Super nice looking launcher Kevin.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
models have come a long way........all resin?!?!   the launcher looks a lot better now that it'a painted :)   nice added deck detail.......is the deck to be painted or planked?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
it is steel, but i have a lot of non slip strips to but on, doing it in evergreen (other makes of plastic strip are available from good model shops and the internet)
like in this photo from the pointy end of the same class of ship
The other bits will go on much later as i still have to make winches lockers etc
NOT MY PHOTO
21617787_10215194664368549_1193768294907254000_n.thumb.jpg.d168c6c4949a59b0d62c31aaa2497ec6.jpg
still can't get over the white anchor chain........wouldn't expect it,  considering it's function.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
At a quess i would say that the sea training staff were riding and if it moved it was hidden, if rigid then it was painted
I think whites chains go back to ww2  if not ww1  certainly on my warspite they are white.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Good evening everyone, are you sitting comfortably? i want to tell you a story......
once upon a time, well the last couple of days
made a full top for the after smoke stack
[W5mfNF8]
[59FSkJ2]
[f04nmJi]
been sanding and cleaning joints for quite a while now and decided to give the superstructure a base coat, to see what needs to have more attention paid to it
[wsL7N9t]
the other reason for this is that there are now bits that need to be added, like platforms etc and so i knew everywhere pior to that point  will have had a least one coat of primer
the hanger roof needed to have to extension added, simple enough
[6932JWh]
but they never reached the sides as if they were to small, infact what this did was bring to light a mistake of my making when I made the superstructure out of MDF
this is when I should have spotted the error
[JZln3Wh]
this what i ended up with, although i never took a photo at the time i have cut a section out to the correct size
[wcJtyiA]
this is where the error occured, this plaform is in the correct position, but i had to cut some of it off to sit flush and the correct width from the superstructure
[EVKrBbG]
where the arrows are is where the mistake was made, the dotted lines are below the platform (and not ignored by me),  this is the amount of hull i had to cut out and the amount off platform that had to be removed
[FOt4vmW]
this is the only photo i can find to show you what i mean (just above the red vent) it is flush with the hanger roof extention
[RnscNDT]
this is the state of play until this friday
[JJPSyQw]
Great work kev,  isn't she looking super, the grey primer  really blends it all together.
OC.
Current builds
Completed works.
Smoke stack looks great and even a minor setback is progress. You'll get there Kevin.
Cheers,
                       VOC Ship Surabaya
the fact that you caught it this early,  means that the fix won't be too big a job.   scratch building at it's finest ;)   you'll straighten it out in fine shape!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I have an update
it took a bit longer than anticipated, but im happy with it so far
we left her in a bit of a sad state last weekend, when I realised that i had not read the plans properly, and as a result never took the superstructure in at the right place
[JJPSyQw]
new infills panels
[FB9RdLR]
[QVURQiq]
and new templates for the platforms made
[JbWFu5A]
the hanger roof is still removeable
[OoTr5W3]
[UJxHsLK]
another primer coat to find bits thet require more work, LOL (lots of that)
[UJxHsLK]
[sUcolM3]
[5PPdPGq]
Wow Kevin, nice work on that fix.
Cheers,
                       VOC Ship Surabaya
Very nice indeed   she is really coming on and looking superb,  keep up the momentum kev  you are creating a real  superb piece of art.
OC.
Current builds
Completed works.
been doing some detail work, with the help of a bit of artistic licence, this is the end panel on the flight deck
Looking great.
OC.
Current builds
Completed works.
Nice doors Kevin, did you make them?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
THE doors came from Fleetscale, I need about another 10 to go on the after superstructure
came out great Kevin :)    very nice fix!   imagine how she'll look when you have done it all over the structures........sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
what have i done this weekend
Well i taught myself how to solder, (very badly though), but i am sure i can get better
i wanted to sort the lighting out in the hanger
so i used two brass strips as the connections and proceeded to attach the positive and negitives to seperate sides but with that came a load of failures, did some damage to parts i wasn't working on but nothing is lost and can be replaced, 3mm Leds for the white lighting and led strips for the red, both have there own power source and are both remote control
this was a failure as i had to much wire  and to many were crossing each other, so as a result the hanger roof didnt fit
reverse side before a tidy up
red lighting not so in your face
Love the lighting  really adds to the build.
OC.
Current builds
Completed works.
Nice work on the lights, Kevin.  I like the effect of white for day and red for night.
far to bright but i can reduce that brightness down to 25%, and make it do all sorts of other things that RN warships are not known for doing
Incredible detail on that hangar roof Kevin and I figured that the lights could be manipulated. Very nice effect.
Cheers,
                       VOC Ship Surabaya
I wonder if a dimmer switch can be added to the circuit.  without some sort of regulator,  the lights will be at full power,  depending on the power supply you decide to use.   it's a very nice effect you've achieved  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Sorry i never made my original post very clear, the lights are remote control but also adjustable , the phots show them at 100% but are dimable to  off, plus different sequences, non of which are used much by the Royal navy in their lighting configurations, i might try a video this weekend to show how it works, although im not sure that this site allows it, but could YouTube it
Edited by Kevin
Good evening everyone, and another little update, and another apology for not catching up on others work,
still continuing on the after superstructure
all doors in place at deck level
hanger door in folded position are made but not yet secured
vents in the process of being scratched
the smaller ones around the hanger door pillar, were bought from Modelling timbers, and 4 of the 12 are fitted
hanger doors, i made the required then put spacers inbetween to give the desired look, not 100% sure how i will fit then yet
[mp3mRi8]
[R7NCgjj]
[fxiPMuk]
I need to make quite a lot of vents, im fine with the big ones, and practice is making me better at it
[0sM9nxQ]
[KtGvnaQ]
[IBWgmXG]
[pZsnV0j]
[G7yxqJq]
[1icjSil]
the lower one will not be seen very much, so of the three i made today, this one was not 100% to my liking and will go there for now
[MNQWExK]
[x4BpVkS]
[aLQ8Zai]
tonight she looks quite a lot like this
Looking really nice kev  great work.
OC.
Current builds
Completed works.
Those vents and doors look pretty convincing Kevin. Great job!
Cheers,
                       VOC Ship Surabaya
the more you add,  the better she looks!  :)    I agree....the vents look great.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
NOT MT PHOTO
from the angle of my last photo, i managed to find this
