3 hours ago, Canute said:
OC, coming along nicely, mate. Love the wire detail in the canopy, too.
Thanks Ken,     yep thats engraved into the transparency.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I got a bit more done today  - I started by painting the different fittings in Black, then I touched up the canopy  farme edges  and did a bit more detailing,  then I decided to fit the tiny transparency parts  - the top/bottom nav lights and the Two wing  lights - here is where I encountered my first problem  - "Boy are they fiddly to handle and position the right way round"   hence I dropped the first one  down onto the carpet joungle  - took me a good Ten minutes to find it  on my poorly knee,  this was quickly glued in with a kind of  - "You are going in even if your the  wrong way round"   then I turned to do the other  side - same procedure  but this time the tiny little thing snapped in Two,  so I just glued the  one half piece in and worked on filling the remaining cavity with  Vallejo Putty,  gently bit by bit assisted with heating and gentle sanding - then more filling/sanding  "You see where this is going"   there was a slight edge around the nav light covers with rivets - well not anymore  as I had  no way of controling the sanding over a  small area.
Anyway they are both smooth and uniform on both wingtips  awaiting a quick blast of primer and top coat  just over the extreme wing tips.
When dry I will mask and paint to Two nav covers in Red and Green  - best I can do.
I will post some more pics after I have rescued this stage.....................Stay tuned.
OC.
Current builds
Completed works.
Evening all  -  right  straight in where I left off  those  wing nav lights  -  firstly I took it outside and sprayed a couple of coats  - primer then top coat,   it turned out ok  smooth without showing the nav lens details, then I brought it inside let it dry for a couple of hours, then after deciding it was dry enough  - I maked up both  wings  to form the nav lens's, then  a few coats of Green  and red  then the masks were removed.
Seems ok I think.
OC.
Current builds
Completed works.
3 minutes ago, Canute said:
Works for me, OC.
Thanks Ken,   it was hit or miss  when that transparency part broke  and  loosing the other part down into the carpet  (the carpet munster must  have had a day off as I found it)  - then it was a case of how I could fill in the missing piece  - thankfully  Vallejo  putty came to the rescue.
OC.
Current builds
Completed works.
A little funny tail  - the Yaw Vane  on the nose near the cockpit,  I keep knocking it off  from handling the  plane, its been off and back on about Four times now😞
OC.
Current builds
Completed works.
A bit more history on XZ-439  She was one of only Four SHAR's  that did not take part in the Falklands, Four jets were kept back at RNAS Yeovilton on training purposes - I understand  she was painted in the low viz scheme with markings  in case they changed thier mind and sent them,   she was the second SHAR built  and was latter converted into a F/A2  version and was even sold at a later year to be flown on the airshow scene in the US.
I am building her as I saw her at Farnborough Airshow 82  along with  190gal tanks  and on the outer pylons  Sidewinder acquisition round used for training purposes.
OC.
Current builds
Completed works.
1 hour ago, ragove said:
Did you darken the seams or am I just seeing natural lighting.  Looks great.
Yep, I am using a fine pencil  (the type with an extandable lead)  I just sharpen a point on it with my sanding stick, then just follow the panel lines - and wet my finger and rub over the lines and wipe with a cloth.
OC.
Current builds
Completed works.
Bit of a late progress report - I only managed and Hour on her to night  just enough time to put some flat White in the outrigger wheel wells  and start work converting the Aim 9 Lima  Sidewinders in to traing rounds  - this basically consisted off cutting the fins off and sanding a smooth round shape.
No pics as I foregot to get the phone out  - but I think you get the picture  - or not  or possibly do if  you can imagine it😵
OC.
Current builds
Completed works.
OC, the training rounds were actual AIM-9L seeker head sections, so they were dark colored, sort of a metallic gray green. The body was just gray with a blue band to mark it as training use.
Ken
Started: MS Bounty Longboat,
Thanks Ken, as I thought  basically a Sidewinder minus the fins.
OC.
Current builds
Completed works.
It's essentially a gray tube behind the seeker head section with clips to slide it onto a launch rail. With an electrical contact pad to talk to the aircraft. Very reliable missile when you get to fire one.
Ken
Evening all,   The decaling begins  starting with the stencils  about a Zillion of them   - I am starting at the front to avoid re handling,   I started with the canopy side decals  I then glued it down.
OC.
Current builds
Completed works.
3 minutes ago, Edwardkenway said:
Looking sweet OC !
Thank you Edward.
OC.
Current builds
Completed works.
21 minutes ago, Canute said:
Nice work, OC. Take your time; this will be a jewel in your display, mate.
Thank you kindly Ken,  I will have to give the decs  a think  after they are all on  - as I  took the masking off the canopy  the paint finish is quite flat  all over her and the decs are quite shiny, I have some Vallejo Acrylic  Flat  (Remember I was having issues with it on my  Waterloo  figures)  I could try  selective  painting with it just over the decals with it by brush, I dont really want to have to mask up the canopy and front  glazing area  if I can avoid it.
OC.
Current builds
Completed works.
Evening all  - a slight change of plan,  I am going to finish her as XZ-457  as I saw here at Farnborough Airshow at the same time, both  were 899sqn  but the difference is - I  have the decals for  457  but not for 439, I will also  dispaly here  (sidewinder equiped)  as she was  in the Falklands, its basically the same scheme  just different decals.
OC.
Current builds
Completed works.
1 hour ago, GrandpaPhil said:
Looking good, OC!
Thank you  kindly Phil.
OC.
Current builds
Completed works.
OC.
Microscale micro-flat is the answer. Of course the best way is to wait in the canopy masking removal until the decals are all on, but I've been where you are many times as well......
Sometimes we just have to see the art...
Finish looks great my friend, another piece of art...
Thank you kindly  my friend,    do you think Vallejo Matt Acrylic Varnish will work if I  brush it over, its not very flat  (as I found out on my Waterloo figures)  but that would be good as the SHAR's  finish was satin.
OC.
Current builds
Completed works.
What you think is best my friend, your looking to match the finish in as thin a coat as possible....
Only you can see what it needs to be..... I think you'll do it right....
You have the touch....
You say the nicest things  - hope my skills live up to it.
OC.
Current builds
Completed works.
Evening all,  decals are on, just need to wait a few days for them to fully settle down  - then I will  dirty the back end abit with pencil gently rubbed over, then I will brush paint my Vallejo Matt Acrylic Varnish, it shouldn't look bad as the lighter paint finish was applied by brush out in the Atlantic on HMS Hermes  by the crew.
This will (hopefully)  seal in the decals and blend them in so I can handle it for the other bits and pieces.
OC,
Current builds
Completed works.
very nice indeed, i loved watching the harriers, they put on a great display at  RNAS Yeovilton 2005007484_20107JulyAirDaystransport(221).thumb.JPG.3bee5b9117bb23487d28e18e406eed94.JPG during the summer of 2010
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks Kevin,   yep I have always loved Harrier displays  and thier low level speed  - very underated, was watching some vids last night of them 700mph  at almost ground level  - loverly jubbly.
OC.
Current builds
Completed works.
