I know that this is kind of Backwards, Gallery first then a Revised Build log. To start I have had the drawings for this boat for over 25 years ( purchased thru WoodenBoat. ) so, when I was Approached to build the boat I jumped at the chance.The Boat was built bent ribs over molds just like the original.  So I started by making the molds, the first shot is the clients boat
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
The next step was to set up the molds and dry fit the stem
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Once the stems ( bow and stern ) were cut and the molds faired, the ribs were bent over the molds and then the Keel was laid. then the planking and removal from the building jig
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
The Next step was to Make and install the Centerboard trunk ( with working centerboard ) and brass tubing for the Rudder, Deck beams started and Mast steps installed along with Sampson post, then completion of deck framing
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Next was the completion of framing for the Cockpit/ Cabin Coaming, and a double check of the Mast steps. The  Exposed section of the Cockpit and aft painted white. then the deck was installed
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Next the Deck was painted and the coamings bent , the Hull was then painted Navy blue , port holes cut into coamings, bottom paint applied
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
The Cabin was then completed including the Porthole glass, Cockpit floor then made along with framing for the benches, benches then completed and cabin details started
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Next I started on the moldings and detail; work including the Base, Next came the Varnishing, then the Spar making as well as making the brass turnbuckles
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Once satisfied with the spars they were varnished as well * just a note: there were 4 to 5 coats of Epifanes varnish applied and sanded to 1500 grit sandpaper in between coats , then came the fitting out Sails blocks cleats, I should also point out that the Hull had 3 coats of paint wet sanded to 2000 grit sandpaper then buffed with 3M buffing compound then waxed
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Finally the Roller furler was made along with the Jib, Bowsprit finalized , Standing rigging finished Solar panel made and installed along with Vhf antenna and Air cowl in the bow. In conclusion she took about 5 months to build, the Client was thrilled and said it looked even better when he saw it in person, She was a lot of fun to build
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi Patrick, The owner was and still is Very Happy, She turned out pretty sweet
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Ya know y' just can't go buildin' 'em that quick! There was not enough time to savour the steps over a few weeks.
Lovely boat and equally lovely model.
Michael
Thank you Michael,  I actually finished this boat over a month ago
Best Regards,
Pete
Edited by Pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Pete,
your canoe yawl looks very impressive
Congrats to this beautiful build, a real gem...
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Chris
Thank you Nils, She was a pleasure to build
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Beautifully done Pete, a real gem.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Thank you Piet, She was a lot of fun to build
Thank you John
You are welcome Dennis
Thank you Mark, William Garden did an Amazing job designing this boat
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
  • 2 months later...
Nice build! Looks like you could take it out today.
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
Thanks John, She was a pleasure to build
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
