kiwiron
Everything posted by kiwiron
  1. Thanks Popeye,Just thinking what to do about bulwark top lining if i use the deck planks i won't have enough for the upper hull.Maybe leaving the lower deck un planked would have been better.I'll scratch around to see whats left from other kits.
  2. Thanks Jeff,the bulwark linings are trimming down easily.
  3. Just trying a simple jig seems to do the job.I'll make a better one later.Bulwarks linings with the odd clamp or two.
  4. Thanks Denis,I like rigging but the boss won't give me time off to have fun so looks like you'll just haveto dream about it again.Can't get rid of this stupid underline either.
  5. Decking done,the fore deck planks are all under full length so no joins there.onto the bulwarks now.Really enjoying it so far.
  6. Brilliant work on the furled sails Denis,i like the vertical thread on the sails.
  7. Very nice Doug,now you can knock the gaff with your arm as well but don't worry it's pretty tough.
  8. Denis, don't cut the wrong thread when trimming your rigging,like a friend of mine did.Thanks Jeff,my first mistake cutting out notches for the bulkheads on my decks,lucky i found it before glueing them on.
  9. Hi Denis,Doing some at work just on my lunch break,cough.This is the easy bit.It will come to a screaming halt when i haveto start fairing the bulkheads,not my favourite job.
  10. Thanks Steve for your advice,i'll try the camber idea.ron.
  11. 4 butt shift, it would be good to line up the treenails with the bulkheads but they are all spaced differantly.
  12. Thanks a lot Steve for the info and photo.How much camber did you put in?
  13. Thanks Alistair,Ken and Slog thats great info thanks a lot.No pressure eh Mark i've got experts here watching so i hope i don't stuff it up to much.
  14. Hi Slog thanks i have already looked at your log a dozen times,very nice job.As for colour i like the blue bit and yellowish wood but probably with a white hull.Ok next bit done. I thought i would use the bottom deck temporarily in place to square up the bulkheads,works well.The first bulkhead sits below the rest so you can fit the bottom deck in there flat at the front as in the photo.Do some deck planks next,nice to do decking again.Probably go for 3 or 4 butt shift any ideas on plank length 65mm as per instructions seems a bit short.thanks men.ron.
  15. Welcome to my build log everyone it will be great to have you along and any advice will be appreciated.I hope James and Mr Banks won't be dissapointed with it.I think i'll just follow the kit except for chainplates sounds like aots,replica in Sydney etc have conflicting ideas.
  16. I have wanted to do this model since seeing the Endeavour models in Gisborne when i was a boy for Cook's 200th anniversary in 1969.They are over a metre long very impressive up on poles.This model will be 815mm long by 300mm wide,should be enjoyable.
  17. Hi whats a decent head magnifier,light and where to buy from.thx ron.
  18. Hi How do you sand your blocks to round them off,one by one or is there a better way,thx ron.
  19. Popeye sorry to hear about you getting stuffed around so much,the ill wind was the landlord opening his stupid mouth again,idiot.Hopefully all is ok now with no damage to your ships,boats.I did notice all the rigging has fallen off your Goth in the move.Chin up the rubbish will pass.
  20. Hi Doug, just getting either rimu or NZ kauri for the base if my work mate comes up with it.Any help just ask sheet 6 made me scratch my head a bit.
  21. Hi Doug,I just used 1mm black from the kit,a bit stupid telling you to use something not supplied.I don't think anyone at Jotika has actually made the Supply from their instructions or supplied parts.Lots of mistakes in it thats why i went to Occre great instructions and all parts supplied.Good luck.ron.
