Has anyone had any experience removing the clear coating that is used on copper wire used in relay coils and or transformers or electric motors?
I would like to do this without using any abrasives and also the wire I am hoping to do this with is .005" or 36 gauge.
Michael
Michael,
I believe they still use lacquer on those, Michael.   Is there a manufacturer's name available to you and/or the part number?  Might be able to get a spec sheet off the web.
Hi Mark,
This is what I have, it is old and I have no idea where I got it. I do know that i have had it for at least 40 years.
Michael
I would try soaking it in lacquer thinner and then clean with fine steelwool.  If this does not do the job repeat with acetone.
David B
  • 7 months later...
Before you get into things like lacquer thinner and paint strippers, try denatured alcohol. Back in the day, I believe a lot of that sort of coil wire was insulated with a coating of shellac and the color of the wire suggests this. If it's shellac, you're in luck. Just soak to soften and wipe off with a rag soaked in alcohol.
I usually have success with either acetone or nitrocellulose lacquer thinner. For short lenghts, I may also roll the wire between two smooth pieces of hardwood until the lacquer peels off.
  • 1 year later...
