This is a ship in a glass Christmas bulb ornament. I started it last year & had so many problems. The glass bulbs are many so thin they kept breaking on me. I went through 6 bulbs & two years before it worked out. It is already complete. This is being posted after it was done because I didn't know if it would ever work out or not.
The glass bulbs & the drawings...
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
First thing I did was to make a folding wood disc for a label that will be seen from the bottom. I glued paper to shaped wood pieces so it will fold up & fit through the opening.
First attempt to test fit base in globe neck resulted in the first one breaking at the neck.
Ship in a Christmas Tree ornament. That's gotta be one for the record-books Jesse. Never seen that done before. I'll be interested to see how it all works out as well.
Cheers
GEORGE
Thanks Patrick & George!
Patrick, they are glass & blown way too thin as I was to find out over the last 2 years!
Ornaments by nature are thin glass due the weight.  To heavy an ornament and the branch sags.   This is going to be impressive and amazing to watch..  I'm curious about you did it, Jesse.
Thanks Mark.
I penciled the back of the drawing so it would transfer to the wood like carbon paper
Cutting out & shaping the hull...
I remember you asking me about this. I'm glad you got it to work out.
What a nice little project.  I have my chair.
Bob
Current build:  SS_ Mariefred
I stumbled upon this ship during my research for the Christmas tree boat I'm building........very interesting  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Me too Daniel, even though it took 2 years & I went through 6 of the glass globes!
Welcome Bob, & thanks Patrick & thanks for all the likes.
Thank you for sharing that video Popeye ! I had not seen that.
Painted hull, scored & stained the deck, constructed the bowsprit & started on deck housings....
Jesse,
I am really enjoying this build.  Keep up the good work.
Ryland
               - Nautical Research Guild
The hull is somewhere around 2 1/8 " (5 1/2 cm) long without the bowsprit, 9/16 " (14mm) wide & 4/16" (6 mm) thick.
Now on the 3rd globe after the 1st two broke.
I asked Daniel last year for some advice on how to make a raised sea surface without adding so much weight. He referred me to another SIB builders trick of painting the open space below the sea surface & making a thin disk that would be the sea surface & sit higher in the glass globe. I measured the size I would need by inserting a round paper cut out & trimming it until it fit. Made the wood sea base out of tongue depressor sticks with paper glued on as hinges so it will fold up to fit in the neck & unfold out flat when inside. More pics of the process to follow....
Edited by JesseLee
Constructing the wood sea base....
Edited by JesseLee
Re-did bottom label disc. the 1st one was too oval so I made another one round like it should be. I also added a wood tab on it so I could hold it with locking tweezers making it easier to install & glue in place. Glued it to the bottom.
Painted blue inside glass between bottom label disc & sea base disc
No wonder you went through so many globes.  You need the touch of a surgeon to keep from breaking them.  I am partial to the Rouse Simmons.  Nice miniature by the way.  i will be sitting in and watching the show. And thanks Popeye for the video.
David B
Thanks David
I did some experimenting with this build. Some didn't work out. Wanted to keep things as light as possible. Tried making the sea out of silicone. It shaped great & looked very much like a slightly choppy sea surface. Painted it & it looked very well. It could roll up to be put in the ornament & open back up flat inside for putting down. The problem is nothing will stick to dried silicone. the paint eventually starts peeling & flaking off in spots. It really disappointed me because it had looked so good & it was so light. I hope I can find a way for this to work in the future. It formed the perfect looking wave caps. I had tried not painting it but having the blue paint just underneath it. That didn't look quite right so that's why I tried painting the sicone surface itself.
Hi Jesse,
Been enjoying your build...really challenging with such a fragile glass bulb.
On the sea...just a thought but would a thin layer of Scuply perhaps work so it isn't too heavy? Comes in many colors and could be painted as well. Could be textured to make some waves and lightly rolled to get it in before opening it out. Some white paint once it is in may allow some white caps as well.
Just a thought.....good luck!
Cheers,
Nigel.
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Never tried that David. Will have to look into it.
Nigel, This is actually already completed. I ended up using Plastalina putty.
Very nice project JesseLee.  Looking forward to the how to.  I love miniatures.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Thanks Piet!
