I'll look forward to seeing her in person one of these days.
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
A little more progress on the build.
Added the poop cover, rail and breast hook.
Doug
Thanks Len.  The Bluenose II is such a beautiful ship it improves the look all on its own.  I really like its lines.
Doug
Finished part 4 of John's instructions!  The modifications to the bulwarks, transom, stanchions, scuppers, taffrail, pin rails, chock rails are done.
The stem and keel pieces have been installed.
On to deck furniture and fittings.
Doug
Looking very nice.  Great work.
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
Finishing up some of the deck furniture for the next reveal.
Doug
Time to post a small update on this build.
I'm on the verge of drilling holes in the hull for the propeller shafts and I'm not happy about the prospect.  I've bee practicing on some scrap.  The problem (as I see it) is that the holes have to go in at a very shallow angle (almost parallel to the hull).  Also, since there are 2 props on this ship they need to be very symmetrically placed to look good.  I'm probably agonizing over something that will be fine but it is my ship after all!  I'd be glad to practice on yours!:)
I've adopted a very similar paint scheme for the hull as I used on the baby bluenose.
IMG_1287.jpg.0c5d6c4dc7ce26a8412e29ac431061f9.jpgIMG_1288.jpg.38a1696f839a1c72e4eabddf6e97e066.jpg
Once the props and rudder are mounted I'll fasten down the deck furniture and get on with the rigging!
Doug
Agonizing over.  I drilled the holes for the prop shafts and all seems to have worked out.
Practice piece
IMG_1306.jpg.a40b4a33b8304dc5adcf1445a0ce2c5c.jpgIMG_1308.jpg.4c30c5a64a74ef40bff863d0720268dd.jpg
Started with small bit at right angles to the surface then rotated it into the correct alignment as the hole deepened.  Then used progressively larger bits until the shaft bearing size was reached.
IMG_1310.jpg.97e77a69fcc719eacfd4d4bca094f8d9.jpgIMG_1312.jpg.8a272232418081db4423bcfa852d7feb.jpg
Dry fit the props - satisfactory!
IMG_1314.jpg.5ca200c926cfd08ff81822784c0dab7c.jpgIMG_1316.jpg.8cf8ec3b4bc7c56b618499b0715b5eee.jpgIMG_1317.jpg.6fa6540940145e9b4318837929c7148d.jpg
Now I'll make the brass supports and attach everything permanently.
Doug
It turns out the prop supports had to go through a trial by fire!
The leftmost piece was cut from a sheet of 0.005" brass.  I just needed to try out the fit of the support and how it would attache to the hull.
The middle was my attempt to bend the 1/64" (.016") kit supplied strip.  It didn't want to bend in curves all.
I annealed a wider strip of 1/64" brass, cut it in half with the Byrnes saw (with a nice zero-clearance insert and a fine blade) and discovered it bends just fine.  I drilled a pair of holes and am ready to pin it to the hull.
Doug
The final item for the bottom of the ship is the rudder.  I puzzled for a while how to mount the gudgeons and pintle in the recessed area in the rudder then onto the stern post.
I settled on slicing a groove and putting a piece of brass rod across all three gaps in the rudder.  Once it was glued down and painted over it is ready for pinning the gudgeons to the rudder and hull.
IMG_1418.jpg.c9d0785f8e44a92e3c38dce3e30d9c25.jpgIMG_1419.jpg.d8acaa2c20a3c3a86dae6b19c8c22cc9.jpgIMG_1420.jpg.06413c14eac7e0d4fd52572c6ec5f3bd.jpgIMG_1421.jpg.89585f62e688c89d8c9374c1dd827c9e.jpgIMG_1422.jpg.d60131f53ba347017e5a15a85855f824.jpg
Doug
Doug
Thanks Steve.  What do they say?  A journey of a 1000 miles starts with one step.
I've a long way to go - hope the journey continues to be as satisfying as it has so far.
Doug
15 hours ago, Heronguy said:
There's nothing like wrestling with pintels and gudgeons to drive you crazy.
Rich
geons
Nice work Doug, looking good.
Derek
Current Builds
On Deck
Finished Builds
I've been puttering on building bits of the deck furniture. I'm still following John Earl's practicum (thanks John!!).
Most fun (read challenge) so far has been the windlass (John's design is adapted from the Jenson diagrams. Here is a blog on the Bluenose II model that shows a more elaborate windlass and well as some discussion of the accuracy.)
I think I've got what I want now.  I still have to settle on the colour scheme.  I don't feel like I have much natural skill at choosing colour scheme.  On the other hand I do like the look of brass and wood.  So far then the windlass is this:
IMG_1534.jpg.f29f7daed91b93646108be47a5e1e05c.jpgIMG_1535.jpg.e8c942b2809e28c7ff93b806e9fbf97e.jpg
I've left the swiss pearwood  untouched since it was also used on the skylights.  The brass windlass barrel came with the kit.  The two drums on the outsides are made from short sections of dowel (1/4" slices sandwiching a 3/16" centre).  What I had on hand were different wood so I painted the centre grey.
The bits and priced that make it up are here.  I had trouble putting pieces together until I used the dowel to be the "backbone" on which everything was aligned and assembled.
It also was a challenge create a large enough hole in the 1/4" dowel to accept the 5/32" axle on the brass drum.  The wood likes to split when it can.
When installed I'll include the chain pipes that direct the anchor chain below deck for storage.  This appears not to be historically correct but I like brass on my model.;)
Doug
Nice work, Doug. I was happy to see some more progress! Keep up the great work!
Bulwark
(Tulsa, OK)
In Progress: 1:60 Red Dragon (Artesania Latina)
In Progress: 1:75 Bluenose II (Artesania Latina)
Completed: 1:40 Scale 1937 Sakkonet Daysailer
what a sweet looking hull you have there Doug!   very nicely done!   rudder and props look great too.........very well done,  I must say ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks guys!  I'll keep on stumbling along.  I hope to make this build my main focus for the next while.  Gotta get some sticks poking up in the air.
Doug
Hi Doug,
Just getting caught up on this build log (although I'm familiar with your PdeN.) It's coming along nicely. Fun to see the differences between the AL and Billing kits.
David
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
Hi David,
I started out just picking up 2nd hand (ie resold unbuilt) kits so the kit manufacturer was random.  Turned out  that the kits are Billings, AL, Model Shipways, Aeropicola.  I've subsequently added MariSStella to the list.  I'm contemplating making it a goal to do one from each manufacturer (not seriously, but it would be a theme!)
Doug
The fife rail and quarter bitts are be the final pieces of deck furniture I had to build.  Now I finish up painting them and then installing it all.
IMG_1598.jpg.9e2a480547e3188d5fee887ff549853a.jpgIMG_1596.jpg.9fc63945235cfb7a7bf1108399d29530.jpg
Doug
Looking good Doug.  Where do you find the majority of second hand kits?
Derek
Current Builds
On Deck
Finished Builds
Derek, I got 4 on Kijiji from 3 different sellers.  One was a "vendor" who had an estate from a modeller - thats where I for the Prince de Neufchatel and the Essex cross section.  The other 2 (Buenose II and Krabbenkutter) came from closets in Toronto.  I haven't seen much on there lately that I would have thought was a good find but I haven't been looking regularly (and I really don't need another one!)
Doug
