Hi David ,
Welcome back !
If it works for you to drone the nails into the wood, then it is ok.
Great tip from Augie !
It looks funny when you are finishing the hull and there are a few clothespins left  :D  :D
And take your time with reading all those logs….See you in a few months  :P
Glad you are all settled in David, and the clamps are quite ingeious...vaseline should work as Augie suggested, but I wonder if the oils might discolor the wood in any way???? I guess I would just suggest wiping away excess glue with a damp cloth and then there shouldn't be a problem.....
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Ok so I thought I would show my new work area (even though its pretty similar to the old one lol)
And I was thinking one wall hunter green (the one I face) and the others a lighter either sea pearl or perhaps sage)
Just keeping everyone updated lol not relevant but that does not matter lol :) :) :)
David     :pirate41:
First Build: Corsair Brigantine
David,
Silly question but…..do they have not bigger tables for sale????????? :D  :D  :D  :D
I thought that everything in the USA is bigger !
Nice workspace and so clean……..
How long can you keep it this way?
Thanks again all. And while I was successful (I think ) in getting a few planks on today.........y'all sure made it more difficult on me by not using nails..........but I think I got will let you know tomorrow when I see if it dried right. :) :) :)
David     :pirate41:
Glad the move went well David, ship looks like it is right back on track!!
And I agree the clothespins solution is quite ingenious, nice!!!!
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Ok here it is before I removed the modified clothespinspost-3113-0-15905300-1377897703_thumb.jpg
And here after I removed everything
So it seems to have worked out and no more nails will be used however, I do seem so have asymmetric lines so will wood filling and sanding get both sides to look similar? I think I like the gradual bend( on the left side of the last picture) better so will try to get the other side to match after finishing the first plank layer.
David     :pirate41:
As this is a first planking, do what you can filler/sanding wise to even things out.  Just use care with the sanding ---it's pretty easy to go right through the planking at the higher spots if you get too 'enthusiastic'.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Planking is looking good, David  :)
I would echo Augie's excellent advice, some filler and careful sanding should take care of any bumps.
May I also suggest some additional fairing of the remaining portion of the 3rd bulkhead? This should allow the planks in that area to have a smoother curve.
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
I agree with Augie and Aldo. That 3rd bulkhead seems to be a bit high and is causing a peak in the contour as she rounds in toward the stem, which appears to be worsening towards the keel. I had one side of my Swift build that had a similar problem. Sanding and filler can make a big difference, before you second plank. That overhead photo really shows the contour of the planking and other then the 3rd bulkhead the rest of her looks perfect.
I found that in many ways the fairing process is as important, if not more so, then the planking and fairing and shimming can be done while planking as Aldo suggests. The main thing is, are you having FUN, If so then you doing it right.
Keep on Planking
Thanks for the advice I have some filler but waiting till I finish the first layer so I can get the symmetry as best I can. It's actually something to plan a bit when soaking the planks for an hour beforehand lol :) :) :)
David     :pirate41:
filler does wonders for creating the contour you want, so don't sweat it, it will come out in the end.
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
I'm lying sideways on my desk to get a full appreciation.  Offhand, I'd say you have a better eye for nautical stuff and should bag the idea of being a window treatment consultant :D  :P  :D
Augie
Previous Builds :
Hi David, this is looking good for a first build. A late welcoome to this forum and all the help it will provide. I too am into my first wood build and if it wasn't for the gang here I probably wouldn't have even attempted it, much less be as far as I am into my build now. It's a great group, enjoy.....
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Oh darn Augie I thought I had some real talent lol....actually I tear more curtains down at fires then worry about what they match to lol
Welcome to my little dock John, the people here have treated me very well and I have some pictures coming tomorrow...
I got a good part of the first layer of planks down so its on to fill and sand.......I may wait to sand until the weather cools off a tad :) :) :)
David     :pirate41:
Ok some pictures of the first layer of planks.....keep in mind I have to fill and sand still.....post-3113-0-23582800-1378929037_thumb.jpg
post-3113-0-03041100-1378929087_thumb.jpgpost-3113-0-82019600-1378929141_thumb.jpgpost-3113-0-61659400-1378929189_thumb.jpgpost-3113-0-17097200-1378929241_thumb.jpgpost-3113-0-44025400-1378929270_thumb.jpgpost-3113-0-42623500-1378929294_thumb.jpg
Ok here's where I ask for more advice.............
Per instructions I am supposed to apply the keel( little piece of wood on bottom of ship) after the second planking is done. I am wondering if logically I should apply the keel then my second plank layers can line right up to it, instead of any gaps that could arise.
Any comments, advice, even rude remarks would be welcome :) :) :) Thanks
David     :pirate41:
Your reasoning on the keel sounds good David.  But I'm no expert on double planking so wait a bit for a confirmation from one of our folks.
Augie
Previous Builds :
David, I did mine per the instructions and added the keep after the 2nd planking....I wish in hindsight I had added it first...as much as you try, without tht little strip of wood to butt up against you will have a gap you have to fill otherwise.
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
Actually David, if you check my log you can see how I attached the stem/keel/sternpost before second planking and then using an exacto and formed a small psuedo-rabbet along the keel line which was used to fit the second planking. This gave a nice tight bearding line and I was very happy with the results.
Looks like you have a bunch of sanding ahead.
David after a good sanding it will look good again :)
i see the first planking as training . on my Endeavour i will try and make it look like it should but if not the woodfiller will come out too :)
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
