I "borrowed" a needle threader from my daughter's sewing kit.  I was skeptical that it would work but was very pleasantly surprised when it did.  I liked it well enough to go and buy a couple more for spares (I tend to misplace tools so having a backup saves time hunting).  (They cost about a buck each - my cheapest modelling tool purchase yet!)  The only complaint I have is that sometimes you have to thread from the back and judging where the hole is is a bit of a skill to develop.
If anyone has figured out how to make a threader that works from the front when pushing a line through I'd be happy to get the details!
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
needle threader is great little device ive always found with deadeyes and blocks the ca was best the needle threader normally only comes out when piercing thru shroud lines above deadeye with me anyhows
Thanks Steve,
Good description, thank you.
I use the Line covered in CA, about 20mm, and before the CA dries, I wipe with the "Digits."
If the line isn't stiff enough, do it again until it is.
You have then got a nice rigid thread you can push through all manner of tiny holes. (Blocks/Deadeyes/Rings)
Once through the hole in question, grab the end with Tweezers, Hooks, whatever.
Have a go on something "Off Ship" first.
If the "Bodkin" :) gets brittle, (As it does after a few holes), repeat the CA and your good to go!!
Unsure of where I got the tip but use this method exclusively, much easier than a needle threading device when the Rigging gets "Busy."
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
I'm still progressing forward. I've finished the deck furniture although I still have to add hinges and handles to the hatchway.  I intend to keep the hatchway and the engine cover glued.  I don't want them removable because I don't think there is enough detail below to make access available.  Like Brian said, it will be our little secret that there is a couple of beds below that no one will ever see.
I haven't included pictures in this post because there really isn't anything new to see.  I will add pictures on my next post.
I have designed my plinth but it will be very basic and I'm not even sure it will work.  I basically just traced the outline of #6 and #10 bulkheads and will cut them out of mahogany.  I will connect the two with 1/4" dowels.  My only concern is that I am using 3/4" thick mahogany. I'm not sure how the boat will sit on it.
I actually tried seizing the other night just for practice although I'm not going to use it on my boat.  I was surprised how well it turned out.  Probably first time lucky.
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
I made the plinth.  Nothing special but functional.  There is some extra room to add some felt pads.
Derek
Current Builds
On Deck
Finished Builds
Hey I need to do this.  How did you take off the hull shape?
Doug
I used the sheet that the bulkheads were cut out from.  From the drawing I got with the model, I determined that bulkheads 6 and 10 were the best positions.  I traced the opening from the sheets onto a piece of wood and cut them out with my scroll saw. I hope you understand what i'm trying to describe.
Derek
Current Builds
On Deck
Finished Builds
Brilliant. Can I borrow your scroll saw? - you could PM it to me . Seriously though I should invest in a 3D printer for stuff like this.
Edited by Heronguy
Doug
Well I'm on the finishing stages.  Tonight I worked on the upper structures and mounted the deck furniture permanently.
post-26154-0-66603700-1486687639_thumb.jpgpost-26154-0-97016300-1486687641_thumb.jpgpost-26154-0-63112700-1486687643_thumb.jpgpost-26154-0-09562700-1486687645_thumb.jpg
post-26154-0-59270700-1486687646_thumb.jpgpost-26154-0-32319200-1486687648_thumb.jpgpost-26154-0-63771600-1486687649_thumb.jpgpost-26154-0-97998900-1486687650_thumb.jpgpost-26154-0-53661300-1486687652_thumb.jpgpost-26154-0-92210200-1486687653_thumb.jpg
Derek
Current Builds
On Deck
Finished Builds
And more deck furniture
post-26154-0-80449900-1486687904_thumb.jpgpost-26154-0-54980600-1486687906_thumb.jpgpost-26154-0-08047900-1486687908_thumb.jpgpost-26154-0-45000800-1486687910_thumb.jpgpost-26154-0-09573400-1486687913_thumb.jpgpost-26154-0-44622300-1486687915_thumb.jpg
Derek
Current Builds
On Deck
Finished Builds
Continuing the final details.  I started some rigging. I know it's not "proper" but it is as per the instructions.
I did a little more sanding to the plinth and added a second coat of varnish
I had a small accident and knocked the model over.  Because of that one of the frames broke off.  Not a big deal, just re-glued it.
I'm hoping to have this finished this weekend.
I spent a half hour re-jigging my work area in anticipation of the Bluenose.  Hopefully I will start the build log very soon.
Although the Mare Nostrum has given me a lot of grief, and although I have seen a lot of much better examples in other build logs, I'm still happy and proud what I have done with this little kit.  I will display this proudly.
Derek
Current Builds
On Deck
Finished Builds
Hi Chap,
I'll be watching your "Bluenose" also if you don't mind.
I take it that it is the 1/75 A/L version?
Will be good to see how this progresses and have been watching your Mare Nostrum build thus far.
I guess you will have learned much from this, and hey, I'm still learning after 10 or so years doing this. (I'm still making basic errors)
Take your time Sir, consider things carefully and if not sure, take some time, Think/Sleep on it, it will work out o.k.
(My BNII took 10 months, was my second build. (Photos are available if these would be of any assistance.)
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hey Hof, the Bluenose is the Model Shipways 1:64.  Starting soon.
Derek
Current Builds
On Deck
Finished Builds
So here it is.  The final pictures of my Mare Nostrum.  I finished tonight.  However, there is one addition I want to make but the part hasn't come in yet so I won't close off the build quite yet.  But for the most part, it's finished. It's not as detailed as it should have been but to me it's a good model.  There were some discrepancies between the plans and the picture on the box.  But I did what I thought was correct.  The bench is now empty, waiting for the next build.
post-26154-0-82075200-1487121967_thumb.jpgpost-26154-0-93736600-1487121968_thumb.jpgpost-26154-0-75718600-1487121970_thumb.jpgpost-26154-0-74314800-1487121971_thumb.jpgpost-26154-0-78837400-1487121972_thumb.jpgpost-26154-0-60253900-1487121973_thumb.jpgpost-26154-0-61596200-1487121974_thumb.jpgpost-26154-0-62582100-1487121975_thumb.jpgpost-26154-0-64143000-1487121976_thumb.jpgpost-26154-0-66776200-1487121977_thumb.jpg
Edited by Worldway
Derek
Current Builds
On Deck
Finished Builds
Congratulations Derek. One down, lots more to go!
A really great start on your modelling career. On to the Bluenose II!
Doug
Thanks Doug, looking forward to my next adventure.  By the way, I've noticed you haven't posted any build logs for a bit.  Everything progressing OK?
Derek
Current Builds
On Deck
Finished Builds
Nice one Derick!!
Looking forward to your "Bluenose" or whatever you should choose Next.
(As I have said, I think you have learned much, as I also continue to do.... :))
Cheers and Regards.... HOF.
(Harry.)
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Nice job man, I am about 25% done with this kit, got side tracked with a dollhouse kit, and lost my picture instructions!
Thanks for posting the pictures about the kit pieces not fitting, it seems everything piece I got with the kit is off.  pain in the a$$
Casey
"I drank what?" - Socrates
Current Builds:
Finished Builds:
Future Builds:
  • Mamoli Golden Hind
  • Mamoli Black Prince
  • AL Swift
Filling, sanding, priming, rigging, thinking, reading, agonizing a bit - nothin' much to show!
Doug
I got some inspiration from Moonbug and decided to pull out the gear.  I set up a photo area to take "better" pictures of my builds. Besides I'm having issues with using my cell phone now, not sure of the problem.   Just seeing how things turn out with these pics.
Derek
Current Builds
On Deck
Finished Builds
Hi Derek,
Looking at your light setup here, and have a couple suggestions. Since you're photographing such a small object, you can get that softbox or umbrella really close to the model. That will also soften the light up considerably. And if you get one of the lights behind your sheet, you can put that one a couple stops above key exposure and wash out the creases.
Best,
Achu
Thanks Achu, appreciate the advice.  I'll try what you suggest and see how it goes.
Derek
Current Builds
On Deck
Finished Builds
Thanks Steve, coming from you that is definitely a true compliment.
Derek
Current Builds
On Deck
Finished Builds
