Hi all.
Deck furniture almost completed.Starting the bowsprit.
Ciao a tutti.
You are doing a fabulous job Giorgio.  Your model resembles the Benjamin W. Latham.  Since both did the same thing they would be similar.  The fun is going to be all the iron work when you start getting into the masts and rigging.  How did you make the cap on the bowsprit?
David B
Hi David, you're very kind. I simply used a 0.25mm thick brass strip. This is properly bended around the bowsprit to create also the lugs at 0° and 180°. Bended lugs are then soldered.
After installed onto the bowsprit, two holes  at 90° and 270° are prepared to receive lugs made from wire.
This is not really correct, but after painting the overall effect is good.
Ciao, and happy Christmas to you and to the other friends.
Giorgio
Edited by GConiglio
Hi all! Long time to prepare masts and accessories.
In particular mast hoops: first prepared turning a copper tube. Not ok.
Then soldering copper strips. Not ok.
Finally, wrapping paper around a wood rod. Result ok!!
Ciao!
Ciao Giorgio
Finally went through your entire building log.  Well Done!!!!    What are you using for rigging plans, including block and rope sizes and belaying points?   This is always a sore point with me as I cannot find a really good single source.  Chappelle has several Gloucester vessels'  block lists, and most plans have sail plans, but I have not found a good set of drawings showing the run of the lines right down to the belaying points.    Chappelle is a huge help, but a royal pain to use as each chapter is alphabetical from anchor to windlass.  Even with the many great details he shows, it is not complete as far as rigging.
 Ciao
Allan
Hi Allan, I appreciate your post, thank you.
The Ingomar is mainly based on the Chapelle book, other books are shown in my first post. Furthermore I've bought 20 years ago a  useful drawing from David Mc Gregor. This helps, but the problem is always the same: it's not easy to find a definitive source about rigging. For example, I wonder if crosstrees shall be installed! About the rope, I bought Chuck Passaro ropes in the diameter I suppose fit better in my scale. Anyway, I think the better source is Chapelle book.
I'm going to update the build log in the next days: these pictures show the masts simply fitted in their holes, and not completely aligned.
I hope to exchange more  informations about fishing schooners with you!
Ciao,
Giorgio
P.S.: the b/w picture in the first photo shows Neil Armstrong as a child with a aircraft flying model. I'm a RC-aeromodeller also!
Edited by GConiglio
Just today I received this nice book. The front picture shows the Ingomar!
It'easy to check that crosstrees have to be installed!!
Edited by GConiglio
Giorgio,
My copy of the SAME BOOK arrived this past Monday!!!! Che coincendenza!   I found it on line for US$6.
I am experimenting again with making blocks with internal strops. The method seems to be very good for large sizes, and OK for small (1/8") blocks.  If I can perfect it a little I will take photos and post.
Ciao
Allan
Allan,
che coincidenza!! (conosci l'italiano?)
This wonderful book solved the enigma of crosstrees.
I'm courious to see your work!!
Ciao,
Giorgio
very nice "Gloucester Fisherman" build Giorgio,
it seems to be ready for masting and rigging....
Nils
Current builds
-Lightship Elbe 1
Completed
Giorgio
I have made one to six trips a year to Italy for the past 30 year, mainly for my job so I had to learn to speak a little Italian as a result.  I think there are more cab drivers in Firenze and Milano that speak English than in New York though ^_^
I may start a log on the Effie M. Morrissey as I do not want this to turn into a hijack of your log.  I really  look forward to your progress on the rigging.
 Allan
  • 2 months later...
Hi all. Long time since last post.
I'm a discontinued builder, although continuously interested to read NRG forum and books.
 Anyway, masts are installed, anchors are ready, obtained from a 2mm thick brass plate.
Ciao!
Edited by GConiglio
Oh No! surely you will be finishing the ship, or perhaps you mean intermittent builder. you are doing a beautiful job on the model.
Michael
Deck planking.
Increasing thickness around masts and bowsprit.
Now is time to think to the cabin.
Hello Giorgio,...I like the lines of your hull. Great job, looking forward to further images.
                         Good luck on the rest o your build...:)
   Keith
Current build:
     A Battleship
Past builds:
   The Unicorn - The Lindworm - Malahini -  Shinobi Maru  -  The MaryJane - The Weeligstraal
Thank you Michael, I mean "intermittent".
The correct word.
Ciao!
Hi Giorgio
Phew!!! I almost had a heart attack thinking that you'd given up building your beautiful ship! I'm glad that's not the case, because I'm keen to keep following your future updates.
All the best.
Patrick
  • 4 months later...
Hi all! Summer activities are gone.
The shipyard is going to restart.
Ciao!
  • 2 months later...
Back to INGOMAR!!
Hi all, after a long time (summer, repairing RC sailplane) I'm back  to finish this lovely ship.
Bowsprit iron works and stays have been installed.
Ciao
