.
  12. Nice job Dave,she will come out nice with a fine sand remember the second planks are very thin so don't get to carried away with the sanding.Easy repair if you do though.
  13. Hi Shaun,You'll enjoy it maybe not all the time until you see your progress.there are AL Endeavour build logs here,every kit is differant also the replica is differant to the aots etc books so it's a guess really to see how the original was.At least the name is the same.Maybe we should have been born 200 years ago to know for sure.Take your time if not sure ask there are very helpfull people here.
  14. Thanks for your comments chaps,Added the breech ropes already just hard to see until you open the photo to full size.Cleats after some pancakes.
  15. Cabin chimney added also wedges to cannons and barrel steps with card.Cannon carriers not accurate for Endeavour so it matches the rest of the kit,at least the name is the same.To much for my skill level to add extra block tackle to the cannons only 10mm of room for 2 blocks hooks rope etc.Add some cleats now, off to work while they dry.
  16. Thanks Popeye,boat supports done.Pumps took a couple of goes to get right.
  17. Looking good Popeye don't forget your beauty sleep,to late for me to worry about.
  18. Thanks Frank and Alistair,i know what you mean now,i'll just put a photo on.Rope on the tiller step re-done.Channel caps to go on later.
  19. Thanks a lot for your comments men,very much appreciated.Alistair do you mean where the small hand cannons are mounted?
  20. Binnacle,chimney,steering wheel,rudder step done,pumps next.Probably re-do the rudder step rope again with beeswax it's a bit fuzzy.
  21. I have'nt had hawse holes line up on any kit i've done so far.Nice hull shape and wale line,much easier to add wales now i think.
  22. No pressure,it's nice to just figure out your parts box first and just sit there looking at it.
  23. Good to see a start on the Royal William,she will be a nice ship.Looking forward to it.ron.
  24. Well done Frank you've got a nice hull shape there,she will sand off real good.
  25. Thanks Popeye,some lining deck fittings now.
