HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
11 minutes ago, cog said:
is that the UK version of the TGV???
TGV  - train?
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Count me in on this OC from here in, interesting to see how this comes together and how you approach the painting.  Nicely done so far.
Cheers,
Jason
In the shipyard:
Thanks jason welcome aboard.
OC.
Current builds
Completed works.
Nice job OC she is already taking on some character. She is no longer a cigar tube with aspirations of becoming a Sardine can. :(:P
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thanks lou,   I thought the same  as subs do tend to be slightly detail shy,   she has a few bits and pieces to go on her yet.
OC.
Current builds
Completed works.
I agree
Back in the day my favorite nuke sub was the Skipjack, and the only kit available was the old Aurora kit that left much to be desired as far as detail goes. That was no excuse I suppose, as I also have plans for the Skipjack that showed details that were not on the kit but could have been etched in. At any rate, my Skipjack ended up as a black teardrop with fins. The prop was really the only break in color!
You might also see if you can find pictures of the deck and see if like US subs these subs have the "Target" ring painted around the rescue hatches. Only a little bit of color but everything helps. Also it looks like the Radar mast is painted white in all the pictures where it is raised.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
A little more progress  just picking out some deck details with my brush(its easier to do this while the hull is still in two halves)    as Lou said  its brings the details out on what would be just a cigar.
OC.
Current builds
Completed works.
S Class (this is Sceptre) i have some more if you want to see some external detail
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks kevin,  wonder if that is red oxide paint they paint where the tiles are missing - cant imagine it being rust,   also what are this  two zig zag panels where there are no tiles  on Trafalgar.
OC.
Current builds
Completed works.
No reason why not OC. The tiles are most likely glued directly to the bare metal and if they get knocked off like in this picture the exposed area would rust pretty fast. There are also some signs of rust showing along the seams of some other panels further back. Possibly that is the reason the panels fall off. Water seeps behind the panels and lifts them off. I suspect that there is considerable flex in the hull between deep dives and the surface and the tiles expand and contract at a different rate than the hull.
Some other areas of note is that the circle marker for the escape hatch is green rather than red or yellow, and that the bollard the guy in sitting on is yellow on top rather than black. I am assuming that this bollard retracts flush with the deck when not needed as a seat. :rolleyes: Another item of note is the cleats. It appears that they are fixed and do not retract or become flush with the deck in some manner.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I take that back about the hull expanding and contracting on deep dives.
The area in question is not part of the pressure hull, but a casing installed over the true hull to provide a walking/working area and is therefore not exposed to pressure changes with depth. The true pressure hull starts just below the freeing ports at the water line and appears to be black rather than the charcoal color of the upper hull.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I have this pic (again not one of mine)
It shows more detail including the pattern on the sides that is completely without any tiles  - but looks intended that way.
OC.
Current builds
Completed works.
Nice work on the anti-skid OC. Rather ambitious replicating the tiles. Do you plan to also show her with a few missing tiles ?????
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
Im not sure about replicating the tiles and missing ones,  I might be able to tape up a few  bit by bit.
OC.
Current builds
Completed works.
Change of plan for my next stage as I am not happy with the finish so far  - I decided I will join the bottom and close the hull,  and possibly construct the sail and fit it,  then I will be able to work on the join seam and sand as needed,   then I will mask to where the generic waterline would be be and give below it a few fresh coats of paint by hand as I dont have a sprayer.
The sail will give me something to hold onto while hand painting and the masking will help with even brush strokes, then I will polish with soapy water and a sponge as before to smooth out any brush marks (well thats the idea)
OC.
Current builds
Completed works.
wrt your question, i need to look it up, but the area you are looking at is part of the sonar array areas, and although still covered i believe i a different type
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Some other T boats appear not to have the channels on both sides, just want to work out if I can paint them in the same dark greay color as the tiles.
OC.
Current builds
Completed works.
28 minutes ago, vossy said:
Really interesting thread and build OC. I have a 1:350 Kursk in my stash that I am keen to make a start on soon. Thank you for the entertainment!
cheers
chris
Start it chris.
OC.
Current builds
Completed works.
I will soon. want to finish my riverboat first. am thinking maybe I might try a diorama of Kursk alongside. given there's not a great deal of detail on these guys I figure maybe I can add access ramps, tethering ropes etc to a dock. also I like the idea of trying to use fake water. but as I say, riverboat comes first.
cheers
chris
here is a photo of Sceptre secured alongside the Diligence in Jordan would make an interesting diorama
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Great photo kevin isnt that the boat you was stationed on/in?
OC.
Current builds
Completed works.
OC.Yes it is, i enjoyed my time on her and all the other boats i was on, but dont miss it
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
26 minutes ago, Kevin said:
So you was a Dolphin submariner.;)
OC.
Current builds
Completed works.
OC.
dolphins are awarded on completion of part 3 training on your first Sub, i got mine back in 1980, on a conventional boat HMS Odin, all in all i had only 6 hull but did about 24 years in them of the 28 years in subs plus another 6 years in surface vessels, hence the building of my HMS Fife
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
That is some service beneath the waves,   I spent a day at Dolphin in 81  school work experience based at Collingwood for the week,   facinating experience taht led me into applying to be a WEM the year after (didn't make the grade though).
OC.
Current builds
Completed works.
Right  I decided to attack the sub  (no pun intended)   by closing up the hull,   this was quite a  tidy job but needs  a bit of filling near the bow,   any way  I also put the two halves of the sail together, then glued this to the hull,   when set I lightly sanded the hull  to create a key, but also masked off the top section, then I started to apply the first few brush coats of dark navy grey.
It will need quite a few coats (all thin coats) to build up a smooth finish.
Here are a few pics.
OC.
Current builds
Completed works.
51 minutes ago, cog said:
Nice progress OC. Looks like a pritty solid colour to me ... so you'll be repainting your acoustic tiles again?
Hiya  mate,  I will continue to buile up the base color first and attack the bow area where there is a gap, then I will look at simulating some tiles with tape masks.
"note to self - look on flee bay for that flast coay rattle can carl mentioned"
OC.
Current builds
Completed works.
