Very clean and sharp!
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Hoss and Wally thank you both appreciate you taking the time :)
While waiting for the brass I had on order I continued on the deck fittings. Not knowing a lot about Capstan's I did a little research and got a little help from my friends and now know how at least it works. I made up the capstan pretty much as indicated in the instructions. I am going to flip the head upside down on the drum tho to give me a little more height for the companionway. Haven't detailed it at all yet either ~
IMG_3776a.thumb.jpg.3cff11bcdbfa89aa8b6aee2199fd0e76.jpgIMG_3780a.thumb.jpg.75220122c6b4be451c1fe89f4175303a.jpg
Got the brass in I was waiting for and made up a carronade prototype. Couple pics showing the sled mounts which were made by soldering a brass tube onto a brass flat bar strip then slicing thin diagonal strips to act as sled mounts. For the carronade I just used a short piece of brass tube soldered on. I know it doesn't look perfect but It is pretty much hidden under the carronade. I couldn't use silver solder because the caseys brass black won't affect it.
Nothing cleaned up or glued on yet...
IMG_3781a.thumb.jpg.4b4ecb68f8ead575d663474e53611b03.jpgIMG_3788a.thumb.jpg.dde3fa16bbad068cbc4928e33bee4745.jpg
Stay the blazes home. Stay safe :)
Capstan and carronades look great! When I built the carronades one of the biggest problems I had was that they had a tendency to end up a bit too high in relation to the gun ports. Hopefully you don't have to deal with that issue.
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Hi Thomas, great to hear from you :) . That is good to know I will be trying out a the two I've done up before I continue and be on the look out for that issue. You milled your drilled blocks in a bit too so that makes me a little nervous will have to see what happens. I forgot you milled them into the underside of the carronade. If mine end up looking to high I could file a grove fairly easily which would make soldering even better and easier. Thanks for the heads up!
10 hours ago, jamcdonel said:
Pearwood makes for beautiful planking
2 hours ago, Overworked724 said:
Love the wood!
Believe me it has been a treat working with pear. The guy who cut it for me did such a precise job, the planks were all exact. He is really happy with how it came out to. Thanks for the great comments :)
Thomas it was exactly as you predicted. I tested one carronade out in the ports and it was sitting to high. I removed the tube filed into the carronade with a round file and re-soldered the tube inset into the carronade. Big difference. I will go a little bit deeper with the recess on the next ones.
Appreciate the heads up. Here are a couple before and after pics
Original before filing First Pic
After Filing Second pic
Original Before Filing
After Filing
Shots taken with carronade set level with the sled
Thanks again, Cheers Robin ~
The second carronade is as good as it gets. Well done!
Thomas
On 4/23/2020 at 10:11 PM, Retired guy said:
The second one does looks way better Robin, and love the deck planking as well 👍
Thanks guys, trying to get the hang of it :) Here are a couple of pics with the breech ring added and the sleds detailed. Soldering the ring could be a little better. Hopefully practice will help lol.  I went with a very thin slice of brass tubing, drilled and inserted wire to make the elevation screw handles. Does they look a little heavy maybe?
914125465_IMG_38271.thumb.jpg.0153f810a8851cf42b024b10a252ade5.jpgIMG_3842.thumb.jpg.66bdb742877b5911a2c434ba63eafd38.jpg
Edited by NovaStorm
Hi Robin looking at the screw it does look a little heavy, just looked on the drawing I have on the 68 lb Carronade on the Victory by Arthur Bugler, it says it is 2" elevating screw and the breeching ring was 4 1/4" dia, so for the screw in 1/64 scale it would be 1/32" dia and ring will be just over 1/16" dia but I am not sure what size of gun yours are.
Regards
Richard
10 hours ago, Retired guy said:
Brilliantly done Robin 👍
Regards
Richard
lol thank you my friend. Kinda flying by the seat of my pants here. Tinning the wire for the breach ring really helped with soldering and I managed to get them quite a bit smaller. The one from the first post is the 5th one in from the bow. I am starting a new wish list for a proper pliers set for metal work. The cheap ones I have don't cut it. Only 8 more to go!
Getting those carronades detailed is a lot of work! Syren has 16 plus 2 long guns . . . just imagine building a Victory 😉. But your carronades really look good!
Thomas
Thomas
Thanks Thomas, they are a lot of work and yours are like little individual works of art! I might be missing a couple ring bolts with split rings I think you have on yours. They don't show on chucks plan. I will have to do some more checking... Cheers thanks again for taking the time.
Ok I couldn't take the bling factor on the carronades any longer. Last evening I got into blackening the carronades and one cannon I have done up for the port side. I was pretty nervous given the time spent on them and the sleds, so it was going to be a bit of a do or die moment. Well the results came out fantastic I think. Took a little trial an error to get the results I wanted and I hope you like them as well.
I started out soaking the pieces in a solution of Sparex #2 in a warming pot for about an hour and a half to clean them. Then they were dried and placed into a container of (straight) Casey's brass black for ruffly 3/4 of an hour. I then removed them from the caseys and rubbed them down with a paper towel which cleaned off the excess and produced results that were not where I wanted them. This was fine as I then placed them back in the casey's again for about 1/2 to 3/4 an hour and then removed them a second time and again rub off and polished them with a paper towel to get the final result. Here are some pics of the outcome.
IMG_3883a.thumb.jpg.8c877bda6355c6fac36494dddcb62196.jpgIMG_3885a.thumb.jpg.d6149a5e57b818f69dcfb7534ed9656d.jpgIMG_3888a.thumb.jpg.56ef74aed14951205cff8d2b1283027a.jpgIMG_3889a.thumb.jpg.40795fe21cbb2601aac267b50edf7913.jpgIMG_3891a.thumb.jpg.0e59537d13ee7a30882aed99d994cf9e.jpg
They look lethal! Well done.
We are what we repeatedly do. Excellence, therefore is a habit, not an act.
~ Aristotle
I could carry, paddle, walk and sing with any man I ever saw. I have been twenty-four years a canoe man, and forty-one years in service; no portage was ever too long for me, fifty songs could I sing. I have saved the lives of ten voyageurs, have had twelve wives and six running dogs. I spent all of my money in pleasure. Were I young again, I would spend my life the same way over. There is no life so happy as a voyageur's life!
~ The Voyageur, Grace Lee Nute
Blackening sometimes can be a bit tricky, but it makes a big difference. Yours turned out very nicely!
Thomas
Today I gave er a good cleaning followed by a minor paint touch up! Made up the stern transom port covers, painted waiting to dry.  Then I did up a signage proto by mounting ``Syren` onto a thin black board. I kinda like it because now it is more visible with more 3d. This is just a test using 2 sided tape  :)
IMG_3953a.thumb.jpg.8ca96f8f8819023e2a0b64063e8db91a.jpgIMG_3939b.thumb.jpg.97dcb648ddf6621bfc7acd4d5aa5439f.jpgIMG_4005a.thumb.jpg.48bb02195d963695da26cadd09ffdb94.jpgIMG_4011a.thumb.jpg.d5c1d44128fb9393dbb5ecf1b0df6978.jpg
24 minutes ago, Retired guy said:
Got some of that Birchwood Casey Brass black it works a treat, canons have come out great Robin 👍
Regards
Richard
8 minutes ago, egkb said:
Wow .. I keep on coming back to that Deck .. That is magnificent work right there!
All The Best
Eamonn
Thanks for the great comments :)  I never get bored of looking at the deck Eamonn. Plus I managed to finish the waterway at the stern. So it is complete now.
Richard I was very pleased for my first time out using it. Cheers
Busy couple of weeks with work but here are some picks of what I've been working at. The stern davits I made out of pear are installed. Tested out the transom post covers. Had a blast making the pumps up which I am pretty pleased with. Added lug nuts to the cannon wheels. Hope you are all well and staying out of trouble!
IMG_4023a.thumb.jpg.345b2bd69b591d27f7dd25df16f705d0.jpgIMG_4039a.thumb.jpg.461792b1bf435aec580c66d673bf3f1f.jpgIMG_4048a.thumb.jpg.b171ddecf93b6e62090061f46d824f0c.jpgIMG_4049a.thumb.jpg.a16b4791f8390cd2e0e2a1e702dcd963.jpgIMG_4065a.thumb.jpg.c9583211fcda210ab4662ee8d669dfc0.jpgIMG_4078a.thumb.jpg.793b2fc5374ca76c7c94dace4fb1873c.jpg
3 hours ago, NovaStorm said:
Really like this idea for the stanchions! Going to remember it for when the time comes.
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
4 hours ago, Retired guy said:
Very nice update Robin and do like your pump great job my friend
Thanks guys appreciate the comments :)  Wally if you haven't got this LINK for your dremel or something better you can use, it was probably the best $55 bucks I've spent in a while. Highly recommend.
Cheers ~
