Keep going, Jay.  Looking great.  It does sometimes seem like two steps forward and one back, doesn't it?
Ok Mark, the whole project is getting more complicated, but I am trying to stay on top of it.
There are lots more things I have on the shelf (such as two more decks and all their details) and they have to go somewhere.
The biggest problem with my approach is that the alignment of each deck is very important and the stairs will prove that.
The more I glance at the front thus far, the more I tend to think of a large cut along the starboard side. There will be some outside planking towards the top so I can incorporate the channels (both sides); however I still want to have a look below.
I think, that as I take one step at a time, and not rush, the details of each deck will come around.
LEDs in the store-room??? What store-room??? More walls to create and install on the orlop deck . . .
Edited by Modeler12
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
I'm smiling..as I feel that way to.  With every step completed, it reveals two more complications.  :)   The joys of scratchbulding, right?   ;)
Right, Mark.
Here is another picture for those who might be considering making a cross section mid-ship versus aft or forward. Obviously mid ship is much easier since the hull is almost straight and there is no need to taper the planks.
The contours of the hull make a major difference in what is happening with the planking, frames, etc. And they all have to be in line (fore and and aft as well as sideways)
Jay
The orlop deck has two special store rooms. They had different purposes (sail room, boatsun stores, etc). I don't know what is in them at the present time, but here are the walls as I see them.
When installed, there will be an LED inside and with the door partly open there should be light coming through the opening. I may have to do some sealing near the top of the walls so light does not leak through the rough slots (needed to clear the berth deck beams. I don't want to make shelves because they will not be visible, but there will be some trim along the corners on the outside.
Notice the 'carpenter's walk'; the narrow passage between the hull and the side wall. It was intended for the carpenter to make his routine inspections of the hull. There  would also be shelves here but not on this model. I am still debating about the shelves and cabinets in the storage area forward of this room.
The little alcove you see with the hole in the center is not a Chinese toilet, it is one of the two entrances to the gun powder room below.
Jay
Nothing new to post except a couple notes to myself.
I decided to try casting some epoxy resin inside the 'swimming pool'.
I always like to experiment before committing to the big thing. I kwow about release agents and happen to have a can of some old spray stuff. A piece of clear glass (coated) would do the trick. I made a small wooden frame, mixed some resin and placed it on the release coated glass. All worked great, the resin filled the square mold and it looked nice. But then something stupid happened (stupid on my part).
The wooden frame simply floated to the top of the resin and  . . . . .
At least I know that sealing the edges is important.
For the real 'swimming pool', I coated glass, sealed the edges with tape coated that with wax, and clamped the glass to the front. Then I poured  . . . .
It takes at least 24 hours before I can find out what happened.
Meanwhile I am doing other things like making a lumber rack, mounting barrels (to be held in place by rope) and the cabinets towards the bow.
Jay
Might be a resin available that is intended to represent water, seem to have read something about such material somewhere. You are doing good work on this project.
jud
Jud and Dave, here is the result of using a casting resin to represent the water. I had no idea how much to pour in because the front was covered with glass and a large clamp to seal off the edges. I toyed with the idea of adding another layer, but I am afraid that might end up a disaster. Less than half a tank is better than no water at all.
Notice the 'lead oxide' in the bottom :angry: . What will come much later is a 2 inch lead pipe going down from the hand pump on the berth deck. It just happened to be right in the front of this model, so I am going to give that a whirl.
The two lines holding the barrels will be tied off on two cleats mounted on the center post (not yet installed). I am still working on the storage racks.
Edited by Modeler12
Jay
There are two more things to add to the orlop deck at this point.
The cabinets and shelves towards the bow and the stairway going up to the hold deck (short) and berth deck.
The latter is still in the works (obviously), but the cabinet is ready to be installed. This turned out to be a very complicated piece because of the curvatures along the back side. I am not really happy with it, but it will be almost hidden in the storage area forward and along the port side. I will install another LED along the beam far right top.
Edited by Modeler12
Jay
Making the stairs is tricky also.
My first attempt was to install each tread one by one using a 'gauge' with the 30 degree angle I wanted.
I quickly gave up on this approach and decided to make a fixture that would allow me to install all treads in one step.
I took a piece of birch cut to a thickness just short of the tread width and milled slots at 30 degrees as shown below.
I might add that I had to use a bit of trigonometry to calculate the indexing of the mill, but it turned out ok. The cutter is actually a 1mm drill bit, so I had to make several passes with small bites.
The last picture above shows the first stair with the solid panel backing as it is right now on the Connie in Boston. However, this piece is not yet finished.
In fact I need to redo this with treads that are cut to length better then this first try. Since then I made a new miter box to cut pieces to the same length.
I need to make four more stairs; one with backing and three as an open stairway.
Jay
Great use of your mill Jay. Got a question.  :rolleyes: Within the next couple months or so I plan to get Proxxon's MF70 Micro-Mill, and I've been on the hunt for a tilt-table, like the one you're using there for those stair-treads. So far, I haven't had any luck finding one small enough to adapt to their compound-table, and I'm wondering if you might have any ideas on where to look. I'd like to avoid having to "home-make" one.
Cheers
GEORGE
Cheers
George, the only one that I know of is from Sherline. The problem is that they don't use the metric thread system and  you would have to drill a couple holes to adapt to other mills that use the metric dimensions.
Is that tilting table really too large for the Proxxon mill?
Jay
Well, I actually don't know for sure, but the total weight of the Proxxon is only 15 lbs., so I would imagine since the Sherline is a full-size mill, their tilt-table would be pretty big.  I guess I'll see about making one after I get the mill and divider for it.
Thanks Jay!  :)
GEORGE
Thanks Jay!  :)
The idea of the tilting table is pretty simple, and making one yourself would not be that difficult.
If you want some more pictures of the one I have, let me know or go to the Sherline web site to see more details.
Go for it George.
Edited by Modeler12
Jay
Thanks Jay.  I was just on their site and what I might do is just get theirs and make whatever mods to the base-plate I need to get it to mount to my compound table. Looks small enough to fit and for $115, it should be doable without too much headache.  :)
GEORGE
George, shop around. You could save a little. Been looking at these myself. Minicasting andDiscount Campus are around $105 US and the Mikes Tooling about $110.
http://www.minicastings.com/acatalog/SHL-3750.html
http://www.discountcampus.com/store/sherlineacc.htm#mill
http://www.mikestools.com/3750-Sherline-Tilting-Angle-Table.aspx
Ken
Started: MS Bounty Longboat,
Thanks Ken.  Got 'em bookmarked.
GEORGE
I am finally getting to where I can install and glue the berth deck in place.
The cabinets and shelves in the storage area are glued down (and I even cut and fitted the clamps for the gun and spar decks).
The stairs from the berth deck down to the orlop (and the short one back up to the hold deck) are fitted and ready to be glued in place.
All of this will be more visible when some of the frames are cut away.
Jay
The final product is a long ways away. But thank you for your interest, Carl.
The next step is to make more of those round posts on the berth deck. They help to support the heavy gun deck above.
I counted about 16 for my cross section alone (and that does not include four thinner ones at the corners of the hatches).
The ladder you see goes up to the gun deck and will be included. I also want to make that small wooden enclosure or cabin for one of the officers and lots more hammocks.
Edited by Modeler12
Jay
The posts and the ensign cabin are made and ready to be installed.
I need to locate and drill holes for the elongated posts and also modify the C-knees (as I call them) to fit against the bulwark. This will be done after the gun deck is fitted in place, so I can measure the height I need and cut the posts to length.
I might mention that to glue the thin strips against the cabin walls I used some lead shot in a jar (or box). They are small but heavy.
Jay
Looking aft
There will be a forest of posts (three more down the center to be made and two along the front). Again, I don't want to cut them to length and glue them in place until I know how high.
I juggled and carved the C-knees to fit the bulwark above the beams. It turned out that towards the bow there are fewer than I expected.
I also show the ensign cabin with the door on this side. Although private, this must have been cramped quarters.
What will make a difference is when I make and install the other knees:
1. the standard knees that stand vertical against the bulwark but don't go all the way to the deck.
2. the hanging knees that go diagonally from the bulwark to the deck beam above.
3. the lodging knees that go horizontally between the beams and against the bulwark (some of these I have installed on the orlop deck).
The diagram above is an older version with the water tanks too small. But it does show where the various knees go on the berth deck to support the heavy guns above.
I think the berth deck will be mundane but lots of hammocks should help.
Jay
I should have added the following picture to explain the knees.
This must have been mid-ship and gave me the idea that every beam was supported by one of those C-knees. So I made a dozen or more.
Does anyone need some extra knees?
Jay
I guess you could ask your local orthopaedic surgeon ...
(Okay ... I'll leave quietly)
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Steve. I wonder how many body parts a ship can have.
Jay
Interesting question, Jay.
Knees, (dead)eyes, heads, waist, arms (ie: cannons) ....
Any others ??
CaptainSteve
belly, bowels ;)
Jack
Current buildUS Constellation
Waist
and then there are 'related parts' like heel, hand, palm. At least they are naval related.
For an interesting reference see the nautical dictionary
http://www.alquiler-directo.com/boat-hire/nautical-dictionary-h.php
Jay
