Is there a trick or jig that I can use to get the exact center of a dowel?  Should be able to work with various sizes of dowels.
Thanks.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Machinists use several different tools for this. Look up squares in any metal working catalogs. One type is a Center Square. Another is a Combination Square. The usefulness of each type would depend on the dowel size. The Combination Square would work for all sizes, but can be a little awkward for really small dowels.
Below is a picture of a Center Square.
Ron Thibault
PROWE
If someone says something can't be done, it only means they can't do it.
Building:Shipyard - HMS Mercury card madel
Completed Builds:
Wood Models; AL Bluenose II 1989, Corel Toulonnaise 1995, Corel Flying Fish 2000, AL Scottish Maid 2005,
Sergal President 2010, Mamoli Beagle 2011, Corel Eagle 2013, Mamoli Constitution Cross-section 2014, Victory Cross-section 1/98 by Corel 2015, Occre San Francisco Cable Car 2018, Model Shipways Armed Long Boat 2021
Card Models
Christmas Train by PaperReplika 2012, Yamaha DSC11 Motorcycle 2013, Canon EOS 5D Mark II 2014, WWII Tiger I Tank by Paper-Replika 2014, Wrebbit Mercedes-Benz 500K Roadster 2014, Central Pacific no. 60 Jupiter card model 2015, Mirage III 1/30 converted to 1/33 card model 2017, TKpapercraft 1912 Mercer 2021
Thanks Prowe.  This tool is cheap enough so I will try it out.  My only concern is that I want to find the center of very small (1/32 or 1/16) dowels.
Thanks also to Thibarltron.  I will research this tool.
Ken
Completed Builds:
Tribarltron - I ordered this tool as well.  I'll see which can handle the very small dowels I'm using.
Thanks.
Ken
Completed Builds:
If you find that your dowel is too small to be used with this tool, you can insert the dowel in a tube (inner diameter tube = outer diameter of dowel).
Make sure you mark the centerline using a very fine marker (the finer the better), and rotate the dowel at least 3 times.  That way you will obtain a very small triangle which denotes the center.
Good luck
Peter
Heghlu'meH QaQ jajvam
Slainte gu mhath
L.H.
Just find something with a thickness about half the diameter of the dowel (Wood, metal, card or plastic will do).  Place it on a bench with the end of the dowel against it.  Draw a line across the end of the dowel using the guide.  Repeat, rotating the dowel about a third of a turn each time (no need to be too accurate).  You will have three lines drawn on the end of the dowel either marking the centre (if your guide was exactly half the diameter) or a small triangle that will allow you to estimate the centre quite easily and accurately enough for model work.  No need for special tools!
WOW!   Thanks guys.  I like all of these suggestions; and will try them out.
Thanks again.
Ken
Completed Builds:
