Thank you Jeff. Am following you step by step, its clever and also a challenge what you do! Am waiting for your new uploads.
Christos
Hi everybody,
If my english is correct, then I have just finished the gunwale and the bulwark.
I believe gunwalle is the top part of the bulwark... there where a sailor could lean his hands and look over the sea the sun setting into the horizon.
Edited by MESSIS
Gunwale almost done. The safety rails (incl.in the kit instr.) won't be fitted, am building the 1779 ship. Cannons on upper deck 6lb, on low deck 12lb and the swivel gun 1lb.
Edited by MESSIS
The Galley is on the gun deck. Had to take her with a winch on the ship and then push her on rollers in position. Now I have to prepare the roof of the galley with the ducts and the cooling panel.
Still working, even in the current heat! Very nicely done. You must be tired after dragging the galley around
Carl
@cogThank  you. its 32° C in Cyprus. But my shipyard is fully air conditioned. No am not really tired, I was using a mobile crane from CAT to move around the galley😂!
The roof of the galley is installed. Its a watertight copper panel, that was filled with water. Thee two copper ducts of the stove were passing through this cooling system, in order to keep the stove radiation as low as it was possible.
I hope you can see the water...🦆.. I have poured in.Its a vallego scenery liquid.
Edited by MESSIS
Main deck on the go. Belaying pins and tables, ramhead of the fore mast.... and ofcourse always dos and redos!
The copper of the galley cooling panel, went dark. It seems the cooper got the humidity of the vallejo scenic water.
So a new panel was remade.
Edited by MESSIS
Thank you Jeff for your nice words.Am watching your work,of which am anxious to see the outcome of your excellent modifications.
Wish you quick recovery.
Christos
I like the vibrant colours, what kind of propulsion did you install, for the use of a helmsman ;)
Carl
Thank you very much... its the vallejo paints. "Helmsman", is it the wrong word for referring to the man on the wheel? Propulsion on sailboats is the wind power!😊
Edited by MESSIS
Helmsman is good, but you don't need one without the sails if you are missing another form of propulsion.
Carl
Stem fnished. Lot of work.... lots of fan. The figurehead in place, the Lion with the coat of arms, the net, the gratted floor and ofcourse on top the two catheads (anhor windlasses). Sorry for the letters on the pic, its the cathead in greek... καπόνι! (kaponi)
Edited by MESSIS
@Louie da fly thank you Steven. Yes on the stern and also on the stem,in the lions hands. You must imagine, the scale is 1/89, so it was impossible to succeed  more sharpness. The stem coat of arms  is bigger, so its sharper than the one the lion holds.
Edited by MESSIS
