Thanks Dick.
Michael
Wouldn't it be easier with the frame support still attached to finish the "ribbons", Dick
Carl
Carl, I have removed the support for the moment so I can properly fair up the floors under the vessel. I may put it back on later but the temporary wale around the top timbers seems to provide good stiffness. The stem and sternposts are not yet fixed to the keel. This allows access to the inside of the hull for fairing. I am learning as I go but, so far, so good.
Dick
Current build:
 Le Gros Ventre 1:48 POF   http://modelshipworld.com/index.php?/topic/564-le-gros-ventre-by-woodrat-scale-1-48-pof-1767-french-exploration-vessel/
Past builds:
Mycenaean War Galley by Woodrat - 1:48 - Shell first Plank on Frame:https://modelshipworld.com/topic/33384-mycenaean-war-galley-by-woodrat-148-shell-first-plank-on-frame
Venetian round ship 14th century by Woodrat fully framed - 1:40 scalCompleted
https://modelshipworld.com/index.php?/topic/17991-venetian-round-ship-14th-century-by-woodrat-fully-framed-140-scale
Venetian Carrack or Cocha 1/64 by woodrat   https://modelshipworld.com/index.php?/topic/4915-venetian-carrack-or-cocha-164-by-woodrat        completed
United States Frigate Essex 1:64 POF   http://modelshipworld.com/index.php?/topic/4496-usf-essex-by-woodrat-scale-1-64-fully-framed-from-takakjian-plans/ - completed
Yenikapi12 by Woodrat - 1/16 scale - a small Byzantine merchant vessel of the 9th century
https://modelshipworld.com/topic/23815-yenikapi12-by-woodrat-116-scale-a-small-byzantine-merchant-vessel-of-the-9th-century-finished/
The Incredible Hulc by Woodrat - an experimental reconstruction of a mediaeval transport
https://modelshipworld.com/topic/25641-the-elusive-hulc-by-woodrat-finished-a-speculative-reconstruction-of-a-mediaeval-merchantman-132-plank-on-frame/
The hull is removed from the building board while it is faired. Applying the garboard strake and ribbands is straightforward. Then it wil go back on the board.
Dick
Current build:
Past builds:
Thanks, Steven.
I have faired the hull and installed internal stringers and clamps.The larger wales are positioned where the floors overlap the futtocks at the bend of the bilge as well as where the futtock overlaps the top timber at max breadth. I haven't finished pinning the wales. No trenails were used on the Contarini 1, only nails.
I have put the hull back into the building frame so I can apply the ribbands for bow and stern.
Cheers
Dick
Current build:
Past builds:
Interesting way to go, Dick, doing the main framing and then adding stem and sternposts. Was there a particular reason for this?
BTW, are you using nails for fixing? I take it they're just temporary - what are you replacing them with?
Steven
PS: Nice precise work.
Steven
Only nails are being used as this was how the original was built. No trenails were used according to the relazione of the excavation. I have not connected the stem and stern posts. I will do this after the bow and stern framing is completed and faired. I used this method for my Essex and Gros Ventre builds.
Dick
Current build:
Past builds:
Thanks for the info, Dick. Is there any particular advantage to leaving stem and sternpost till after the bow and stern framing is done and faired?
Steven
Beautiful work
Somewhere I have read that in warm waters mostly iron nails were used. Because the wooden treenails were eaten too quickly by woodworm.
found it. Source : Joao Baptista Lavanha, who died in 1620
Edited by Backer
update
Steven, just ease of access for the Dremel. You could join the posts up now. The strength is largely in the wales rather than the attachment of the keel to the posts. I need the frames in place before I can extend the wales to the posts. There were no cant frames in this vessel and the bow and stern frames were curved floors placed along the curve of the posts and reinforced with vertical futtocks. I believe there must have been some vertical bow timbers to reinforce the hawse holes but these were not preserved in Contarina 1
Thanks, Patrick for the info on iron nails. What was the book? Steffy?
Cheers
Dick
Current build:
Past builds:
The first two bow frames are in. Not quite perfect but I think I have the hang of it. Although there are no actual cant frames as we usually understand them, it seems inevitable that some frame rotation or canting creeps in. Note how the floor timbers are now tilted to match the curve of stempost. the curve of floors and futtocks is the same as for the rest of the ship.
DSCN1614a.jpg.12914dcea6d671c5a6f4e5e159655220.jpgDSCN1614a.jpg.12914dcea6d671c5a6f4e5e159655220.jpg
DSCN1613a.jpg.574eb50dd0ca9e7d22cde8005a1484d3.jpgDSCN1613a.jpg.574eb50dd0ca9e7d22cde8005a1484d3.jpg
DSCN1615a.thumb.jpg.588b14f269fca6f59465056d65d5e1f3.jpgDSCN1615a.thumb.jpg.588b14f269fca6f59465056d65d5e1f3.jpg
Cheers
Dick
Current build:
Past builds:
so true druxey. Dick, I wonder how you will make things fit ...
Carl
11 hours ago, druxey said:
Interesting method of construction, Dick.
So do I. The venetians managed it.  Unfortunately not all of the bow survived so some extrapolation will be needed.
Dick
Current build:
Past builds:
I was able to complete the framing of the bow section. The tilted floors from the wreck were reproduced. The timbers above this level in the Contarina 1 wreck did not survive and have been guessed at. You will note that canted frames became necessary and seem to work. Breasthooks and deck clamps applied.
Dick
Edited by woodrat
Current build:
Past builds:
Another piece of "learning by doing" - probably the only possible way to construct the bow framing; hard to predict in theory, but the obvious road to travel when doing it in practice.
Steven
  • 5 weeks later...
Chaps, I have completed the framing of the stern and used a slightly different technique. It was quite difficult. Fairing of the frames and pinning was made easier by keeping the stern separate from the main hull. I will now attach the stern module.
Making the tilt floors
15 deg. angle
then angle to match that of the futtock
Tilt floors fixed in place
Stern uprights in place
stern detached and fairing up commences
Fairing done and breasthooks in place
cheers
Dick
Edited by woodrat
Current build:
Past builds:
Thanks Carl and Steven. The hull framing is complete and awaiting fairing so I can fix the wales.  Overall the framing of the bow and stern is fairly consistent with the Contarina find. I am presently researching the quarter rudders and have decided to make a swing mount. This allowed the rudder to be swung up and secured when not in use and allowed easy removal and replacement of the rudders ( in some mediaeval ports it was a requirement on anchoring or docking to remove the rudders so the master couldn't  do a quick scarper and avoid paying the port fees).
Cheers
Dick
DSCN1641a.thumb.jpg.52d54f56c97844177e78228149b0700a.jpgDSCN1642a.jpg.4c5f1b9df8515513b25e9f1997c7e9f0.jpgDSCN1643a.jpg.bbd13b2206361f4320207e3e4abb3a71.jpgDSCN1644a.jpg.a83dec0b36c2be6dbbae37205fd0da43.jpgDSCN1645a.jpg.1dd06a17d4e1b465f56f1e222cb65bb1.jpg
Current build:
Past builds:
The wales have been attached. I have inserted the main throughbeam in the stern. This a major structural element as the quarter rudder applies its turning moment through this beam. Pilgrims in round ships have described how, travelling in steerage, they could feel every movement of and twist of the ship when they leant against the throughbeam.
Cheers
Dick
Edited by woodrat
Current build:
Past builds:
Beautiful work, Dick. The hull has really taken shape well.
Regarding the side rudder, I take it you already have the TAMU paper on the development of rudders/steering oars?
Steven
Thanks Steven and Druxey and everyone for the likes
Yes Steven I have read Lawrence Mott's definitive treatise on the Development of the Rudder. I use this plus some of my own interpretation of the iconography. In addition, new information from the Black Sea wrecks will be used to reconstruct a usable swing system for the quarter rudder.
Cheers
Dick
Current build:
Past builds:
This is my plank bending jig. Planks are soaked for 24 - 48 hours. No steaming.dscn1653a.jpg.c0dc58b6c36a79cf42e735bf06a87b9a.jpg
the framing of poop. The stern deck framing is underneath the poop. Note the pillars with the red balls. This will become the shelter for the steersman.
Making the external supports for the poop. This can be used to make complex curves. 0.5 mm planks are glued and clamped and allowed to set overnight. It saves a lot of carving.
sorry about the soft focus
DSCN1660a.jpg.2ccc90c20e3d6d0f3a320b6cf491fcc6.jpg  DSCN1661a.jpg.1216490753f607b9b0e8b26bb4fb364b.jpg
I will show the swing mount for the quarter rudder in the next installment
Cheers
Dick
Current build:
Past builds:
This in my concept of the swing mount used to attach the quarter rudders. The rudders had to be removed and given to the port authorities as a safeguard against sneaking out without paying port fees. So the rudders ahd to be easy to remount. Also, loss of a rudder was not uncommon at sea and mounting a new rudder had to be straightforward. (and a sight easier than remounting a stern post rudder. The quarter rudder had to be able to swing horizontally out of the way in shallow water to prevent damage. Also the weather rudder could be withdrawn if the ship was heeling. The ship was steered then by the lee rudder. There were many different variants of swing mounts. Here is a contemporary illustration showing a swing mount.storm20.thumb.jpg.498278468d58ec27654a267ea3c24fb6.jpg
This how it is on my ship:
This the rudder rotated up ( this would be done by a rudder hoist) and would be even more horizontal when fully raised.
Dick
Current build:
Past builds:
