I’m taking a break from the Victory and building the Prince de Neufchatel from plans in American Sailing Ships by Howard I. Chapelle.
So far I’ve traced the hull lines and resized them to 1/72 scale.
Building:
1:200 Russian Battleship Oryol (Orel card kit)
I’m using Ab Hoving’s tutorial.
I’ve never built from scratch before, so we’ll see how this goes.
Here’s the first two bulkheads:
Just as a side note, I’m doubling everything for more strength.
Building:
The only drawback to the posterboard is that I am having to double it in order to build up to the 1mm thickness that Ab mentioned in his tutorial.  But, so far so good.
 I traced the deck camber from Zu Monfeld and enlarged it to make a template which I transferred to the bulkheads.
 I’m currently in the process of doubling the bulkheads below the main deck to gain more area to glue to.
Building:
The plans in HIC books are available from The Smithsonian for $10 a sheet plus $5/12 postage.
The line scan is crisper.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Thank you for the information.  I’ll remember that for next time.  There are several ships in his books that I would like to build.  Buying the plans in sheets would be very convenient.
 I never actually scanned these, I just traced them and enlarged the tracings.  This has been a highly educational project.  I’ve been learning a lot.
It’s been a lot of fun too, I’ve never built from scratch before.
Edited by GrandpaPhil
Building:
Quick question, what’s the best way to install a transom on a card model?
Should I just build up the stern frames like any other model, or just glue it to the stern after installing the deck and covering the hull?
Building:
I don't know, but try searching (either here or on the Internet in general) for build logs of Shipyard kits. You might find how they plan for that task. Good luck!
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Mitsubishi A6M5a, WAK SBLim-2A
Richard44's SBLim-2A build
Hi Phil
Talk about a ‘challenge’...this has it in spades!  No doubt you’re up to it; especially with the very promising start you’ve made already.
I’ll be following along for support and encouragement.
Have a great Christmas and New Year!
Cheers.
Patrick
12 hours ago, Wallace said:
I have to take my hat off to you Phil, I am impressed with what you are doing. It looks like it is a very steep learning curve but hey, that's why we do it right?
Thank you!  Much appreciated!
I’ve definitely been learning a lot with this project!
I’ve answered all of my own questions about rescaling plans and transferring from the books, just by doing it.
Building:
10 hours ago, Omega1234 said:
Hi Phil
Cheers.
Patrick
Patrick,
  Thank you and welcome aboard!
Have a Merry Christmas and a Happy New Year!
Phil
Building:
Due to a minor issue resulting from the  placement of my templates on the poster board and the page split of the plans in the book, I had to cut the deck pieces between bulkheads 1 and 2 and remove about 3/16”.
I have the forward deck pieces and bulkheads permanently installed.  As soon as they finish drying I will pull the aft deck pieces and double them.
Building:
WonWoToderfull start, you ade Phil!
To make it more stable, you can fill the spaces with balsa wood blocks, so you get a smouth durface for the planking. Or if you a dogmatic cardener you could lay light paper diagonally over the bulkheads and create the surface for the planking like in this way.
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
59 minutes ago, Wallace said:
It will be interesting to see how nice and stable your hull will be after adding the board. I will be watching :)
The hull is strengthening up nicely.  I’ll be able to tell you more after I get it done.
Building:
