One thing that I do not like about false decks, and this is an issue in most kits, is that while the deck can be pinned down wherever it lies atop a bulkhead, the little flaps in between the bulkheads have no such substructure; they can still flex, resulting in a slight undulation along the deck edge. The "waviness" might not be readily visible, but it can play havoc with things like properly aligning cannons with their ports. Rubber bands will make that problem worse, because of course they will exert a downward force in exactly the wrong places, i.e. between bulkhead extensions. To properly address the issue, some kind of ledges need to be provided between the bulkheads for the deck to be fixed to.
I did try pinning and my thumbs were not happy with me as it is pretty tough to push those pins in the plywood. I'm still thinking about nails but not sure how hard they would be to pull back out. Using weights might be the only reasonable answer. I really appreciate the ideas!!!!!
Edited by Gremreeper1967
Try push pins -- the kind with the plastic head. And be sure to drill pilot holes to make the job easier and reduce splitting.
Hey mate g'day
I built the adventure  about  2 years ago and yes I did nails and wood glue  enjoy  your  build   cheers snowy
5 hours ago, Snow said:
Here was was my 1st  ship build she took me about 13 months  and I put a thread  around  the  sails and hand sewed the lot as you will see enjoy
Snowy, I read through your build log, it helps to clarify some of the instructions for me.
Search Model Expo for a nail driver. I’ve had one for 30 years. A great tool for pushing small nails. Drilling a small hole prevents splitting. Also, I saw an identical driver at Ace Hardware at about $5 cheaper than Model Expo while doing a quick Google search this morning.
Thanks for the heads up ragove. I have a drive for in any day. I used push pins yesterday as was recommended by another member.
Decking is done and started on planking the hull. Im having issues with the lining the hull technique. I understand all of it until it is time to cut the plank. Can this technique be used with planks at 5mm wide? I don't see how the curves can be cut with a narrow plank.
2 hours ago, Gremreeper1967 said:
First layer of one side done.
I’m not certain if you did or not based on your pictures but I have seen it recommended that you plank both sides at once to minimize the chance of the hull warping. I don’t have enough experience to know how critical that is but it might be something to keep in mind in the future. It’s looking good so far!
Hull warping never crossed my mind but I will keep it in mind for future builds. Thank you for the tip.
Hi mate going  great
At least now we have  more time  to build
Happy  modelling
Cheers snowy
14 hours ago, Snow said:
Hi mate going  great
Happy  modelling
Cheers snowy
Snowy, we started watching our grand daughter since the closed the day care so I don't get to work on it quite as much right now. She is two and I did have her helping me drill some holes the other day. She is going to catch the bus real early, lol.
