Tankerman
About Tankerman
  • Gender
  • Location
    South Somerset
  • Interests
    Model ships, static and working radio control.
    Gauge 1 and 0 gauge model railways.
    Model Classic Sports Cars. Classic commercial vehicles.
2,108 profile views
  1. Hello, Tankerman
    I did buy the 4-horse harness kit. Question: was your kit supplied with black rubber gasket material for the traces, straps, etc? The same material was supplied for the stagecoach itself, but I can tell from the written instructions (for the coach) that it was not what was intended by the kit designer. Brutal stuff to work with, and not cut through. Any advice? Instructions speak of cleaning up char from this stuff, are they kidding?
    Thanks very much, Bob
    I'll be updating the log at some point. . .
  2. Photos as requested, as stated above these are untouched within the boxes and are as received from the model store so I'm not going to unpack the contents.
  3. Master Korbel- Brigantine Phoenix (Plus Edition) £180 plus p&p. Master Korbel - Schooner Polotsk (Plus Edition) £160 plus p&p. I do not have the time or display space that these kits deserve and would like them to go to a model maker who can do them full justice. Both kits contain the full sewn sail set, are new and untouched internally. I will post them tracked and insured. PM me if you are interested or want further information.
  4. Based on the photo of your Allerton Steam Pumper model in bobandlucy Concord Stagecoach build log and your description, I ordered the two-horse hitch for my Allerton Steam Pumper model which is still awaiting my attention.  (Beautiful model by the way).  I now need to find a pair of 1/12 scale horses to go with it.
    1. Tankerman
      Tankerman
      My horses came from ModelExpo but it looks as though they are out of stock, this is the company that manufactures them so you may find them elsewhere.
      https://www.breyerhorses.com/blogs/news/welcome-to-freedom-series?srsltid=AfmBOoriJ6dNF75-YN3Ev_e9LJEumRLr7otQclPFtuP3-VY-BncdTJL7
  5. This is a Model Trailways kit. After following this build log I was very interested in attempting the model myself: The kit retailed at £450 in the UK which was more than I was prepared to pay but in the New Year Sale at Model Expo earlier this year it was on offer for $200. Even with shipping and import duty it was still a substantial saving so I bought it. I always expect a lot of hard work where white metal is concerned ( unless it is a Model Factory Hiro 1/12th. car kit ) and sure enough I was not disappointed. The moulds were obviously reaching the end of their useful life and I spent many hours grinding and filing away excess metal, not just flash but huge lumps. In other places areas where the cast was missing I built up with low-melt solder and then filed back to shape. Although I was very pleased with the end result I thought a team of horses would set it off nicely, I could not find any photos to tell me if it was a 2 horse or 4 horse team. I went for the 2 horse team as the overall length would fit in the display case I had.
  6. I strongly recommend the Model Trailways Harness Kits and Horses, they really enhance the model.
  7. Deluxe Materials "Glue 'n' Glaze" is the product I have found that is better than PVA glue for glazing windows and portlights. It is similar in consistency but seems to give a better appearance.
  8. This may be of help: https://www.blundellharling.com/product/imperial-academy-architects-triangular-scale-rule-12-300mm/ Good luck
  9. I can thoroughly recommend this compressor from a totally reliable specialist supplier. It is very well constructed, quiet and very reliable. I have had a Sparmax compressor for many years and would not consider anything else. https://www.everythingairbrush.com/product/sparmax-professional-mini-piston-airbrush-compressor-2-5-litre-air-tank/ Chris
  10. Chris, I built your Agamemnon some fifteen years ago a couple of years after I retired from work and enjoyed every minute of it. Indefatigable looks like being an incredible model and I wish you every success with the forthcoming kit.
  11. Very much by trial and error wefalck, I was lucky that the red on the truck was a good match. Chris
  12. I have used this method on several of my models and show two examples below: The T2 tanker is the very old Revell kit at around 1/450th. scale and I wanted to show it as one of the many T2s owned by the company I sailed with. The company logo was downloaded form the web. The "Caltex Glasgow" and port of registry in the correct font and size ( less than 2mm in this case } were added to the file over a black background. The file was then printed on to a white decal waterslide transfer paper by 'Experts Choice' using a domestic inkjet printer. Once the ink was dry the sheet was sprayed with a clear acrylic varnish to seal it, after which the images were carefully cut from the sheet and applied to the model. The tractor unit is a conversion of the standard AMT 1/25th. kit of the White Freightliner to represent the ones operated by Carolina Freight. The logo on the door is a commercially available decal but the fleet name on the roof deflector and front bumper, the fleet number and legal lettering are generated in a 'pages' file on a Mac to the correct size and font, given a red background and printed off on white decal paper. The red print colour matched the red paint I used on the cab. I hope this helps you HOF.
  13. I ordered the sets of planking for the Trumpeter 1/200 Titanic from their store on ebay which came direct from the States, well packed in a very stout box and in pretty rapid time. Hopefully you should be able to obtain what you want without too much hassle.
  14. Having bought a jar of this to try I wouldn't be without it now, such a versatile glue. Not only the windows but all the PE and resin decoration on the stern of my Sphinx are securely attached with it.
  15. Here you are: https://www.abebooks.co.uk/servlet/BookDetailsPL?bi=30549031522&searchurl=an%3Dwilliam%2Bmowll%26fe%3Don%26sortby%3D17%26tn%3Dss%2Bgreat%2Bbritain%2Bthe%2Bmodel%2Bship&cm_sp=snippet-_-srp1-_-title1
