The more I read about the ship type "fluit" the more respect I get for the people who build them, both in the past and in the present.
What a difficult  shape to build
Congrats with this model Marcus
Thanks for all the likes and comments.
Small update.
Painted all the windows yellow ochre.
804410822_324FluitZeehaenwindowspainted.thumb.jpg.fa7f9133fb2116d34ac746f76a6df66d.jpg
Inserted the single and double blocks in upper area of the hull. The area where the single blocks are located will be painted 'An Dyk' green.
1375508787_322FluitZeehaensglblockinhull.thumb.jpg.69e3052b1edd0a7c1b3d9f1efaba2e61.jpg
1927943821_323FluitZeehaendblblokinhull.thumb.jpg.57b84e309cf3dea879fc456b2d8b6a96.jpg
I don't know the name of this but installed a small rectangular piece of wood with a hole for rope in between the upper wales.
Marcus
Current Built: Zeehaen 1639, Dutch Fluit from Dutch explorer Abel J. Tasman
Unofficial motto of the VOC:
"God is good, but trade is better"
Thanks for all the likes and wonderful comments.
Building the bowsprite. I find this part on of the most demanding exercise of building a scratch ship model. I always double or triple the pieces of wood that make up the bowsprite. I always break one or two.
I have glued some of the paper templates to the wood. I will make them out of walnut and cherry.
849588282_327FluitZeehaenbowspritecherry02.thumb.jpg.74085b5159ce4892b19f292c25335167.jpg
1157882176_328FluitZeehaenbowspritepear03.thumb.jpg.31ff334e61b9e409d5d25c654e2d3472.jpg
407251386_329FluitZeehaenbowspritetemp04.thumb.jpg.9cd277e6b95d2b256aded490e4528b05.jpg
Marcus
Cut out and rough sanded all the cheeks from walnut and some extra pieces from cherry and basswood. I use the basswood and cherry pieces as practice. Once these pieces fit I will take and compare them to the walnut cheeks, fine sanding where needed and glue them together. I know this is a lot of work but it is my way of getting it right
It has been warm these last two days so all the cutting and rough sanding was done outside.
Marcus
After all the cheeks were rough sanded, I started to dry fit the bottom cheeks. When everything fit I glued each side in place. The next day I sanded the bottom cheeks and dry fitted the second layer of the cheeks, glued in place and the following day sanded that and did the same for the 3rd, 4th,and fifth cheek layer. This process has taken me 3 weeks.
1355538102_334FluitZeehaenbowspritepc1.thumb.jpg.b3f7065f2f8dc7d3b7eb4d18ffddf300.jpg
1083846592_335FluitZeehaenbowspritemonster.thumb.jpg.e6ffea7ef99074aac8705f4a68490a92.jpg
201342936_336FluitZeehaenbowspritemonster.thumb.jpg.d8bb2dc076e9869f11c19082f615f0a4.jpg
1204640623_339FluitZeehaenbowspritepc4.thumb.jpg.d2a27c4a3f764f8121e1d5284a1c5fde.jpg
Also my first attempt a lion from Sculpey, looks more like a monster. I see that it needs work.
With Christmas did not work much on the Zeehaen. I spent several nice days in December outsie with my newly acquired bandsaw from WEN. Most of the wood I got from my woodworkers club has been sawn in 3, 5, 7 an 10mm planks.
Next will be the grating that is inside the cheeks.
Marcus
She's looking really good, Marcus. Having followed your build, I've decided that no matter how beautiful a fluit may be, I really don't think I want to take one on. Just TOO difficult getting the shape right. I take my hat off to you for your persistence - and your courage in ripping stuff off and starting again till you get it right. :dancetl6:
Steven
Thanks for all the likes and Steven, thanks for the compliment.
Speak of ripping stuff off, after installing all the cheeks I noticed I had forgotten the anchor rope holes. So without removing the bowsprite and the cheeks I removed the little deck, drilled 4 holes with great difficulty, reinstalled everything and need to let dry overnight so I can sand and shape the area.
1928739541_9a1FluitZeehaenbowspritere-do.thumb.jpg.18d49e1e6441499cab609eacf34e0975.jpg
1255249341_9a2FluitZeehaenbowspritere-do.thumb.jpg.ae442fbfe69085832bbb37b98a293e03.jpg
1739072757_9a3FluitZeehaenbowspriteredo.thumb.jpg.e7c007d9fbd35fa6038b2717092c03df.jpg
818863448_9a4FluitZeehaenbowspritere-do.thumb.jpg.5bcab98bc3ca5190f49436885385df61.jpg
Marcus
3 hours ago, Meriadoc Brandybuck said:
Recently came across this and I'm loving what you're achieving here!  I'd like to build a fluyt someday (perhaps after some practice with one of the Kolderstok kits).  Can't wait to see more of how this lovely lady takes her shape.  The beakhead and head timbers are coming together quite nicely!
Thank you so much for the compliment.
Kolderstok is in the process of creating a Fluit. It is the same one as I am building here.
Marcus
Marcus,
It is visible that your skills are improving fast, and I also think that your new equipment gives you an extra boost.  Congratulations.
By the way, I wonder how the Kolderstok model will be like.  What scale will it be?  Probably smaller than your model.  Anyway, it will probably be a better model than the 2 existing flute models (Segal's Baleinera Olandesa and Euromodel of Como's Derfflinger)  but then again  these models cry for improvement, which of course is part of the fun.
I think it is time for me to restart my own model, the now named Poolsterre!  I noticed that it is actually a little more advanced than the latest posted pics.
Tot ziens, hoop ik.
Jean-Pierre,
Here is the link. Big discussion on the reason why the Fluit was built the way she was built. As so many sources say that her narrow deck was so a Fluit payed less toll. Totally Wrong.
https://www.modelbouwforum.nl/threads/17e-eeuwse-fluyt-kolderstok.274136/
Marcus
Thanks for the link, Marcus.  I read that there were 2 build logs on Modelbouwforum but could not spot them.  Too bad!  The discussion why their deck was so small is not conclusive.  In my opinion, and I am sure you will have come to a similar conclusion, there must have been a very obvious reason to build such an intricate hull shape.  The original merchant ships would, I think, been made as simple as possible to reduce costs.
Another possible reason may have been stability at sea, or quite simply, ...to have the chain plates preserved from contact with the quay (kaai).
Happy building.
Note:  I thought the kit by Kolderstok was going to be the Zeehaen, and that Mr. Hoving was making the drafts.  But the draft on the forum page shows a ship without a beak, which the Zeehaen has!
JP I was thinking amongst the same line, i.e. stability. Getting a wide hull, has two advantages over a v-shaped one: the centre of gravity is moved further down, it can carry more cargo, and it is far harder to make the ship tilt with a comaparative wide lower section. I don't think that protecting the chainplates would be a major reason to build the hull in such a way.
Carl
Worked on the rudder and created 6 gudgeons and pintels from brass bars which were 1/64" thick and 3/32" wide.
The top 3 were sanded lightly and painted with matt black oil paint. The bottom 3 and the bottom part of the hull will be painted dirty white.
Started working on the different decks. Lots of measuring.
Yesterday it was in the upper 40's so I put the bandsaw outside and cut 3 inch cedar planks down to an inch thick each. Made 2 birdhouses. They will probably be occupied by the many wren's I have.
Marcus
I was reading the book from Mondfeld and on the pages of the "Head" he talkes about the "seats of ease", the latrines on a ship. He says that modelers rarely add this item. There is a modeler on MSW that built the Victory and he has added them on the head.
I checked the plans of the Zeehaen again and wondered if Cor Emke had added this to the head. I did notice a circle on each side of the head and wondered if that was it.
So I researched examples on other ships and it is rare that you find anything about it. I did find an article about Queens Ann Revenge wreck and divers had located a porta potty of that ship.
I decided to create 2 seats of ease and installed them on the head.
Marcus
Marcus,
It does look like those are the "seats of ease" in drawing.   Your solution looks good.
Maybe this was an early form of seats of ease (seats of "not so" ease 😉)
Added a layer of sanding sealer to the outside of the hull. The advantage for me is that when I paint any area of the hull and accidentally get paint on an area which is not to be painted, it wipes off easily without leaving anything behind.
The blue thing is a silicone ice cube tray and it is where I keep the paint I use in.
Painted the upper area of the hull and the little windows on the stern.
Colors used:  Yellow Ochre, Chrome Oxide Green and Cadmium Red Deep Hue.
1190637271_360FluitZeehaenBalticbirchply.thumb.jpg.8d2a472bc6ea41227f624cbf28dd0cad.jpg
I ran out of maple for the deck planks so instead I am using Baltic Birch which is also nice and light in color, 1/32" (0.79mm) thick. Cut strips of 200mm L, by 6mm W and darkened one edge of it. I know it is not the conventional planking method but it works for me and the end result is about the same.
Next I will start making the different deck items.
Marcus
I wonder what is easier, sculpturing it from model clay or carving it out of wood? I plan to use sculpturing model clay for my Neptune build, but am ver afraid to produce "monsters"...:wacko:
Looking forward to seeing your next attempt! And if you could also let us know how you did it? :imNotWorthy:
Rgds,
Radek
RdK - I just had a look at your Neptune log. That's a LOT of carvings!
Whether you use sculpey or carved wood, don't expect your first effort to be satisfactory. But keep it - to remind yourself how far you've come.
Given the large number of carvings, I'd think sculpey would be preferable because it's easier to work. Carving wood is very labour-intensive (don't ask me how I know - just look at my dromon build log). The precision of finish with sculpey isn't as good, at least initially, but in my view the big advantage is that you can "rough out" the shape of the item much more quickly than with carving, and with experience you'll get better and better at it. And when it's dried, you can come back to it and tidy up the detail with a scalpel and sanding.
You will produce monsters to start with, but unless you're very good with carving tools you'd do the same with wood anyhow. So my recommendation would be to try sculpey and see whether you're happy with it - and don't let a few setbacks put you off.
Steven
Steven,
Thanks for the comment and I agree with you on the Sculpey subject. I'm just not very good with carving figures. I attempted this with basswood in my Statenjacht Utrecht built and most of the carvings look more like 2D than 3D.
What I like about building just merchant ships is that there is a minimal amount of ornamentations. The Zeehaen has a few here and there.
On a Dutch site, modelbouwforum.nl there is a advanced builder who built "het wapen van Hamburg", he has  posted a tutorial on how to do faces in Sculpey.
Marcus
