Hi everyone!
Many thanks for your LIKES and your interest to this project!
A small update here. Today I present another deck element - the steam winch ))
Best Regards!
Igor.
Hi Nigel,
Yes, I think you all understand correctly.
What size boat need to you?
Best Regards!
Igor.
Hi Igor,
Thanks for the confirmation!
Ships boat will have a length of 5.5cm with a max beam of perhaps 1.5 cm. Still working on the design, but pretty big by your standards!
Steam winch you just made looks awesome!
Cheers,
Nigel.
Edited by UpstateNY
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Can I please ask what you used as the round cogs at the ends of the winch?  Were they watch mechanism parts?
Hi Patrick,
I have used the 3 parts from the set of the photoetched detailes - base, which I cut into 2 parts and 2 wheels.
I will make the photo of this kit evening.
Best Regards!
Igor.
Thanks Nigel!
5,5 cm?!?! WOW!!! This boat is very big! ))
I think the boat of this size can be made in the traditional way.
I've done several boats from kits. The smallest was 75 mm.
11193338_475353995950056_138666130531888
Please, look at this link - https://www.shipmodeling.ru/tips/lifeboat
Perhaps it will be useful to you also.
Best Regards!
Igor.
That's a clear show of building a small boat Igor. Yours? If so well done, else for the other person my compliments
Carl
Hi Igor,
Wow..those boats are all great! Wonderful work.
My boat is certainly large by your standards, but as I've never made something like this before, large is probably a good place to start!
Thank you very much for the link showing your other method.  I am wondering if I can actually carve a decent base to frame the boat around. Your other method looks easier for me to try for a first build as I can build it up from flat sections. Appreciate all the help!
Cheers,
Nigel.
Hi Patrick,
Here are 2 sets of photoetched detailes -
934814_527957710689684_48225277553470251
Edited by IgorSky
Hi Carl,
I made these 4 boats shown on the photo from the kits with laser-cutted parts. I was wondering just to try to do it.
The method shown in the link is also very pleasant to me. It seems to me it's quite simple, but effective. It is not my method, I found it on the internet a long time ago.
The method that I used for building these 2 lifeboats for LENA, I use quite often in my SIBs. Using this method I was able to build the really very small boats -
1506747_448673575284765_8993410260115981
10614274_449989341819855_474723924155418
11070816_452930554859067_881011058195976
Edited by IgorSky
Thank you Tom,
I think that to make all this is not as difficult as it seems ))
Yesterday I have done some inconspicuous works, so I have the quite a little to show.
Best Regards!
Igor.
stunning work Igor !
winch and other metal work at that scale, well done
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Tom!
I think you just need to start do your model and all will become clear in the process of work.
And of course we are ready to help you.
Best Regards!
Igor.
P.S. Maybe I am forced to do the little boats because I'm not very good doing big it ))
Hi Igor,
I have a hard time believing this... :)
I only see SIB's in your signature, but if you ever decided to do a larger build, I expect the build and its detail level would be stunning!
Cheers,
Nigel.
Edited by UpstateNY
Thank you Nigel!
I have made several the kits of ship models a few years ago. But they were the ordinary models from the box ))
Edited by IgorSky
Hi everyone!
Thank you all for your support and interest in this project.
Yesterday I have started to make handrails.
Best Regards!
Igor.
I like the way tou made the stanchions thicker.  I'll have to remember that one.
Bob
Current build:  SS_ Mariefred
Hi Carl and Bob!
Yes, I have added the wooden stanchions which were made from the plank about 0,35x0,35 mm.
Earlier I have made of brass wire stanchions 0.3 mm for Atlantis
18683_461753763976746_474422054770311453
1508162_461948000623989_1445727230783857
But in this project I want to try to make a wooden gunwale on the stanchions.
How many times am I allowed to say, "Wow"?  Without the tweezers in the picture I see a 1:29 scale model not a 1:129 scale.
Bob.
That's even better, but the log heading says 1:290.  Is that wrong?
Bob
