This is my first posting here. I am about to start my second wooden ship build.
I believe the first model was the Dumas Kuala Lumpur kit, I built over 30 years ago.
I picked this kit, due to the fact of the detailed instructions included.
There also seems to an abundant wealth of info here on this site about that kit.
I have built RC planes both from kit and scratch before.
There will not be much progress on this until next month, I have a rocketry project that needs to get off the work bench first as you can see in the last photo.
40 minutes ago, Y.T. said:
Hoping your "rocketry project" is not located at a Gaza strip. :D
Love a sarcastic sick sense of humor. 😁😂
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Smarra the Syren is a fun educational build. Enjoy.
Regards,
Jim Rogers
Inventoried all the parts and cut out the bulkhead former. It seems to be perfectly flat.
Using a French Curve, I drew the bearding line on the other side of the BF. This will be it until next week as I'll be traveling over the week end.
IMG_6551.thumb.JPG.65736872ba9a9d5546bd4058cf4dd6e6.JPGIMG_6550.thumb.JPG.e694295237d49a034c1983a83cc9745d.JPG
Preformed the rabbet strip.
IMG_6598.thumb.JPG.8b5e2718dd7791bc1ffba7517b7fcede.JPGDry fit the bulk heads, the stern looks to line up nice.
The bow not so much, The second bulk head bevel line falls short of the bearding line. I guess I'll remark to the bearding line and bevel from there, worst case I guess I'll have to do more sanding when fairing the hull.
Edited by smarra
More text for photo
The bulkheads are faired and all but three bulkheads are glued in place.
Not sure where I saw on this site about the lego blocks for squaring the bulkheads, but it has worked out perfectly so far.
The keel is still pretty much square. I'll add balsa filler blocks next to keep it that way.
11 hours ago, HIPEXEC said:
Good luck with your build! :dancetl6:
I have been following your build and I'm very impressed with your workmanship.
If my build comes out even half as good as yours I'll be thrilled.
35 minutes ago, Y.T. said:
The soft wood pieces in stern and bow make lots of sense for proper hull curvature there. Wood pieces in the middle of the hull - I am not sure what benefit they can bring.
I put them there in hopes of keeping the keel and bulkheads straight.
One of the great benefits of the additional blocks comes during planking of the deck. Now you don’t have to be concerned about being over a bulkhead to attach decking planks as you have the entire surface for glue. I do this all the time, makes the build really sturdy.
Regards,
Jim Rogers
2 minutes ago, HIPEXEC said:
Careful! The whole thing is very fragile at this point. Most of us had to do major re-work after breaking the fragile wood.
I'm finding that out, just sanding very lightly at this point. That is why it is taken so long to move on the the next step.
Hopefully as more wood is added it gets stronger.
I now moved into new territory for myself, as this is my first planked wooden ship.
I have been comfortable in my skills up to this point.
We'll see how this next phase of planking the ship goes.
She is looking great so far. Just take your time when you are planking and it will all work out. You’ll do just fine.
Regards,
Jim Rogers
