Pat:
Thanks. I am going to get a first coat of paint on her on Tuesday evening. That should change her appearance quite a bit. :)
Russ
Nice looking vessel.
Count me in as a bystander :-)
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
look'in good Russ  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Here she is with her first coat of white. This will need a some sanding before a second coat. Once the final white coat is on, the deck will be planked and that planking will be left with a natural finish.
Russ
Mike:
Thanks. You are so right about white paint. It shows everything and there are a few places where I see some areas that could be improved.
Russ
You were right Russ, the paint really does accentuate her lovely lines.  This will make into a superb example of your Biloxi luggers :).
cheers
Pat
The deck planking begins. The first planks are along the center line. These planks have to be right or it will spoil the appearance of the deck. I am using jigs to represent the footprints of the pilot house and hatches. This will ensure that the deck planks end snugly against the hatch coamings and the base of the pilot house. Doing it this way will allow me to have the coamings and pilot house base sit down into the deck planking, making a snug and seamless fit more likely. I could simply plank the deck and then have the coamings sit on top of the planking. However, that could lead to ugly gaps along the base of the coamings. I am hoping this will make that possibility less likely.
Russ
Lawrence:
Thanks for your kind words. I am glad to be making some progress again after the holidays and cold weather made it difficult to get anything done.
I have developed my plans from a study of tonnage admeasurements from local customs house records, contemporary newspaper articles, and contemporary photographs. It is interesting to see what can be recovered from such research. While there are numerous plans of local work boats from the east coast, there is very little to be had from here on the Gulf Coast, especially in my area. That is not to say that plan material from the Gulf does not exist; it most certainly does. However, from little corner of the Gulf Coast, there has not been much of this research done so I have been at it for the past 20 + years to try and fill that void and to add to the literature on the subject in some small way eventually.
For plans of small work boats, you can look at Chapelle's American Small Sailing Craft for some examples.
Russ
Edited by russ
Here is some progress on the deck planking. The hatches and pilot house base areas have been closed in and you can see the detail of the planking where it meest the margin plank near the bow. So far so good.
Russ
John:
Thanks. It is still a bit rough. I will scrape it smooth once the entire deck is planked.
Russ
Nice progress Russ, the planking is looking good; I like the colour/tone of the wood you are using.
cheers
Pat
Pat:
Thanks. It is basswood strip from Bluejacket Shipcrafters. Very clear, nicely milled stock. I am trying to alternate here and there, using different strips at random to get some variation in the deck.
Russ
Carl:
Thanks. I simply rubbed a number 2 pencil along one edge of each plank and one one end as well. One smaller scales I have used this before and gotten good results. Once the deck is scraped down, it should have a good scale appearance.
Russ
Carl:
I had thought about using a grey pencil, but I do not have one handy, so I went what I had. On a larger scale, I would take a sheet of basswood as thick as the planks are wide and paint one side of it grey. Then I would set up the table saw to rip planks off the edge of the sheet so each plank would have one edge of the plank plain and the other edge grey. That works really well.
Russ
Nice to know!
I've seen someone stacking the planks, and glue (semi)dark gray paper to the side of the stack and slice them of the stack. I think the sanding might pose a problem with the paper ...
Carl
Carl:
I recall that method. I read about it in Underhill I think, although I believe he was mentioning what Longridge had done on his Cutty Sark model. I have not used it though.
Russ
nice progress Russ......the planking looks very nice.   I like to do the same pertaining to structures.   I'm not a big fan of the separation gaps either  ;)    the hull is looking real sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
