Jeff,
I'm late to see your build. I'm sweating out the gun ports on my AL build, but will use your build as inspiration. Your detailing is more than I plan on my build, and adds a lot. Can you show another long shot of your build? It is such a beauty, and I would like to see it with the new detailing.
Bob
"Even while the storm raged at it's worst, my ship was wholesome and noble." - Captain Joshua Slocum
Current Builds:
L'Hermione 1780 - 1:89 - Artesania Latina   http://modelshipworld.com/index.php/topic/10261-hermione-la-fayette-1780-by-bobstrake-artesania-latina-scale-189/#entry305929<p>
Louise - 1:26 - Constructo  http://modelshipworld.com/index.php/topic/11855-louise-by-bobstrake-constructo-scale-126/?p=360370
Completed Builds:
Carmen 1850 - 1:80 - Constructo - First Build   http://modelshipworld.com/index.php/topic/10398-carmen-1850-by-bobstrake-constructo-scale-180/#entry31137
Jeff,
Just a suggestion, but before you go too much further, drill the holes for the masts.  If something goes amiss during this, you don't want a lot of deck furniture that can be damaged or need to be removed.   I thought the instructions had the holes being drilled earlier than this.... I could be wrong as I built mine totally out of sequence.
Oh yeah, she's a beauty! Thanks for the view.
Bob
Current Builds:
Completed Builds:
The masting is looking the part and looking good, Jeff.
Looking good.  Once a mast gets installed the model takes on a whole dimension.  Kind of renews the excitement of the build... at least for me.
Looking good, Jeff.  I'd call them wales (not whales... those are a different critter ;)  :P ).  If you can, put a touch of flat black paint in the hawse pipes...  I think you'll be even happier with them.
Hey guys a very quick update started working on Not sure what they are called but first attempt was rather bulky and cramped together so I started to think Hum What do I have that could possibly look better Wa la tooth picks so I drilled sanded and came up with this think it looks much better and more proportional what do you think
Edited by Jparsley
Jeff,
Nice idea.  It is simple and it looks good.  The kit instructions want you to put a square hole in the flat piece and insert the square pegs.  Making tiny square holes is a bit of a challenge.  I overcame this by cutting the square pieces and gluing them on both sides of the flat piece so they looked like they were actually put through a square hole.  In reality, there was no hole.  Your idea was much simpler and cleaner and it looks great.  She is coming along nicely.  :cheers:
Tom
I like it the after look.. just crisper.
Jeff,
Treenailing is always a builder option.. :)   Moreso at the smaller scales.  Do what you'll be happiest with.
