Materials:
The real implementation forces to change pump proportions for a little: follow up to standard set of copper (and brass) tubes: 3/16'', 5/32'', 1/8'', 3/32'' and 1/16''.
The chosen tube set is giving a great opportunity - the inner diameter of a tube corresponds to the outside diameter of the tube оf next number – the tube move -in and -out into each other as closely as possible.
Designed etched details on brass 0.6mm thick were good for nothing – I had no inexperience, and did not add 20% of the thickness to the edges of small parts, so they were eaten to be useless ... Nevertheless head cover and the base bed are ok. But the remaining parts – handle, support and stock - should be done by hands.
And yes!!!: a metal wire from the package of bread and brass washer with 1.5 mm inner diameter.
Also I have to say: an idea to make the pump “working” came while of assembling: that was happen that I have steel balls with 3/32’’ and 1/16’’ diameters (I bought them to simulate charges for 24’ carronades and 6' guns, respectively)
Oops!! One more thing: a 00-90 bolt
Edited by mir0n
to be continued....
and well... how i can fix a typo on topic header?  :angry:
Edited by mir0n
Since I haven't made that mistake yet I have to sit and wait with you for the answer. Since I know that will happen to me for sure.
Wacko
Joe :D
Go MSW :) :)
Very cool pump, amazing at that scale!
Now you need to create an animatronic crewman to work the pump in a diorama display, possibly scale figure jointed at the waist with arms attached to pump handle.
Ken
Current Build: Authentic Hannah Kit Bash
Pending Continuation: Sea of Galilee Boat
Completed Build:  MS AVS
On Shelf: AL Independence, Blue Jacket Alfred
To fix the typo, edit your first post - click edit at the bottom of the first post, then click on use full editor.  The title is now available to edit.
This is a wicked neat topic - thanks for sharing it with us!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Cool!!! It works!!! :)
The head:
0.3 mm brass piece: bending, drilling, grinding out a support of handle (have no photo, but looks like everything is clear from the sketch)
Soldering the 3/16'' tube (with bore for 00-90 thread) to the head cover.
Inserting the 5/32'' tube into
Fluting and cutting the threads for the locking bolt
First fitting
Soldering the support of a handler
Chopping, grinding out, trying on
Edited by mir0n
The “pipe”:
On copper tube 1/8'' (main pipe): grinding out a little groove for the locking bolt
Cutting off to the size (see the sketch below...)
On other side of the 1/8'' main pipe drilling a 2.8mm bore; that would be a place for a ball of lower valve
Copper tube 3/32 ""(overflow pipe): Grinding down the desired area up to 1.9mm (see sketch below...)
In the 1/8’’ main pipe: drilling a 1.8 mm bore for the overflow pipe
Another piece of 3/32" tube and all 3 parts for pump pipe are ready
Soldering all together using simple conductor
Reseating the soldering of lower and upper pipes with help of 3/32" diamond sphere
Edited by mir0n
The rocker arm ( The handle)
Brass 0.6mm: cutting out and forming of the rocker’s sly form
Brass 0.3 mm: drilling three 0.5mm holes with 1.4mm step
Bending stock holder, whetting the rocker tip up to 0.5 mm
Soldering
Grinding off excess
Handle assembled!!!
In handle support: boring a required spot for rocker movements
Fitting
Edited by mir0n
The piston
Brass 3/32" tube: Boring to 2.0mm
Well, yes! First there was a hole for 0.5mm axle – no photo left
Boring the edge a little for the stock move
Solder the washer, so that the valve ball is not thrown out of the piston.
Reseating the ball bed with 1/16" sphere inside
Edited by mir0n
And where a photo from the last messages? The pomp and without them looks good, but it would be desirable to look... :)
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Wait for it Garward - mir0n has "bookmarked" the pages so all his posts are in order without other's comments. He'll edit them when he's ready, but they won't show as "new" posts so you will have to keep looking for an update.
I did the same with my "reconstructed" Build Log of Vulture - I just added posts with titles and added pictures and text when I had the time to do so.
:cheers:  Danny
Cheers, Danny
Uri....its great to see how you built the pump.  I held them in my hands at the show and they are a marvel to look at and feel.  The "pump-action"  can be felt when you move the crank.
Thank you so much for posting.  I cant wait to see them on your brig.  You should also start a build log for the entire project.
I hope to see you again real soon.
Chuck
:cheers:  Danny
Thanks, Danny, I understood, I will wait. The pomp turned out excellent!
Best regards,
Garward
  • 1 year later...
Hi Mirün,
I must have overlooked that lovely bilge pump you made last year. It Looks fantastic and is so inspiring that a am thinking about alike....
Well done !
Nils
Current builds
-Lightship Elbe 1
Completed
