So I have decided to throw my hat into the ring with my next project.  It was a toss up between this and the Longboat.  I decided on this one as I was able to obtain a Longboat replacement wood package in pear (from Crown Timberyard prior to their "maintenance").  I wanted to save that for when I have a bit more skill.  It was pretty interesting to learn that there are not too many builds of this kit here on MSW.  Blue Ensign, Tigersteve, Mike Y and MikeB4 and a few others are about it.  For tonight its going to be inventory desk clean up and sanding char.... Yuk!  Although there is remarkable little on this well made kit.  Hopefully it won't take 4 years like the last build.  :D
Thanks Steve.  I haven't started a regular kit in a very long time so we will see how it goes.  I always forget how much I hate laser char.
Also test fitting the rabbit...
Basswood is kinda fuzzy eh?
Was able to get the frames glued in.  It went pretty slow but the overall run is really nice.  I used a small level to make sure they were not tilted to the side.
This weekend hopefully will get the strengthening battens in as well as the bow filler piece and maybe, just maybe the first strake.
This thing is so flimsy without the reinforcements.  It feels much sturdier now and when I start fairing the frames I am going to feel much better having these things in place.
Well I guess I am not as gentle as I thought I was.  I knocked the tip off of one of the frames while I was fairing it.  I was wondering if I should try to shape a small (very small) replacement or will it be fine after planking?
Looks like you need to find the piece and glue it back, if you can. Otherwise, yes, a replacement. You need a solid 'landing' for the planks later. Be extremely light on those cross-grain areas!
Nice build! Hope you will have more luck with thin planking strips included in the kit, it is actually easier to build with a boxwood package - thicker strips that bend more evenly with more margin for fairing.
Very light touch indeed.  I wasn't even going across the frames but along them.  This wood is crazy soft.  I looked for the piece but I think I will have to just remake the tip from the scrap.
We will see about the kit provided wood.  I do have a nice pear replacement package for the Longboat but wanted to try to see what I could do "out of the box" on this one.  Hopefully skilling up a bit before I move on to that one.
4 hours ago, Tigersteve said:
It looks like both frames need treatment.
Steve
The one on the left is just about the right size (maybe just a touch short).  The other non-faired side is about the same hight.
Enjoying following along on this Pinnace build...
I had been thinking of picking up a Model Shipways longboat kit and pinnace kit just to use the drawings and then the kit laser wood as patterns.
I’m going to use castello, buxus, holly and pear for my builds as much as possible.  I moved away from basswood for model building a few years ago as I find it not strong enough for my tastes...
Cherry and maple have been my garden railroading woods of choice, for shipbuilding these perhaps have too much grain for 1:48 or smaller scales.
Cliff Ward
Cary, North Carolina
USA
Thanks Cliff.  Cherry seems nice as that is what my Halifax was made out of not sure about maple though.  This bass wood is really soft and it seems to fall apart with almost no rhyme or reason.  I have some pear and it really seems nice.
I squared off the broken tips and added a small filler piece.  You can still see the joints but it is very smooth to the touch. With a few test fittings, the planks seem to run very nicely.
  • 10 months later...
Work finally easing up a bit.  We went through a massive expansion basically doubling our size over the course of a few months. Back in the shipyard more soon. Here first attempt to start the planking.
More fuzzy basswood.  Camera picks up all the fuzz and dents.
Great to see you back Michael - Pinnace looks great! Looking forward to seeing the progress.
Dave
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
Your Pinnace is looking good.  Glad to see you back in the shipyard.  It was also great seeing you in Las Vegas at the NRG Conference.  I know you learned a lot of new modeling techniques that you will use in building your Pinnace.
Ryland
               - Nautical Research Guild
Thanks Dave and thank you Ryland. The conference was great and as always it’s a motivator and inspiration to get back in the shipyard. Next up is the garboard plank which seems to have given others quite a bit of “learning experience“.
Garboard and first lower planks are in.
With just about 20-30 sec of soak in water and careful clamping and drying with heat gun you can get a fairly good bend even with basswood.
gotta be careful though this thing will definitely burn the wood not to mention human flesh...
seems symmetrical maybe a bit of gap but not enough to worry about. will be sanding/filling as needed
bow view on the camera makes it look like the starboard side is higher/further but irl its almost exactly even
Michael - looks great!  looks like the garboard strake is perfect, you have great symmetry, and the run of the planks will be spot on.
