Bowdoin 1921 by ahb26 - FINISHED - Bluejacket - Scale 1:48
I took advantage of a brief trip to mid-coast Maine to visit Bluejacket Shipcrafters in Searsport and purchase my next project, the schooner Bowdoin.  This will be my second plank-on-bulkhead model.  The first was twenty-five years ago, Laughing Whale's small Friendship Sloop.  (That kit lives on in Bluejacket's line; they acquired Laughing Whale some years back.)  Bowdoin looks like a good project for reacquainting myself with the planking process, and I have ESF's (Steve's) excellent build log for reference.
Why Bowdoin?  As the official state sailing ship of Maine and sail training vessel of the Maine Maritime Academy, she has strong connections to the state.  I have deep roots in Maine on my father's side, and my wife's parents had a cottage on the coast for many years, so we spent a good deal of time there.  I like the looks of the ship, and the fact that she was built for Arctic research and carried out that mission with great success.  I like the relative simplicity of the rigging (I've had my fill of square-rigged masts for now).  I get a kick out of knowing that the kit was developed (originally by Laughing Whale) and is built right in Maine, a short drive from where Bowdoin is based in Castine.
Bluejacket Shipcrafters.
A wonderland of beautifully finished ship models.  That's proprietor Nic behind the counter.  (The camera was inadvertently set on the Toy Camera effect for this shot and the next.)
And here's Bowdoin.
This will be a long project.  I want to do Bowdoin justice as her centennial approaches.  This is a good opportunity to learn new skills and improve existing ones.  I'm not going to rush.  I think there are at least two other Bowdoin's in the works, but neither has broken cover yet with a log.  I'm looking forward to sharing information with these ongoing projects, especially when I run into the inevitable problems along the way.
Edited by ahb26
Corrected to plank-on-bulkhead (not frame)
Andrew Bodge
Finished:  Muscongus Bay Lobster Smack (Midwest / Model Shipways)
Finished: Maine Lobster Boat (BlueJacket)
Finished: Yankee Hero (BlueJacket)
Finished: Emma C. Berry (Model Shipways)
Finished: Northeaster Dory (Chesapeake Light Craft)
Finished: Schooner Bowdoin (BlueJacket)
Finished: US Revenue Cutter "Joe Lane" (Marine Models)
Missing and presumed lost: Friendship Sloop (Laughing Whale)
Link to comment
Share on other sites
And so it begins.
The contents of the box (less the manual and other documentation).  I purchased the book from Bluejacket previously.
First order of business was to build a keel vise.  I have a lot of cherry left over from a kitchen remodeling project, and it comes in very handy for this sort of thing,.
The edges of the 1/8" basswood keel have 1/16" strips glued on to form the final keel width and a rabbit for planking.  Here the bottom strips have been glued on and clamped.
Andrew Bodge
Link to comment
Thanks Chris and Azzoun for the likes and response.
I didn't start this log until I had completed some initial work (and reached my first issues).  With the keel glued up, I broke out the bulkheads and sanded out the slots in the bulkheads and keel to allow the bulkheads to slide on easily.
The keel and bulkheads are both 1/8" basswood, and the bulkhead extensions (timberheads?) are quite fragile.  (It's interesting to contrast this construction with that of the Model Shipways Bluenose, which appears to use 1/4" basswood and plywood for keel and bulkheads, and use 15 bulkheads vs. six for Bowdoin.  You could pretty much drive a truck over the Bluenose's hull.)
The deck is 1/16" thick and comes in two halves, which I pinned to a foam board and glued with thin CA.  I had to file and sand the notches in the deck edges to allow the bulkhead extensions to slide in freely.
I boxed in the mast seats in the keel and cut 1/8" tenons in the two dowels provided for masts.  With the bulkheads set in place but not glued, I was able to do an initial trial fitting.
At this point, I discovered that bulkheads 3 and 4 are slightly narrower than the deck.  Whether this is due to expansion of the deck or inaccuracy in the parts, I can't say, but I had to enlarge the notches to allow the deck to be placed over those bulkheads.  I could have saved myself some trouble by checking the bulkheads against the deck halves before the deck was glued, making sure the bulkhead centerline matched up with the deck centerline.
So the first issue is whether to correct this by sanding the deck edges flush to the bulkheads, or by building out the bulkheads to match the deck.
Other than that, the deck fits well, so I pulled everything tight with rubber bands and glued the bulkheads to the keel with CA.  I didn't glue the deck to the bulkheads yet, that's an issue for another reply.
Edited by ahb26
Bulkheads, not frames!
Andrew Bodge
Link to comment
I should mention that, for the first part of my career, I edited and wrote software documentation and specifications.  In part because of that, I am a compulsive instruction reader and I seize on inconsistencies and any lack of clarity.  With that in mind, if you are listening Mr. Bluejacket, please take my comments on the Bowdoin manual as constructive observations, not criticisms!
The Construction Overview suggests completing the planking before fastening the subdeck to the hull.  "Doing so makes this operation much easier."  However, the construction photos all show the subdeck firmly attached to the hull during planking.  Furthermore, the subdeck must at least be in place, at least for the first few upper planks, because it locates the bulkheads.  And the top edge of topmost plank (shear plank?) lies flush with the top of the subdeck and should fit tightly against it, otherwise the bulwarks won't line up properly with the hull planking.  All of this argues for gluing the subdeck in place prior to planking, losing the advantage of unfettered access to the interior during planking.  Also, gluing the subdeck to the bulkheads will be easier if the planking is not present, since the subdeck must be held in place by a collection of rubber bands.  Given all of this, I am inclined to glue the deck down before planking.
While we are on the Construction Overview, it states that two different widths of planks are used.  This does not appear to be the case.
Andrew Bodge
Link to comment
Hi  Andrew. My Bowdoin is sitting in dry dock as I am waiting to regain full use of my right hand. I have started the rigging
when I was sidelined. Hope to be back at it soon. My son who is in the Coast Guard just did the inspection of the Bowdoin
and came up with some fine pictures.
Wish you the best on your build and will be following along.
        Bob Porter
Link to comment
Tom, Bob, Tasmanian - thanks for looking in!  Bob, I hope you are back in commission soon.
The deck has been completed and glued on.  It was not a trivial exercise.
The fore subdeck is made up of two halves of 1/8" basswood.  As I was preparing to join them, I noticed that the joining edges are cut on a very slight angle.  This provides a slight crown in the foredeck, matching the crown in the two bulkheads it sits on.  Handy!
Gluing the foredeck to the main subdeck.  I should have clamped the edges better, but was able to fix the resulting gaps later.
I needed all these rubber bands to get the proper compound curve into the deck.  I left it like this overnight in hopes the deck would relax into position - it did, more or less.  Where small gaps remained between the deck and bulkhead surface, I held the deck down by hand while the CA glue was setting.
The deck is about 1/8" aft of its intended position relative to the keel.  I noticed this during initial deck fitting, but even before the bulkheads were glued to the keel, it was very difficult to move the deck forward.  I hope it doesn't cause problems.
The deck in place, bulkhead extensions sawed off and sanded flush to the deck.  (I'm glad to be rid of them.  I broke most of them off and reglued them at least once during this process.)
The next steps are fairing the bulkheads, planking the deck (with scribed sheet), shaping and gluing the transom block, and waterways.  Then the real fun begins!
Edited by ahb26
Typo
Andrew Bodge
Link to comment
Andrew,  thanks so much for the shout-out on my Bowdoin.  I thoroughly enjoyed it as my first wooden ship build and I'm sure you will enjoy yours.  I ran into the same problem with the subdeck being slightly short at the bow but I thought it was due to poor positioning on my part.  Later in the build I fit a small piece in the gap.
Regarding planking, the instructions say to fit the first four planks (from the sheer down) on each side without spiling, but this created issues later with trying to fit the remaining planks, especially at the stern.  Toward the bow I needed a couple of drop planks each side and even then it was tight.
Maine Maritime Academy has photos online of the Bowdoin restoration from about 2014(?) that were useful to understand mast, deck and bulwark details.  They also have a series of photo logs of student cruises which were good for understanding the deck layout and capstan details.
Rubber bands were a godsend for me too, along with metal binder clips customized as I saw in other builds to hold planks in place.  I also used wood spring clothes pins sawed off to give a square end for tighter work.  The compound plank bending was helped by soaking planks in boiling water for an hour, using a length of plastic pipe capped at one end and standing vertical.  The clothes pins also helped to keep the planks from rising out of the pipe while they soaked.
Thanks again and best wishes on your build.  I'm sure you'll beat the 550 hours it took me.
Steve
Link to comment
Steve, thanks for the reply.  I am logging my time but I also expect to be taking my time.  As Nic at Bluejacket said, model shipbuilding is a relatively inexpensive hobby on a cost-per-hour basis, and the more hours, the lower the cost per hour.  Currently, I am working on the deck planking and also tracking down and studying information on hull planking.  At some point I will have to dive in and acquire the hands-on experience to go with the information.  Your log will be most helpful for that and other tasks along the way.
Andrew Bodge
Link to comment
Work on the scribed decking proceeds, but I also broke out the laser-cut transom block and studied what needs to be done to it.  The block is meant to extend 3/4" beyond the aft end of the keel, and the outside of the block will be shaped such that it aligns with the angle of the keel.  (This will be more clear at a later stage.)  If the deck were in the right place relative to the keel, this would place the block at the aft edge of the deck - but as noted earlier, the deck is 1/8" further aft on the keel than it should be.  What to do?  I was initially inclined to trim 1/8" off the deck, but thought better of it when I realized that the deck locates the upper part of the bulkheads.  I didn't want to reduce the distance from the aft bulkhead to the transom, so I decided to extend the keel instead.
In the bow, the incorrect position of the deck would result in a gap between the top plank and the deck.
I added a strip of scrap wood to the edge of the deck and sanded it to fill the gap.
I'm glad I didn't rush through these steps.  It took me a while to recognize the problem, and a while longer to think it through and settle on solutions.  Fortunately, I haven't yet cut the scribed foredeck down to its final shape.
Andrew Bodge
Link to comment
I stained and varnished the decking sheets, and glued them to the subdecks.  After scribing plank butt joints into the sheet, I used Minwax "aged oak" gel stain with liberal amounts of pre-stain conditioner.  The result was a bit blotchier than I hoped but should be OK with all the deck furniture in place.
I used contact cement, with a wax paper slip sheet to allow positioning.  It's a bit nerve-racking as you only get one shot at it.
All deck sheets in place, edges trimmed and sanded flush to the subdeck edge, mast holes opened out.  Despite my best efforts, there is a slight gap between the edges of the main deck sheets toward the bow.  Fortunately, that area is mostly covered in deck structures.
I have also been working on the transom block, but I'll cover that in a separate reply once it's in place.
Andrew Bodge
Link to comment
Tale of the Transom
"Let's carve him as a dish fit for the gods..." Julius Caesar Act 2 Scene 1
The transom block starts out as a C-shaped piece of 3/8" thick basswood.  Most of it will end up as sawdust.
The inner part is shaped first, using the supplied template to define the amount to remove.  I used a Dremel sanding drum in my drill press to do most of the work.
After painting the inside surface, I glued the block to the deck.
At this point, the instructions are a bit vague.  As best I could tell, I needed to shape the underside of the deck and block to match the line of the keel.  I used a large sanding block to sand a flat surface, ending up with this:
At this point, I started looking around.  The laser cut parts include this template, which is not mentioned in the instructions:
In The Arctic Schooner Bowdoin: A Biography, there are two photos that clearly show the transom, and it is this shape.  (In the photos, from 1924 and 1941, the transom is painted a contrasting dark color.  I may do this when I paint the hull.)  I also located a photo from the recent Bowdoin deck restoration project that provides an excellent view of the transom, confirming the shape and also showing that the transom is right under the caprail at the stern, with no space between.  That meant that I had to increase the angle of the area I had sanded to bring it closer to the top of the block.
I also had to sand a slight arc (as viewed from above) in the surface to bring its top edge to the top of the block along the entire width.
This got me closer to the desired shape, but the two triangular ares at the bottom corners still had to be removed.
Here, one side has been sanded to the shape of the transom.  I ran planks from the rearmost bulkhead to get an idea of how the surface should be shaped.
Both sides sanded.  I can see from the photo that I probably have a bit more to go to get them to match, and possibly more when I get to planking, but I am going to leave it alone for now.  Next step is to paint and attach the waterways, and then - planking.
Edit: I should have sanded right to the top edge of the deck rather than leaving the thin strip.  See the April 15 2019 post for more information.
Edited by ahb26
Note that transom should be sanded to top edge of deck.
Andrew Bodge
Link to comment
The waterways consist of 1/8" x 1/32" basswood strips.  After cutting to length and shaping the ends, I poured boiling water on them and let them sit for a few minutes, then clamped them in position to dry.
This was my first attempt at putting a bend into wood and it worked OK.  After painting, I managed to glue the strips in without smearing glue (carpenter's) all over the deck.
I am using the paint from Bluejacket's paint kit - Testor's Model Master lacquer primer and enamel top coat.  I'm not impressed by the coverage capability of the top coat - need to work on my brush technique, but I think I'll find a flat white spray enamel for the hull and large cabin surfaces.
EDIT: It was a mistake to paint the top surface of the waterways - I should have just painted the inner edge.  The top surface should be left bare to allow a good glue joint with the false timberheads.  Also, the waterway will get dinged up when the scuppers are cut.  Finally, I noticed ESF (Steve) had an initial problem with the paint because he didn't stir the primer and it didn't dry well.  I also didn't stir the primer.
I have to put in a good word for Maine Maritime's Bowdoin Deck Restoration Archive.  It covers an extensive restoration project in 2015-16 that replaced not only the deck but a lot of frame timbers and planking.  The engine was removed and overhauled at the same time, and many systems were updated.  The archive (start with the highest number page) begins with removal of deck structures and removal/demolition of the deck and old framework, then shows how the new wood is planed, shaped and installed.  It's interesting to contrast the way the real ship is put together with the model.  If you are building Bowdoin, the photos are an invaluable resource, but it's fascinating even if you're not.
Edited by ahb26
Painting top surface of waterways was a mistake.
Andrew Bodge
Link to comment
Planking has commenced with the shear strakes on both sides.  This is going to be a learning process.  The logs I've looked at mostly don't go into the details of how the builder glues the planks to the hull, and the details I have seen cover various different approaches.  I will be finding my way to a method that works for me and documenting it as I go along.  I am always open to comments and suggestions!
EDIT: It's worth noting that on the actual ship, the planking appears to extend to the height of the foredeck, not the (slightly lower) main deck.  You can tell this by noting that, when seen from outside the ship, the main deck scuppers are cut into the topmost planks, not into the bottom of the bulwarks (as denoted by the horizontal break at the top of the planking).  See the April 15 2019 post for more details.
I went through the exercise of lining out the hull, making a spreadsheet with planking bands and stringing thread along the bulkheads.
I'm not sure of the value of this, since I'll be using full-width (1/4") planks for the most part, which will not fit evenly into the bands.  However, it does give me a sense of where I may want to taper or consider a drop plank in the bow.  The stern is anyone's guess at this stage...
Here's where I do the planking work.  The plank soaking tank is clamped to the bench (thanks to ESF for that suggestion) and filled with water and a little household ammonia (as recommended in the Bluejacket instructions).  The soaked shear planks were pinned and rubber-banded in place and heated to the sizzle with my wife's old curling iron.  When dry, they held their shape well.
Hanging the first plank felt like an act of faith that was not initially rewarded.  I tried using a combination of CA to secure the plank at the stem and first bulkhead, with carpenter's glue along the run of the plank where it glues to the edge subdeck.  I wasn't able to clamp the plank to get it tight to the subdeck, so I switched to using CA glue everywhere.  I pinned the plank to each bulkhead and ran a bead of thin CA along the junction of the plank and bottom of the subdeck.  By the time I got to the second shear plank, I had the clamps in play where possible and the process went smoothly.
Next step is to hang the next planks down on each side.  I'll investigate introducing a taper into these, although the instructions say the first five planks on each side should be used full width.  As I said, it's a learning process - we'll see what happens.
Edited by ahb26
Note that planking should extend to height of foredeck.
Andrew Bodge
Link to comment
The first five strakes have been glued in.  I added thin strips at the stem to provide more glue contact area and bring the surface of the planks flush with the stem.
(This also shows the mess I made of the first strake.)  I also added thin strips at the stern for more glue contact.
I soaked each pair of planks for a couple of hours, then formed them over the bulkheads, hit them with the curling iron, and left them to dry.
The clamps and binder clips help keep the plank edges aligned.  To glue, I ran a line of carpenter's glue along the edge of the plank being installed, well beyond the next bulkhead, then used CA at the bulkhead crossing.  I then extended the glue along the edge of the plank and glued at the next bulkhead.  I had to keep up the pace so the carpenter's glue wouldn't dry before I got it in place.  It was a little messy but worked well.
At the stern, I tapered the last two planks slightly (and a third plank on one side to make up for an earlier error placing the first strake).  We'll see how that works out later.  My keel vise worked pretty well as a plank vise, but the middle of the plank wasn't firmly gripped.  A third bolt would solve that.
I cut the tail ends of the planks to the approximate shape of the transom.
Then I sanded in the plane of the transom.  As I had hoped, the planks tapered to a clean edge along the previously shaped transom.
The result is a pretty good match for the actual Bowdoin transom.
Photo by Chase Davidson, used with permission of Maine Maritime Academy.
The instructions say to start planking from the keel up at this point.  I'm fairly pleased with the results so far - it will need some sanding and filling, but that's to be expected.
Andrew Bodge
Link to comment
I have done three strakes (plus a stealer) up from the keel on each side.
My first stealer!
Things are getting more complicated.  These strakes have to fit into rabbets at each end and they have a slight taper at the forward end.  They also have more twist, but soaking plus the hair dryer on high gives good results.  (The curling iron is difficult to maneuver into these spaces.)
The 4th and 5th bulkheads still need seven planks, but the 1st only needs three (or more, with tapering).  I need to figure out how to make that happen as well as navigating the twists and turns and odd empty spaces at the stern.  It's an education.
Andrew Bodge
Link to comment
Hello Don, glad you are following along.  The keel vise is 13" long, and is made of scrap cherry left over from a kitchen remodel.
Two weeks since my last update - it feels like longer. Not a lot of visible progress, but a lot of thought and some false starts and redos have gone into the two planks (per side) I've added.  Plus, there was family here at Thanksgiving and other stuff going on.1038070704_DSCF5563(800x600).jpg.ca5660e3615234204cb35dc0fc42c212.jpg
Here, the fourth plank (which is a drop plank at the bow) has been added and the fifth plank is ready to add.  This is the most complicated plank so far since it also needs a stealer at the stern.  I discovered that I can use a razor saw along with a plane to cut the tapered notches when the plank is clamped in my keel vise.  It does a cleaner job than I can do with a hobby knife.
Fifth plank in place.  The port side is the "good" side since I do the starboard first, then apply what I've learned on the port.  I'll need five planks for the middle frames, with one or two drop planks toward the bow.  The stern will be an adventure, but it appears that drop planks will be needed there as well.
Andrew Bodge
Link to comment
Happy New Year!  Bowdoin's last plank was glued into place on the last day of 2018.  The project log shows 78 hours total, with 42.4 hours spent on planking.  (The log is an approximation at best.  It only counts time hands-on the model, not the time spent on research or lying awake trying to puzzle out a problem.)  Things did not go entirely smoothly in the month-plus since my last update.  I found that I had introduced a significant bulge in the upper planking toward the stern (especially on the starboard side) that did not match up well with the lower planking, which was stretched too tight between the bulkheads.  On the starboard side, the planks were not laying out well, and I had to tear out some of what I had done.  I chalk it up to inexperience, although I'm not sure what I would do differently next time to avoid these problems.  An in-person mentor would have been a big help, and perhaps more detailed instructions and a few intermediate bulkheads also.
The photos are before any significant sanding.  I have renewed my sanding blocks and purchased a can of MH Ready Patch in preparation for the next phase.
Port side - the "good" side.  I'm reasonably pleased with how the planks laid out on this side, but the execution leaves something to be desired, particularly toward the stern where the planks don't align well.
Starboard side.  It was a scramble to get this done at all, and I ended up cutting odd shaped planks to fill the gaps left by other planks going off at odd angles.  I'll be happy when this is sanded and filled! - but I have detail photos to remind me of my sins.
Stern detail.  The port side is orderly, starboard less so.  There are a couple of cases where I thought a plank would turn into two planks, but that didn't work out, accounting for the apparently unnecessary joints.
Andrew Bodge
Link to comment
Starting to sand.  A few of the gaps between planks are in excess of 1/32" (maybe 3/64") and I'm concerned that when these are filled, the wood will flex during further sanding and dislodge the filler.  Should I be filling these cracks with epoxy or some other material before the Ready Patch goes on?
Andrew Bodge
Link to comment
Nic, thanks for the encouragement, and thanks also to others who are following along.
Tale of the Transom, Part 2
As I went through a few cycles of sand, fill, repeat, I realized that I had yet to plank across the transom.  I had thought of putting it off until the bulwarks were installed but figured I should do it before the last of the filling and sanding in order to blend it in.  As noted in an earlier post, the transom has a slight curve in both the horizontal and vertical axes, so gluing straight planks to it was going to be a challenge.  I also wanted to maintain the specified shape.  I edge-glued four short planks and traced the shape onto them:
Then I cut it out and covered the glued planks with boiling water.  While they soaked, I sanded the approximate shape of the transom into a small block of softwood.  The soaking dissolved the glue joints, so I clamped the individual pieces onto the block in their relative positions, then heated them with a curling iron and hair dryer and left them to dry overnight.  Finally I re-glued them and clamped them in place on the same block, with wax paper between.
The result was a built-up piece with curvature that made it simple to glue into place.
I will need to fill around the edges so the planks appear to butt against the transom, and work the top edge to look more like the real thing, but I'm glad to have this part of the job behind me.
EDIT: The top edge of the transom planking should be flush with the top surface of the transom block.  See April 15 2019 post.
Edited by ahb26
Note that top edge of transom should be flush with top surface of deck.
Andrew Bodge
Link to comment
After a couple more rounds of filling and sanding, the hull was ready for its initial coat of primer.
As expected, the primer showed up some flaws and more sanding and filling was needed, but I'm generally pleased.  On close inspection, I can see lumps where the bulkheads are under the planking, due to stretching the planks too tightly, especially on the starboard side.  More bulkheads - or more experience - would have helped.  I also established the proper angle of the keel with respect to the horizontal (there is a name for this but I forget it) and scribed lines on the keel so that I can replace it in my keel vice at the correct angle and elevation.  I'll fill the lines when they are no longer needed.
If I had it to do over again, I think I would attach the transom before any planking, then butt the planks into the transom - rather than sanding the ends of the plank the way I did.  I filled the area under the transom to get the same effect, but if I wanted plank lines to show, that wouldn't be possible.  I also have an issue at the top edge of the transom that I'll have to address later.
Edited by ahb26
Remove unwanted photos.
Andrew Bodge
Link to comment
Tom E, thanks for the "like".
There are a few more tasks before the final paint goes on.  Hanging the rudder is first up.  When I broke it out and offered it up to its location, I found that the available space was slightly shorter than needed to align the propeller cutouts on the sternpost and rudder.
The space between the bottom edge of the planking and the start of the cutout is about 1/8" shorter on the model than in the plan.  I realized that this resulted from an adjustment I made early on, when I found that the deck was displaced aft with respect to the keel assembly.  I made a paper copy of the rudder to figure out how much to remove from the top, then shaped the rudder to match.
Next, I found out that the cast medal gudgeon fitting for the bottom of the rudder was meant for a 1/8" keel, not my 1/4" keel.  After some head scratching, I decided to cut mortises into each side of the keel to take the straps of the gudgeon.  The mortise is 1/16" deep at the edge of the keel, reducing to the thickness of the strap at its other end.  I was able to rig up a guide for the knife blade:
I used 1/32" brass rod for the hinge pins, and voila...
Everything is now disassembled.  I still need to shape the rudder and install the propeller, and I have an idea for improving the appearance of the top hinge area, but the tricky part is done.
Edited by ahb26
Conciseness.
Andrew Bodge
Link to comment
Nice work on a nice looking schooner - look forward to following along.
Edited by gerty
Current Build: Willie L. Bennett - Model Shipways
Future Interests:  Friendship Sloop - BlueJacket Ship Crafters
                            Cape Cod Catboat - BlueJacket Ship Crafters
Link to comment
Gerty, Tom - thanks for the kind words.
The rudder and propeller are all set for now.  The propeller shaft is 1/16" brass rod from the kit, and I found some 1/8" O.D. copper tubing (from an aftermarket windshield washer setup) for the housing.
I now arrive at my first major addition to the kit as supplied.  According to Thorndike's The Arctic Schooner Bowdoin: A Biography, Bowdoin was originally built with a band of ironwood sheathing over her planking that "started a few inches above and reached five feet below the waterline."  The sheathing was present until at least 1947 and probably was removed, and not replaced, during the 1980 rebuild.  This photo, from 1947, is the best picture of the sheathing I've found.  The sheathing is not there in a 1984 photo.
I'd like to include the sheathing in my build.  It was 1-1/2" thick, so 1/32" basswood will do nicely (ironwood being in short supply this year 😉). I plan to use 3/16" wide strips cut into 5" lengths to simulate 20 ft. planks, and for ease of handling.  This is the approximate area to be covered (I'm still dialing in the waterline):
The 1947 photo can be zoomed to show quite a lot of detail.  It appears that the sheathing was mostly used at full width without too much shaping, except where necessary to conform to the upper or lower boundaries.  Hopefully this will simplify the job.  I plan to draw a line where a plank will lay fair the full length of the hull between the boundaries, and work up and down from that line.  I'd like to do this without filler if possible so the lines show through the paint - that means I need to keep things tidy.  Another learning experience!
Andrew Bodge
Link to comment
Andrew
looking good. I believe the prep work you did on the deck will really look really good.
It is so much fun to build models of schooners and other ship or brigs that we can go see. With luck she will be back in the water next summer.
cheers
jon
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
