12 minutes ago, Landlubber Mike said:
Take a look at my Unicorn/Lyme log linked in my signature.  I agree with Bill that the Corel kit is of the Lyme class in Chapman’s Architectura.  My log goes into the many inaccuracies of the kit.  Still builds into a nice model though as some of the logs on here show.
Very well said Mike,   very similar  class to the Corel Greyhound  kit - quite a few of us  tried to bring that kit to life.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
15 hours ago, Thistle17 said:
Nice work harlequin! My Unicord, a 1980's kit is sitting in a container maybe never to finish as the materials then were quite second rate by some standards. Maybe, just maybe you can inspire a restart for me with your good works.
Joe
This one of mine is ancient and to be fair it seems to be going ok....go on give it a go.....you know you want to...
this is roughly what the transom will look like when installed. I will probably paint the background black....The outer decoration is a cast metal which i have heated to soften then bent to shape....overall it doesnt look too bad......the new unicorns have a precast transom which makes this stage easier....im happy enough with the result.
Great work mate  - takes me back to my  Greyhound/Lyme  build.
OC.
Current builds
Completed works.
OC.
those were the days....i have just dusted Greyhound and looks in fine shape.
Indeed mate.
OC.
Current builds
Completed works.
18 hours ago, SpyGlass said:
Good heavens - just seen your log - THAT takes me back.  I built Unicorn it must have been at least the early 90s if not earlier.
The black wood supplied was discoloured and they supplied a ridiculously over large amount of replacement - I still have about 20 strips left.  I think it is actually dyed but it is a nice true black throughout so can be sanded without discolouring.
I have used on severa builds where a bit of a contrast without paint is needed
 I was very pleased with the end result .  My figure head  was total rubbish compared to yours !
the kit is ancient SpyGlass....i bought it for 15 quid so no pressure to complete.....they call this black strip fibreboard....some of the second planking is very brittle, but I am going to continue with it and see what happens......it is going ok I think.....corel kits have a lot of detractors but i actually dont mind them at all...
Unicorn doesnt have a stern post so I took a gamble and shortened the length of the hull to accommodate a stern post. Overall it has ended up a strange shape but with the addition of the rudder I can live with this peculiarity....the colour is different, but I can do something about that later...  the hinges have yet to be fitted.
Edited by harlequin
Transom being prepared for fixing.....second planking will probably be finished in the next couple of days....then a good sanding to smooth out the whole hull.....the transom will be fixed and allowed to dry thoroughly before the windows and decorations are fixed....a dry fitting seems to suggest all will be ok.
Edited by harlequin
