Ordered one, should be here next week from Indiana distributor. Now faced with the problem of picking a project...
Edited by markjay
Phoenix, AZ
Current builds;
Previous builds, in rough order of execution;
Shipjack, Peterbrough Canoe, Flying Fish, Half Moon, Britannia racing sloop, Whale boat, Bluenose, Picket boat, Viking longboat, Atlantic, Fair American, Mary Taylor, half hull Enterprise, Hacchoro, HMS Fly, Khufu Solar Boat.
On the shelf; Royal Barge, Jefferson Davis.
Don,
The only log I've seen so far using one is the original poster's... http://modelshipworld.com/index.php/topic/13427-riva-aquarama-by-aydingocer-amati-radio-a-new-challenge-for-a-so-far-static-ship-builder/
It looks interesting and I can see where it'll be a big help.  I'm not ordering one myself at this point as I don't know if the next ship will be a Hahn type or a right-side up type build.  Cross that bridge when I get to it.
Hi Don,
Yes you can move the white piece back and forward to align each of your frames. The screws which hold it are not permanently tight. They stay loose. You move it, and when it is in place, you tighten it.
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
Haven't put mind together yet, also I won't be using the board itself because it's not long enough but the rest of the stuff I will put to use for the build board I have for the upcoming build will make sure I keep the base that came with it though for later. Will post when I have it setup for the build.
Wacko
Joe :D
Go MSW :) :)
Do the aligning piece need to be unscrewed and move to the next position to continue framing for the entire hull?
Thanks,
Richard
You'll certainly need to move the white aligning tool along the keel in order to adjust each frame, however I at least did not necessarily have to screw it all the time. For me it was just enough to align the piece using the rules on both sides and hold it just there while gluing the frame to place. Screwing tightly to place would be probably needed if you want to use the aligning piece also as a support to the frame.
Current :
Completed:
Titanic - Mantua
Who knows, maybe with all this type of attention to a very specific product HobbyZoneUsa might be a sponsor. With my new workshop I will certainly have some of the modules.
Respectfully
I have a few of the modules. The tool holders are nice, keeping those items in one place and close at hand. :)
Looking at getting some of the paint holders, too; I use PollyScale/Floquil, Tamiya and ModelMaster. And some Vallejo colors, too. The racks are sized for the different size bottles. May try one of each of the 2 sizes of racks.
Ken
Started: MS Bounty Longboat,
Looks like a worthwhile investment to the ship yard. Shall I SLIP into something more comfortable shall I say! Haha.
Regards, Scott
Completed builds:
Awaiting construction:
Finally took picture of the paperwork that came with it for you.
I was able to take what you posted and build my slip. Just on the final pieces waiting for the glue to dry. Then I can try it on my build of the Nao Victoria.
DOES ANY ONE HAE PICTURES OF USING THIS FOR BOF AND OR POB, WOULD LIKE TO SEE HOW IT WORKS AN WHAT PIECES NEED TO BE REMOVED TO SLIDE IT FROMM FRAME TO FRAME, ANY HELP WILL BE APPRECAITED. THANKS Don
Hi Don,
I have used my build slip mainly for gluing the bulkheads and then mostly as a stand after that for planking. During planking I used a pillow which was making it easier for me (as I often intend to take the hull to my lap for close work).
Buy anyway here are a few photos.
On the first picture below you will see the screw holes at every 10cm intervals, on both sides of the base board. You also see the "panel" which is standing vertically. There are 2 "rails" on either side behind this panel. These rails are fixed to the panel (in other words, the white vertical panel and the two rails slide together on the base board). The rails have screws, which can be tightened/loosened using washers. While the screws are in the same hole the rails will allow the panel to move around 10cm back and forth. So,
- as you will work with the next frame, you move the panel accordingly.
- when the rails do not allow moving any further with the screws in the same hole, then you remove the screws, move the panel to the next location and put the screws to the next pair of holes.
Second photo below shows how you use the measurements on the panels for reference:
You can catch a few more photos in the early pages of my Riva Aquarama build log where the build slip is in action:
Br;
Aydin
Edited by aydingocer
Current :
Completed:
Titanic - Mantua
Here is the link for our fellow members located in the USA
Minislip
Edited by Nirvana
Respectfully
I agree with Gaetan.  Also, it would allow modification/improvement based on personal practice.  I am not experienced in creating plans, but if anyone does, please post them.
Richard
Richard
Member: The Nautical Research Guild
Like I had said before, if someone though about it they could do the same thing Like Gaetan did. But I also bought the Hobbyzone setup and I am changing things on it to fit my build, also you can't use it all on a 1.48 ship, but you can change things, but don't trow anything out which I won't.
Wacko
Joe :D
Go MSW :) :)
