Hello my friends,
As the next ship I decided to build the famous english galleon built in 1577 Revenge, flagship of the sir Francis Drake during the Armada campaign in 1588 and mostly famous for his last fight with the spanish fleet in 1591 ( she was under command of Richard Grenville ).I think that´s no necessary to explain more about this ship :)
Now I decided not to build the ship from scratch, but I decided for the Shipyard model of this ship, re-released last year.  I alredy built this ship fro mte 1st release in 2009 - it was my first ship model after a very long pausem and because I love ships from this age, after re - releasing of this model I had no doubt about the next ship in my collection
I started the build immediately after receiving of the kit. The frame of the ship is laser cutted, but there are no all of the necessary parts cutted, several of them you have to cut out personally. You can see it on 2,3,4 th picture. Until today I completed the frame including decks, today I´d like also to grind the hull ( it´s necesarry - some parts are printed with excesses an because of 90 degrees of angles ). There are some little mistakes in some parts as they were in the old one, but nothing special.
Here are pics.
Jan
Finished:       Ark Royal 1588
                      Mary Rose 1545
                      Arabian Dhow
                      Revenge 1577 ( first attempt )
                      La Couronne 1636
                      Trinidad 1519
                      Revenge 1577 ( the second one )
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
On the table: Sovereign of the Seas 1636 - continuing after 12 years
All of them are paper models
Thank you Matti ;)
I glued the bottom part of first layer of the hull shape. I glued 5 mm strips of the paper on ribs before ( it´s very useful ).
Now I have to cut out and glue some gun carriages and glue them into the ship.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Thanks Matti
Gun carriages for the interior are completed. In my opinion they are produced too complicated - you will see just front of them through gunports. Shipyard could produce them just from four parts only ( as in some later kits ). All of them are recoloured.
Upper parts of the hull shape will follow ;)
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Nice work so far, Jan.  I'm looking forward to following along.
Very nice and very interesting. I've never seen a card model of a sailing ship, so I'll be interested in following this build. What is the scale of the ship?
Under construction: Mamoli Roter Lowe
Completed builds: Constructo Enterprise, AL Le Renard
Up next: Panart Lynx, MS Harriet Lane
In need of attention: 14-foot Pintail in the driveway
Thank you, friends :)
Stevinne: you´ve never seen? I ´ve build several ships, and all hulls of all of them are made from card.
Try to look here ( I just have a report from these ones ):
http://modelshipworld.com/index.php?/topic/1120-la-couronne-by-firdajan-card-1636-196/?hl=couronne
http://www.papermodelers.com/forum/ships-watercraft/7233-mary-rose-1511-1-96-a.html
http://www.papermodelers.com/forum/ships-watercraft/5326-ark-royal-1587-1-96-a.html
Some little problems appears. Because I built this ship some years ago, and there were some mistakes, I supposed they are solved in this reprint of the kit. They aren´t. Parts are just redrawed into Q3 format and textures are improwed in a better way.
After cutting out of upper parts of the first layer of the hull shell I tried to fit the on it´s place...and they didn´t fit ( as some years ago :angry: ) So I had to fit them by edges of decks, some gunports and by inner part of the railing on the aft. Then I had to slightly improve other parts of the railing too Now it looks quite good.
Then I start with the second layer of the hull shape - but now I was more careful and cut out it from the copy. The second layer has thickness cca 0,9 mm and it is possible to glue parts by edges and points - then they doesn´t work and the result is much more better.
Yesterday I start with oter parts of the second layer. As I maybe mentioned, I will grind the hull until smooth. For upper decorated parts of the hull I will use original parts for sides and bottom of the ship I will use strips of foil. I´ll try to make the planking effect
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Thanks, Anja :)
So, my friends, I did some work on the ship last days ( sorry, mainly nights ). I glued on the rest of bottom parts of the hull shape, then used a little bit of putty mainly for contact places and drastically ground it up. Then I painted the hull with the glue for a card I´m using - the hull is stronger then.
Yesterday I finally glued the upper original parts. Who knows me, know, what will be next, I will improve the final part of the hull using strips of foil to make a planking effect.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Excellent work Jan........ I'm really impressed with card models and especially your talent to build them..
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Thank you, my friends, thank you,  for your replies :)
Matti: it´s not comparable - there are two different ways, how to get a hull of ship. Simply said - with wood is much more work, and in my opinion the wooden model is in absolutely other level than cardmodel. And the rest of ship - the work is the same in both ways, I´m also using wooden masts and yards, ropes, etc. BTW, if you know my older projects - I´m mainly the scratchbuilder, and I´m working with plans for wooden kits ( Mary Rose is the exemption - this is my own project simply absolutely from nothing ;) )
As I said, I start with the final surface. Pictures says more. Now I have to cut out the foil in places of gunports, and patine the hull because of planking effect. You will see.
Jan
btw, the last pictures is my collection ( just hull of the Golden Hind and Sovereign are missing :dancetl6:  )
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Matti: yes, it looks :D
I glued the keel on the ship finally. Now I can to do some color improvements on the hull. Momentary I´m working on handrails ;)
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Thank youm my friends, for your replies :)
Today I glued handrails I prepared yesterday. the hull is closed now, there are no white places of paper ( except of ornaments ). Enjoy some pictures from today.
Jan
Edited by firdajan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Next step is done.
The "wooden " part of the hull is patined - and I got the planking effect. The bottom part of the hull is coloured too. Also the inner rails are gglued. The progress is still continuing :dancetl6:
Enjoy pictures.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Jan,
Beautiful work! Looking forward to seeing more of your build.
Eddie
<p><span style="font-size:12px;"><strong>"Be yourself. Everyone else is taken." - Oscar Wilde</strong></span></p><br />
<p> </p><br />
<p><a data-ipb='nomediaparse' href='<a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/2720-elsie-by-4whelr-modelshipways/#entry73752'>http://modelshipworld.com/index.php?/topic/2720-elsie-by-4whelr-modelshipways/#entry73752</a>'><span style="font-size:12px;"><strong>Current Build - Elsie</strong></span></a>
Beautiful work. The work that people like you and Doris and others that I have seen done in card is undeliverable. Please keep the pictures coming.
Wacko
Joe :D
Go MSW :) :)
Thank you, my friends, for your comments :)
I don´t have a lot of time this summer ( I´m working on absolutely different object ) but I made a little progress.
Bottom part of wales is glued, and I started the work on the galion.
That´s all at the moment, I hope I´ll do some progress very soon.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Hello my friends,
I made some progress again :)
The galion is finished. I had to make some improvements because of dimensions of parts, but it quite fits.
The rest of wales on upper parts is glued also ( so all of them are there finally ;) )
As the next part I´ve just started balcony - it will be reconstructed - I don´t like the graphics used by shipyard on this parts ( and, by the way, there is something different on the picture at the front of the kit :angry: ). As surface finish I used strips of foil. Now I have to produce all of ornaments ( letters E and R, fleurs de lis and flowers ). Why do not complicate some things:D  I tried to check dimensions of it with the ship - it fits.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Thank you, Matti.
Finally I finished works on absolutely different objects and now I have more time for the ship. During this period I did some progress: the balcony is finished, windows are done, stairs are done and the rest of railing on the maindeck is finished also.
Now I´m continuing in producing of another little parts :)
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Ledges aroun grating´s holes are slightly improved, and gratings are made I let the semi  - product for gratings cut out by laser to my friend here in Slovakia. I could to make them by myself, but these ones looks much more better ;) . All of channels are also cutted out. And, finally, yesterday evening I started the work on capstans ;)
Enjoy pics.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
