Hello,
This is my 3D build log for HMS Pandora. The build was started in February 2011, and it is still in progress.
The primary references include the Anatomy of the Ship: The 24-gun Frigate Pandora (the plans), The Shipbuilder's Repository (it contains the dimensions and the scantlings of HMS Porcupine, which is of the same class as the Pandora), and the “Swan” Series. Many other books and online resources are also referred to.
I began with drafting a 2D drawing of the ship, and then I imported different parts of the 2D drawing into Solidworks to guide the 3D building process.
In the following posts I will post the screenshots I captured during the build and briefly describe what is new in each figure.
Jingyang
Best regards,
Jingyang
Current build: HMS Pandora (1779) in 3D
Let's get started!
2011-02-09: keel, false keel, perpendiculars, cutting down line, lower deck, upper deck, stem post, stern post, stern counters, stern timbers
2011-02-10: toptimber line, top side lines, water lines, forecastle, quarter deck
2011-02-12: lower breadth line, upper breadth line, main wale, sheer rail, waste rail, drift rail, fife rail
2011-02-15: gun ports
2011-02-17: channels, deadeyes
2011-02-18: planking above the load water line, platforms, knee of the head, ladder, fenders, chestree
2011-02-19: lower cheek, upper cheek
2011-02-20: head rails, head timbers, cathead
2011-02-21: taffrail, quarter gallery
2011-02-22: rudder
2011-02-24: gun port lids, sweep ports, scuppers, hammock cranes, swivel guns. The taffrail and the quarter gallery were modified.
Best regards,
Jingyang
2011-02-26: details of the chains and deadeyes
2011-02-28: HALF-BREADTH PLAN added - keel assembly, main half breadth, toptimber half breadth, top side half breadth, half breadth of the rising line, projections of the diagonals
2011-03-02: BODY PLAN added. A set of lines for the inner surface of the frames are also drawn but not shown in this figure.
2011-03-04: water lines, cant frames, fashion piece, hawse pieces, transoms, inner post, apron, keelson, first thick limber strake next the limbers
2011-03-05: deadwood knee, disposition of the frames
2011-03-08: disposition of the square frames
The 3D build began from this point!
Best regards,
Jingyang
2011-05-17: internal planking and external planking
2011-05-20: The space between the internal planking and the external planking was filled to form the shape of the frames.
2011-05-21: the shape of the keel assembly
2011-05-23: cutting the frames
2011-06-12: All frames were completed!
Best regards,
Jingyang
2011-06-15: main wale
2011-06-15: shape of the external planking
The frames can be seen by setting the external planking transparent!
2011-06-16: Cutting the bottom planking into individual planks.
2011-06-17: Finished cutting the bottom planking.
2011-06-18: The main wale was also cut into individual pieces.
Best regards,
Jingyang
Jingyang,
I played around with 3d years ago and never came close to the skill you are showing. Well done.
David
Thank you, David!
At the beginning I was not sure about how to draw this in 3D either. And I tested quite a few methods until I found the one that works for me. :)
Jingyang
Edited by ppddry
Best regards,
Jingyang
Incredible work! It shows so much detail of a physical build! Thanks for showing all the interim work to get to the more complete-looking model.
-Sarah
Krabbenkutter CUX-87
Harriet Lane
Fishcutter GO-38
In the Wings:
Corel Victory Cross section
Completed Build:
USS Missouri minimissouri.jpgHMS Bounty's Jolly Boat thumbnail.jpg Peterboro Canoe tiny.jpg
Thank you! :)
Best regards,
Jingyang
Excellent work. I enjoy all the detail you have done. Are you going to build this in wood later? Keep the pictures coming.
Wacko
Joe :D
Go MSW :) :)
2012-06-05: assembling the stern to the hull, adding the rudder chains
2013-02-11: ladders connecting the lower deck to the upper deck, chain pump winches, iron pillars on the upper deck, shot racks on the upper deck
2013-03-04 to 05: forecastle planking and fittings, quarter deck planking and fittings, catheads, stove, capstan, forecastle planksheer
Best regards,
Jingyang
Thanks WackoWolf. No plan for building her in wood yet, but it is definitely possible!
Best regards,
Jingyang
