quite a ship...no doubt about it!  off to a very good start Kevin...fun project to follow along ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Caught up with your progress Kevin. She's beginning to look like a ship. Nice work.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Stage 3 building the after superstructure in Plasticard
I purchased A4 and A5 sheets of card from Amazon/Ebay in 0.5mm, 0.75mm and 1mm
made a better light box by using a sheet of glass placed over a lamp
over the plans I layed a thin sheet of plastic and traced the plan lines onto it, this then also act as a floor
I managed to obtain a few photos of the hanger internal details, as i want to display it with the hanger door open, i may also go for a few other bulkhead door to be open as i proceed so i am having to think ahead, plus i am having to think about where the wiring for the radars and lights be be going
i actually spent a bit to much time playing with the hanger, she has an office and oil store opposite the hanger doors with sliding doors so i have tried to  create this, but still needs a lot of work to pass the rivet counters, from there it was quite easy to continue with the rest of the after superstructure at main deck level
Edited by Kevin
Amazing work she is coming along superbly.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Did you see this guys build
what he did with re building Warspite at such large scale is amazing.
OC.
Current builds
Completed works.
such a nice start on the superstructure...looks really good !
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Good evening everyone, just mended my PC by putting a new power supply in, so i can make a post tonight
not happy with my first attempt at the superstructure in Plasticard, so last weekend i started again, it is going together much better this time, the problem i am finding is that the plans, for the cost are well poor, i have found lots of mistakes, but the worst part is that some of the lines are as thick as the plastic i am using, so having to be very careful each each cut could be at least 1MM out
also references are not as plentiful as anticipated, on the forward end of the hanger by the doors there are lots of air vents/exhausts, and at present i am unable to work out haw the fit
thoroughly enjoying this,
Stbd side aft this is where the replenishment at sea rig (RAS) was fitted, but removed at some point around 1980
the offices located in the hanger are to tall, so will have to be adapted/replaced
aft of the hanger the RAS rig is the pillar on the right
this was created as one piece on the two previous attempts, worked out much better as a seperate module
the basics of the after mast has now been made, it is hollow too allow for a motor and wiring
as off last night
IMG_1375.thumb.JPG.14fe50f064a0fea17b9cedc9abe9903b.JPGIMG_1378.thumb.JPG.a59a6520304a92d2db673c27c306dc6d.JPG
Edited by Kevin
Hope i am not offending people, im just trying to show certain areas where i am currently working
Nice progress Kevin, glad your retry is working out better. Please, no apology required on my part. This clarifies where you are in the build.
Cheers,
                       VOC Ship Surabaya
comparing the picture above with this one,  it appears that the hangars are too far back.   they should be flush with the aft section of the structure,  and appear more boxy.   is there a port side outer wall that you haven't added yet?   no offence either......always good to know where you are with your project.   it is from that picture though,  that I see this.......perhaps something you haven't though of yet
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
good evening popeye
thank you for pointing the out of sequence photo,
the hanger door has still to be made and i have added a photo of version 1 (in card) and version 2 which is being remade
Popeye
this is not my build, but hoping to show you the basic shape from aft you have the radar complex then the hanger which opens out before the after funnel
Kevin - are they Jecobin plans? I built a type 22 to their plans but supplemented them with a lot of photographs.
I built the superstructure from 1/32 thick plywood - it has a deal more stiffness than plasticard.  Here's my type 22 for interest.
I'm enjoying your build, its coming along well.
DSC01148.thumb.JPG.84a2648c5f352229f3d862ee881ea51c.JPGDSC01144.thumb.JPG.5235769744b78017b9a377b5472be364.JPG
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Lovely work keith, have i seen this build on the Fleetscale forum?
Kevin - its my age, I of course meant type 22. I have never used fleet scale plans but I did find Jecobin to be generally fine. Not sure why it would be on the fleet scale forum - but anything seems possible in this virtual world.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Sorry Keith I presumed it was a fleetscale hull, they have a lot of builds on their own forum, I am using Jecobin plans,
Kevin - you can see more detail of my type 22 here - you may have to join to see it. http://modelwarshipsuk.informe.com/forum/post41038.html?hilit=hms cornwall#p41038
Modelwarshipuk is a pretty good site for Royal Navy warships.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
lol I knew I had seen it before - just the wrong forum Thank you
yup.....that's what I figured Kevin........the first progress picture was what I was thinking of ;)    you hadn't made that port side wall yet.  I didn't want to comment...but my curiosity got the best of me.   that will make for some really neat detail inside. :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
looks like there will be a bit of artist licence in the detailing but I have managed to source these few snaps
Wow she's a Biggie Kevin - makes my 1.3m Bismarck look tiny :D. I'll be following this build with a lot of interest.
:cheers:  Danny
Cheers, Danny
amazing how they can get the helo in and out of there ;)   you've shown two possible ways to detail it out......either way,  there's a lot to the interior.   my son found me a 1:400 Heller kit of the Jeanne D'Arc.   the kit comes with four Helicopters.   have you found any helicopter kits that will fit the scale of your vessel?   lots of ducting,  the shelf/rack at the fore end and the rotor rack above.   the model pictures look great.......but they forgot the no smoking sign :D
you have your work cut out for you ;) .....I'm sure you'll do a stunning job of it!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
one of the reasons for picking the 1/72 version over the smaller 1/96 was the availability of the wessex HAS3 Falklands Helo
http://www.britmodeller.com/forums/index.php?/topic/234983812-westland-wessex-has3-falklands-war-172-italeri/
cool looking helo.......what year are you planning on the Fife?    back in 1987 the flight deck was enlarged so it could carry two helos.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye she was heavenly converted after being sold to Chile and renamed
The Royal navys idea of the side entry hanger, was quite silly, and the conversion allowed her two helo, it was the Seaslug system that dictated the design this had become very outdated very fast
the top photo is how she was when i served on her with the Exocet system fitted where B turret used to be
before
Edited by Kevin
the hanger idea did not work for me, when the door is cut the whole superstructure became to flexible, so back to the drawing board
the solution I came up with was to make an internal hanger to fit inside the main body
IMG_1416.thumb.JPG.b4f36642c7232ce7f2d165c619a40116.JPGIMG_1417.thumb.JPG.fc7c40775f3a8e39048f9fef2c763a36.JPG
this has firm everything up and it is removable
helicopter arrived
the office has been remade (3rd or 4th time) most likely the 10th
just one door and put a desk inside not that you will ever see it
IMG_1419.thumb.JPG.49b16755e746246b34dc6c146cd5bace.JPGIMG_1420.thumb.JPG.618463c2324f65c851942f0e12aaba42.JPGIMG_1422.thumb.JPG.91b0e9258791ec5ab8116a27ffbc0277.JPGIMG_1418.thumb.JPG.9f3aac842c885d85628035d02103241c.JPG
IMG_1423.thumb.JPG.f09b8ed04ad19a20eaf75feddaac2914.JPGIMG_1427.thumb.JPG.ceb3f3ed084b7e30f8d323e36176bbfd.JPG
and then put a platform in, to see if it looks in scale i taped some of the helo together
today i detailed a few bits, very much artistic licence, but if the rivet counters want to pick me up, LOL it means they have a photo, that being the case I will  change it
IMG_1432.thumb.JPG.cbcc8f9da504698ff6d4e5a2d9d8f2bd.JPGIMG_1434.thumb.JPG.9a9d9222c6d4f10fc456cc6590b3e1f1.JPGIMG_1435.thumb.JPG.1c8942250a2a8dd6b433a732454873b7.JPGIMG_1436.thumb.JPG.4d277a12501499a1f832e2a9ef986f4e.JPGIMG_1438.thumb.JPG.bc3bf4d30ef42a3797b242636f4bdc24.JPG
Great work Kevin. I like the the way you are trying things out ... nice take on the "insert" hanger.
Carl
