Posts posted by AON
Thankyou for the comments.
My build will represent the ship as originally launched or having first entered service (1786-1790).
Reading she had carronades in 1795 does not mean they were there in 1790 or 1786 but the build contract does specify the accomodation for them. Reading a comment suggested to be by an eyewitness that they were there is a game changer... if I read it correctly.
I will need to take another crack at it and let it percolate a bit.
Yesterday was a beautiful warm (28°C) sunny day so I decided to spend it sitting on the patio reading my new book: From Powder Monkey to Governor, the life of Rear Admiral Sir John Hindmarsh, RN 1785-1860, First Governor of South Australia and Lt. Governor of Heligoland. Published by Access Press, 1995, and written by his descendant, F. Stewart Hindmarsh. ISBN 0 949795 88 7. Only 189 pages and I made it to page 19 before the neighbours came over to visit and I had to force myself to put the book down.
He entered the RN at a most irregular age of 5 years as a servant to his father, John Senior, appointed Gunner, a Warrant Officer aboard the brand new 74 gun warship named Bellerophon. Earlier I had discovered his son, John Junior or "Jack", was at the Battle of the Glorious First of June (1794) when he was 9 years old, Cornwallis` Retreat at 10, and the Battle of the Nile as a 13 year old Midshipmen where he found himself the only officer alive on deck and so assumed command and saved the ship. This is why I had to read the book!
In those first 19 pages I learnt what life was like for a "Youngster" (normally 8 to 14), where they slept (the Officers Nursery), how they were guarded at night by the Gunner and Chaplin whose cabins were nearby, and the posted guard called "the Lady of the Gunroom", what they ate (makes my stomach turn), the hours of schooling, etc. Then they describe the "Oldsters", the midshipmen, and their place onboard.
It was a real eye opener... but then I read the statement "I don't know why they called them a 74 when they had 82 guns". They list all the guns of a 74, with the addition of 8 carronades, 2 x 32 pounders on the forecastle and 6 x 18 pounders on the poop (roundhouse).
I`ve read a list of all the 74`s that were issued carronades and Bellerophon was not on the list... but the build contract specifies accommodations for carronades but that doesn't mean she had them...but then again at Cornwallis` Retreat (16 June 1795) it was reported that the Bellerophon threw her carronades and shot overboard in an attempt to pick up speed and break away from the French.
I am beginning to believe that I need to add 8 carronades to my build!
Absolutely correct. Transposing my gunport corner locations from the original plan identifies which are skewed. Although my templates are square I will remember this fine point.
Presently trimming and sanding the top timbers down to their proper heights. All indications are that this will yet again be another long drawn out affair.
UPDATE: Bruce (next message below) has contacted SMS already and it is being dealt with!
I believe he got to it before me because he is 5 hours ahead of me!! 😇
I have forwarded your message to the Society of Model Shipwrights in London.
Hopefully they will contact you via this forum as many are here.
- Keith Black, bruce d and mtaylor
- 2
- 1
Went back to the build contract to get the proper sizes for the various gunports as a triple check.
Gun Deck 3'-3" wide x 2'-8" tall... except the aft most which is 3'-4" wide (I don't think anyone will notice 1" difference at 1:64 scale)
Upper Deck 2'-10" wide x 2'-8" tall. (There will also be two in the beakhead and two in the transom at a later date)
Quarter Deck 2'-8" tall x 2'-5" wide
Forecastle 2'-8" tall x 2'-5" wide
Roundhouse The contract doesn't give dimensions but they measure 3'-0 x 3-0" on the plan
Port Cells: (Upper and lower) are said to be 7-1/2" deep (through the frame) on the gun deck and 6-1/2" deep on the upper deck, and "put in with a bill as done in the King's yards". They do not give a height but they all measure 8". The "bill" angles are 30°-60° and 120°.
So I created and printed paper templates of the three sizes that I will glue to stiff thin card stock and cut out the outline to be used for tracing.
There is an dimensioned 8" long line provided to the right to check the scale when printed.
My intention is to hold the template at each marked location and trace the shape in preparation for cutting through the frames.
I will need to practice this (tracing, drilling, sawing) on a dummy frame setup first to get comfortable as I am anything but comfortable with the idea at the moment.
We called it "a round tuit" because it would get done when we got "a round tuit".
- thibaultron, mtaylor, Canute and 1 other
- 4
You can get some 1:64 scale figures at the NRG Store
https://thenrgstore.org/collections/model-figurines/products/seaman-13
- Keith Black and mtaylor
- 2
starting marking heights
I've got the four hawse hole locations marked (at two per side) and six gun deck gunports marked (at three per side)
I measured off the original 1:48 plan x 48 / 64 to get my scale measurement. Double checked that to my 1:64 plan. Then marked them on the model.
I use a soft "preacher pencil" to mark the four corners and a flexible ruler to hold tight to the curve of the frames and connect the dots with a line.
I learnt the term "preacher " versus "farmer" pencil yesterday morning on television watching the master woodworker from Eureka California.
A preacher pencil has a fine point to mark the truth or true location.
A farmer pencil has a dull point to mark a wider line as a guide for cutting with ease allowing a bit of wander.
Both have one thing in common.... an eraser on the end!
He cracks me up.
Below are a couple photos of my using my height gauge. It can also be used inboard.
Ahhhh! I see it now!
Book Volume II Chapter 8
3D Figure: 8.34_Forecastle_Bulkhead_03
Thank you
- usedtosail, Keith Black and mtaylor
- 3
Do you have a reference image (drawing, sketch, photo) that you are building to that shows this relationship you can share?
- mtaylor and Keith Black
- 2
As said in a post above, be aware that when they wrote diameter they meant circumference.
Why?
I have no idea.
They invented the language so I imagine diameter meant something different in that time frame.
- thibaultron and Dave_E
- 2
Well I believe this portion of fairing the hull has been completed... and I cleaned all the dust up in the shop.
I will start remarking the timber tops and gunports next week as this weekend is full of ship model club meetings (Friday, Saturday and Sunday) and our baby boy turns 40 so there will be a family gathering and spirits will be partaken of.
When I start I'll be measuring thrice, then checking yet again because last night I dreamt I cut a hole in the wrong place. YIKES 😲
I did manage to get into the shop and determined, though it is looking fine, I am not quite done yet.
Other than that, we were surprised with temperatures just shy of 20°C (it reached 19.7), and finally a good abundance of sunshine... so yard work was called for.
There will be plenty of time for more sanding... rain is predicted.
Working on fairing inboard.
I'm left with the same nagging question: "when is it enough?"
My wife visits me and asks: "will anyone see that?"
My response: "I will know."
There was this look, after 46+ years I know it well, she left the room.
I think I'm done, but someone suggested looking with different illumination.
I'll look with fresh eyes and a different light source tomorrow.
(God please let me be close)
- fake johnbull, robdurant, ccoyle and 7 others
- 10
Yes. I imagine it might have happened. But most sailors would have remembered where they "parked the car". It definitely helped the new crew.
It is the same reason why they had signs with images over the shops in town. People recognized the image but couldn't read the letters.
I imagine some well bred person decided to standardize the figurehead.... cheaper to make than the one of designs. Probably got a bonus, raise, or even a promotion for it. A decision made without thought of consequences.
I believe the story because something very similar happened to me once.
I must admit, I find that I get some strange comfort and feeling of satisfaction passing the palm of my hand over the smooth hull. Makes me want to do it again, and again. Then I look at the inside and that old dreaded feeling comes back, 'damn it, there's more yet'.
Gary - I've never heard or read about using broken glass.... seems like something I should steer well clear of.
Phil - if you only knew the struggles I am having trying to undo 55 years of saying Bell-air-o-fon. Why we all did this is beyond my comprehension, even after we were told we were wrong by one person that knew better. It seems so simple to say it correctly now when I look at it, but my brain doesn't want to go there. That is when I realize the struggles of the sailors back then that couldn't read and were trying to say the word.
Did you know one reason for ship's having figureheads was because most sailors couldn't read so wouldn't otherwise recognize their own ship!
1:64
but your right.... where's the fun in having someone else get mad and start throwing stuff around the shop for ya.
Can we get a view from the far corner to see the back and other side?
- Keith Black, FriedClams and mtaylor
- 3
British Capstan circa 1777 by DocBlake - FINISHED - 1:16 Scale
What a fascinating device for making ring bolts!
