The Peterboro Canoe by Duanelaker - FINISHED - Midwest Products - 1:12
2 hours ago, Duanelaker said:
whenever model expo had a sale that dropped a boat below 100$ I would end up buying it
I keep eyeing the Dusek Greek Trireme whenever model expo has a sale. A few times it has come close to that $100 mark and I’ve almost fell victim to the sale. I work slow, so I’m doing my best to hold off buying models until I’m close to finishing what I’ve started.
(...and I keep buying upgrades to my build so there goes the ship budget anyway 🙂)
Edited by VTHokiEE
Link to comment
Share on other sites
The biggest two problem with all the kits I bought are that 1) they take up an incredible amount of space and 2) it makes it nearly impossible to decide which one is next 😞
Link to comment
I'd say first of all, finish the ones you're currently working on. While you're doing that take a look at each of the other kits you have and ask yourself if that kit it special enough to you that it is indeed a keeper. I've found that even "easy" models take quite a bit of time to build well and I'm not willing to put a ton of hours into a model that isn't that special to me. In the end, I'd rather build fewer models that are special to me and, because of that, I'll do a better job on them and be ok with investing a lot of time into them.
I've got a few models on the shelf that I bought that I'm not so sure about anymore so I think I'm going to put them up for sale pretty soon. It will make it much simpler for me to decide on my next build also.
Bob
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
A few update photos....I did end up switching up to CA glue as it is kind of nice to use due to the set time being instant and the planking becoming more difficult.
Link to comment
I ended up filing the planks after I installed them as it seemed easier then filing the planks in my hand.  Seems to be working ok.  These pictures show how I trim and fit the opposite end as I finish each plank.
Link to comment
So far it is going well...I think I could do better, but these are level 2 for a reason 😝
here’s some fat cat pics...don’t have to worry about her jumping up and getting into my rigging 😂
She’s not dead, she’s just a very sound sleeper...and it’s cozy in front of the wood stove insert....
Link to comment
It's looking great, Dave. I used medium viscosity CA and it worked well for me. That hull will sand up nicely.
It looks like your cat has had a long day and is out for the night!
Bob
Bob Garcia
Current Builds:
Link to comment
The worst too is that by the time you finish one, you likely bought three others to make deciding even harder!
Edited by Justin P.
Link to comment
Hahaha...too true!
Bob
Bob Garcia
Current Builds:
Link to comment
Link to comment
Link to comment
And more...quite difficult to keep everything even but I tried...
Link to comment
Very tidy work,   always difficult getting the first hull planking right.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
I ended up glueing the frame in one spot because the bottom of the boat was flaring out...did pretty good trimming the pieces to fit...
Link to comment
And it is off the frame...not too bad, feeling a little better lol
Link to comment
OC.
Thanks!  I wish it was a little tidier lol hopefully after sanding and clear coating it’ll be nicer.  Love your black pearl btw!
Link to comment
Your  doing just fine,   thank you for your kind words.:cheers:
OC.
Current builds
Completed works.
Link to comment
Great job that will look wonderful when it is all sanded smooth and clear coated. Got a shipping update today mine should be here tomorrow.
Link to comment
It's looking great, Dave, and it brings back memories of how tedious the planking got when I did mine also. It will sand up nicely. You're making fast progress.
Bob
Bob Garcia
Current Builds:
Link to comment
Bob
Was super tedious...the last few were tough.  I was impressed how light it is off the frame!  Lots of fiddly things to go.  Wondering how I should mount it or display it.
Link to comment
With how clean your work is I’m sure it’ll be a beautiful piece!  On my Canadian I think I might stick with carpenters glue...I’m not sure I’m good enough and can keep it clean with the CA
Link to comment
Couple of  columns  or perhaps  a couple of frames  - depends if you want  them decorative or invisible?
OC.
Current builds
Completed works.
Link to comment
OC.
I don’t mind it being visible, I’m thinking I’d want the canoe tilted a bit...just can’t picture it with the paddles and such
Link to comment
Could try a couple of  columns/pedestals  one  slightly longer than the other to get the lean you want?
OC.
Current builds
Completed works.
Link to comment
Link to comment
Looking good, Dave! It's interesting that the frames on the Indian Girl Canoe are much wider than the ones on the Perterboro Canoe.
Bob
Bob Garcia
Current Builds:
Link to comment
Bob
Do you mean the distance between the frames or the actual wood?  I’ll have to take a look at the Indian girl plan
Link to comment
The actual wood frames are wider on the Indian Girl:
Bob Garcia
Current Builds:
Link to comment
Well I haven’t thrown it in the wood stove yet 😂. There are a lot of these frames...onward.
Link to comment
The repetition in model ship building can test just about anyone's patience except maybe the Dali Lama! Drilling around 700 little holes and putting a sliver of fishing line in them to simulate nails on the Medway Longboat nearly sent me to the looney house! Hang in there,Dave, she's coming along!
Bob
Edited by BobG
Bob Garcia
Current Builds:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
