Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
M1A1 75mm Pack Howitzer & Prime Mover by Egilman - Vision/Tamiya - 1/35th Scale FINISHED!
1 hour ago, CDW said:
Really like the little Willys Jeep. Nice kit.
Hi Craig, I agree, a very nice kit....
Quote:
9 minutes ago, Jack12477 said:
I think I also have that same kit in my completed models stash.  Will have to do a little rummaging.  I know I have 3 variants of the Jeep.
Your welcome to post a pic here if you like Jack, I'm sure it came out beautifully.....
Quote:
I'm not so sure about the "beautiful" part, it was from my very early days of armor modeling. I will try and get a photo of it/them and post it.
Ok, First three steps... Engine & Frame, Running Gear then Suspension & Exhaust....
Engine and Frame...
Running Gear...
Suspension and Exhaust...
Next up, we start on the Body.....
Onward....
Quote:
Okay,  I found the 3 variants I built years ago.  Here's the 3, the one on left is I think the one you are building EG , middle one is the Vietnam era one I almost include in my M16 Diorama, and the one on right is the TOW version which seems to be missing a few parts as is the one on the left - missing machine gun. And all are showing the wear and tear, dirt and grime  of mounths on the battlefield.
Thanks for letting me post them, EG
2 hours ago, Jack12477 said:
And all are showing the wear and tear, dirt and grime  of months on the battlefield.
Yeah they have been soldering on for quite a while my friend...
Thank you for posting them...
Quote:
I took this at an airshow last year  - not sure if it helps?
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Yep, they are the British versions, (markings and equipment) but other than that they are the same....
They have fans worldwide....
Thanks OC....
Quote:
Ok, step four, initial body work......
Body pan....
Radiator & Headlights
Firewall & Tailgate....
Taillights!...
Sitting on it's chassis....
Beginning to look like something now, next up Seats and Dashboard....
EG
Quote:
hey gang!   again....late to the party!   that's a neat little cannon you built there........my word....even come with a few shells  ;)    rafters beware!!!!!   at least I'll get to see the Jeep.........it's like a ship you know........'cuz  it's all in how you outfit her  :D   off to a great start  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Why thank you Denis, I was thinking about making up a little ammo crate for those and sit it in the back of the Jeep.... (WWII they used wood crates for the shells)
Glad to have you join in.....
Quote:
sounds like a great idea  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Small update...
Got the seats in and the body mounted to the chassis. still waiting on the dullcoat to dry on the dash sealing in the dash decals....
And a comparison of size.....
Next up finish the Cowl and tires & wheels....
Thank you all for the views, comments and likes...
EG
Quote:
Ok put together a few more details as time allowed...
Wheels on and body mounted...
Some of the finer details added to the engine compartment and rear ....
Decided that I will mount the M1919A4 gun and it's pedestal mount... I saw a lot of images of the Jeeps with the 101st on D-Day had the gun and the wire cutter so I will include both..... as far as the gun, it seems like the only pics taken were ones of them loading the thing on gliders, or in C-47's, none of them in actual use..... That's a shame cause for the first employment in europe the AB divisions primary artillery support was this gun..... Makes one think that the AB division didn't have anything other than what they jumped with... which is not correct at all... In fact they all didn't jump many battalions came in on gliders rather than jumping out of airplanes.... We always hear about the pathfinders and parachute infantry regiments, we never hear about the glider infantry regiments which in many cases took twice the casualties than their silk hung brethren...
Anyway, almost done.  Researched the Artillery rounds that came with the gun, they are M48 HE rounds 5 of them. in WWII in Europe they were delivered in wooden cases, two to a case and they were in protective tubes black in color with a yellow tape seal..... the only time there were shells out and about ws when there was firing going on, other than that they were never removed from their protective tubes..... So there is really no need for exposed shells in the back of the jeep..... although I may still make up a couple of crates and some of the other equipment used with the piece....... I guess the gun was meant for a diorama with a crew manning it...
Next up finishing the aft details, mostly grab handles, hood, windshield and weapons...
Onwards...
Quote:
Looking good mate   - not far to go now.
OC.
Current builds
Completed works.
OC.
Thanks OC, life interuuptus is trying to rear it's ugly head again but I'm holding it off...... {chuckle}
Quote:
"Fight the good fight"  get a load of kits out  put them on the table  and say  -  "Priorities  - must get on with them now"
OC.
Current builds
Completed works.
Hi Guys, final update before the finish....
Everything is together, decals on, ready for its final flat coat. (must sit overnight to allow everything to completely dry)
I decaled her for the 82nd Airborne Division, 319th Field Artillery Battalion, Battery B, Truck 4 with one of four M1A1 75mm Pack Howitzers. Operation ELMIRA, 2100 hours, (two hours before dusk) June 6th 1944. The second glider borne assault reinforcing and supporting the 82nd Airborne troopers around St Mere Eglise....
The hood is still in future that's why it appears a bit greener than the rest of it. I need to add a few items that all these jeeps and guns had as equipment but wasn't in the kit....
Rope looped over the front bumper, various rods and gun parts that would be strapped down to the trail, and maybe a little cargo in the back of the jeep....
When finished I'll do a photo array.....
Thank you for the thumbs up and comments while following this little build...
EG
Quote:
Very nice brother  -  spot on with the details.
OC.
Current builds
Completed works.
8 hours ago, Edwardkenway said:
Great work EG, looks good 😁
Thanks Ed, I appreciate it....
Quote:
7 hours ago, fnick said:
That's a super little build!
Nick
Thank you Nick, for a tiny item, it sure gets the modeling level up there it's like 50 parts in a space of 3.5 x 2 inches.... and the gun was 45 parts at least.... It's not a hard pair of kits for an experienced modeler and without RL it would have been done in two days mostly waiting on drying time.... So you're absolutely right...
An impressive little kit....
Thank you..
Quote:
OC.
Thank you my friend, I tried to get it as close as I think it would have looked, unfortunately there are no pics of this available online. (but I'm sure they exist in someone's photo collection)
It's a situation that HAD to have happened, the Horsa Glider loadings were set up that way.... Shame that no one seems to have took a pic...
Thank you for following my friend....
EG
Quote:
Again, a great looking build EG.
Unfortunately the incidents that are the most desired in combat are also the times that most if not all the people involved are pretty much busy with other matters they feel are important. Pictures are not usually high on that list. :(
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thanks Lou, It was a fun build even if a short one... and a bit of a challenge.... Sadly though as the 76th Anniversary of what is depicted is but a week away, it is dedicated to those who took many shots so those who didn't get the shots I was looking for could live...... context is everything....
Thanks goes to all that served.... WE owe them more than anyone can return...
EG
Quote:
Nice build ! Nice model !
Now when do we get to see the diorama of the crash landed glider with the jeep and gun exiting the tail ?   😊😊😊
The problem with that brother as you are well aware of is building the two sections of aircraft. You need the fuselage section right behind the wing to represent the exit, and a complete tail section which was tossed to one side... the span of the horizontal stabilizer alone would be close to a foot in 1/35th it would have to be  on a base at least 18"x 12" at the absolute minimum and probably more like 24"x 24" to do a proper job of it...... I suppose it could be set up as it's own separate shelf in the display case...
One of those subjects that would be great, if you had the space to keep it... I do believe that someone produced a paper kit of the Horsa in 1/33rd scale, that would work I suppose.... (building it in plastic using the paper as patterns)
I guess Bronco  does a 1/35 injection Horsa Mk1 .... (amazon, check the price)
Kit Review...
Quote:
The gliders used in WWII were pretty simple and you shouldn't need the whole thing to do a Diorama as they unloaded from the nose.
World War II CG-4A Glider Exhibit | U.S. Army Center of Military ...
In the case of carrying a Jeep, I even wonder if one glider carried both the gun and the jeep.
CG-4A - Air Mobility Command Museum
Would this do for a set of plans?
https://outerzone.co.uk/plan_details.asp?ID=6106
https://outerzone.co.uk/plan_details.asp?ID=6763
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
That pic is of a Waco Glider brother, (in British service known as the "Hadrian") and yes it could only carry one or the other.. the Airspeed Horsa Mk 1 is twice as large... the USAAF as well as the British used both...
Four Horsa's and a Waco (Hadrian) in the same LZ...
You can tell the Horsa's from the separated tails, it's how they unloaded vehicles....
Quote:
