HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
There was a little progress today. The planking is proceeding and, although it has not been sanded and is a little rough, it is getting there.
Russ
That will sand back nicely Russ as the planks appear to butt up very nice and cleanly.
cheers
Pat
Some more progress. I have done some sanding on the port side planking to see what I had and, while there are some areas I am not happy with, it is not too bad.
Russ
Had some more time for a few more planks. What can I say? I am having fun. :)
The ports ide has two more full strakes and parts of two other strakes left to go. Then back to the starboard side.
Russ
John:
Thanks for looking in.
I am taking pics mostly to get an idea of how the planking lines are shaping up and to check for any other issues. There are a few things that bug me, but that is pretty normal. Anyway, the camera can sometimes pick something up that my eyes do not.
Before I forget (again), thanks to everyone for the likes. :)
Russ
You can heat up the tar, caulking time is nearing ... your hull is becoming a thing of beauty, Russ ... you are certain you won't leave her unpainted?
Carl
Carl:
Many thanks for your kind words.
The hull will be painted. This is a commission and the model is being made to look like the real boat as much as possible.
Russ
I could not help myself. The planking near the port bow is complete and there are only a few planks left to complete the entire port side. I always like how the run of the planking appears in the forward areas. Just had to share. :)
Russ
Can't blame you for wanting to share this Russ, the lines of these schooners are very lovely indeed and your planking sets this model off nicely.
cheers
Pat
Pat:
Thanks. These luggers were really nice looking boats. The plumb stem made the lines forward that much more pleasing because it created a bit of hollow down near the forefoot. This is a later boat that was a bit longer and deeper for its breadth than some of the smaller, earlier boats from the 1930s.
Russ
Planking progress on the starboard side. This is still rough, with no sanding yet on the latest planked sections.
Russ
looking really nice Russ! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
The starboard planking is complete below the bulwarks. Some sanding has been done, but there will probably be a bit more here and there. Three more planks on the port side and I will be ready to plank the bulwarks.
Russ
Pat:
Thanks. I appreciate it. The planking looks pretty good to my eye, but it is good to know that it looks good to others too. I find that I can get a bit too close to the work and I lose some objectivity. :)
I just have to remember that there is always room for improvement.
Russ
