Thank you... I'm seriously considering coppering the hull and from what I've learned, the plates' size should be at this scale 19 x 6 mm, but I'm not sure about the material. There are some self adhesive copper 6mm tapes on the market, but they are a bit pricey and I do not know whether their glue will suffice. Normal copper sheats and cyano would do, but what thickness should I choose that would be ideal to work with (incl. "printing the nails")?
1st build - HMS Race Horse (Sergal)
Current build - HMS Fly (Victory/Amati)
Great planking Vitus. Nice to have you well ahead of me, I can follow and learn!
Cheers
Alistair
Cheers
Alistair
Current Build -
Thank you. That depends, Brian. Either I will copper the hull, or treenail it. In any case those visible planks will be treenailed. I'll probably use something else than actual treenails (toothpicks). Probably a thin and cut injection needle that creates small circles that (using a bit of varnish) look rather good.
An example from a Czech board by klimi (http://www.modelforum.cz/viewtopic.php?f=177&t=73264&p=1452414&hilit=jehlu#p1452414)
I'm impressed. I will use your pics while doing my HMS Pandora. Neat, clean and good-looking. What's the diameter of your treenails? When I have some doubts with my kit, I'll write to you :)
Cheers, Paweł
Paweł
Current build: HMS Pandora: http://modelshipworld.com/index.php/topic/3409-hms-pandora-by-jastrz%C4%85b-constructo-185/
Finished projects:
Roar Ege 1:25, Billing Boats
Albatros 1:55, Constructo
Santa Maria 1:50, Mantua
Thanks everyone, much appreciated. Paweł, treenails on the deck should be at this scale .4 mm, but that is rather hard to achieve, so mine are about .5 mm. Treenails in the hull planks are bigger. Anyway, the copper tapes just arrived, so now I'm thinking about a way to assemble 46 pins to make a stamp and "nail" the copper sheets with it. Sounds like a piece of cake :)
The copper tapes are very thin (about .03 mm), but once pierced, the marks won't disappear whatever I do, so I'll probably use them. Still, they don't look like they can take damage easily, so I will lay them once the heavy works are done and that will not happen any time soon.
Splendid planking work Vitus, it looks perpect! :)
Have you considered just leaving the hull uncoppered? I personally think your planking work looks too beautiful to cover up B)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
I could not resist applying first protective thin layer of semi-matt Nelson varnish after sanding the hull. There are still quite a few details to take care of and the first layer also revealed a few poorly finished spots, but the overall result is good, in my opinion. Looks like I will have to use those copper tapes elsewhere, treenails FTW :)
Hi Vitus
Your planking is really great - looks near perfect - if I get it that good I'll :).
But - it maybe the photos? - it looks very stripped, pale, dark, pale, dark etc. Perhaps pause for a look at the overall effect if it isn't otherwise dressed - copper plates and paint? Could be the photos, could be my taste...
Just my thoughts
Alistair
Cheers
Alistair
Current Build -
Vitus, I'm with Aldo on this one.... copper plating can be used somewhere else because that planking looks gorgeous. The varied and staggered planks, the colors.... seems a shame to hide it behind something else... of course she's your ship so your decision but you have a beautiful hull there :D and if it were mine... :)
Vitus,
I'm am in awe before your beautifull planking! I hope mine will come half as good. Regarding the coppering, maybe you can copper one side and leave the other natural? Well, wathever you decide, I'm eager to seeing the result. :)
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
Thanks guys for the kind words.
Alistair> Yes, the planks' color is different and the varnish only emphasised it, but on photos the contrast is even greater because the reflections are not diffused like before, but much more focused. This is also why there is a big contrast in overall lightness (esp. in the 1st photo) and now it is almost impossible to shoot the hull under artificial light. I will have to use some very fine abrasive material for the final finishing touch and I also plan to add wearing (that is a maybe). Now I chose to apply the first coat only to protect the planks. Well and also because I was curious about the whole look :)
Anyway now I'm not planning coppering the hull anymore, definitely not only on one side. Better watch out for shipworm now.
Very nice.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Really great work Vitus.Your planking looks fantastic. I hope to be planking that second layer soon and then we can better track through this model together.
Cheers
Alistair
Cheers
Alistair
Current Build -
Your wood finishes have really turned out nice. She's looking good.
John
