Everything posted by Nirvana
At my last visit in Seattle one of our MSW member cut me a perfect 15/32" x 15/32" stick to be used for the cannon ports. The stick was cut using Byrnes table saw with micrometer. Instead of marking of each bulkhead from a caliper I used the stick to get the correct height between the lintel and sill. The stick turned out to be a good tool as well.
Fokker Dr.I by Torbogdan - FINISHED - Model Airways
Nirvana replied to Torbogdan's topic in Non-ship/categorised builds
Tor,I am crying seeing the receipt for gas of yours. My last fill up cost me 36 dollars for 13.1 gallons. Now let me try to convert it to Swedish units...... That will be 50 liters and 290 kronor for 87 octane gas. -
Sail design for 18th-century longboat?
Nirvana replied to Cathead's topic in Masting, rigging and sails
Thank you Chuck for the clarification in this matter regarding the horse. In other words the version I did with the tiller under the horse would be later 18th century. I also added a signal cannon at the stem, which I found out that some longboats had as well. -
Tor, Why not upload picture directly to MSW? Do you need photobucket? -
Mr. Pucko Have you contacted the consortium that build Gothenburg? You might be able to buy plans from them.
- 305 replies
- deagostini
- vasa
Just my two cents in this matter, when building my long boat I opted to go with the tiller below the horse, right or wrong..... who can tell. For me it was more of an esthetic view, but also made sense. At the time of years when longboats were built I just can imaging the variations that came out....... I don't think any were right or wrong...... Well, just my two cents -
My Syren is back on a steady course. With a big Thank You to Marc Mosko at ModelExpo I am back. The replacement part was so straight and accurate it was a very easy job to get the "skeleton" together. Anyone reading this, make sure to taper the stem piece before gluing it into place. See picture two. This is where the figure head will be attached. Tapering after attachment will be much harder. I am now at the stage of doing the planking between bulkhead 16 and 20. The pre-fairing of the bulkheads came out good as well. So far no incidents.
America by Nirvana - Constructo
Nirvana replied to Nirvana's topic in - Kit build logs for subjects built from 1851 - 1900
Kevin, I only have rigging left, and this is where all manufacturer fails, giving good instructions of how-to. But someday I will have three ships that will its rigging done.
