10 hours ago, Ekis said:
I locate the village during the foundation of the bastides in the south of France during the whole of the 14th century.
My knowledge of French history in this period is pretty much limited to reading Maurice Druon’s works post the fall of the Templar’s but the more I read around this and the establishment of the various bastides make me hope that this Covid 19 situation clears up as would love to spend some time exploring.
One of the reasons I may go earlier is my understanding of Bastides were they were well planned and had straighter lines in terms of streets and walls.  None of this is my strong point so will hide behind this as an excuse for a more muddled construction.
I think that for a very small cloister in this small country village in southern Europe, the stone used had to be closer to white or pink sandstone (as in the region of Albi or Toulouse in France).
Granite has no place in the southern regions, marble was reserved for much more prestigious buildings!
Granite or marble are very difficult rocks to extract, even more so for stonemasons hired for this small religious construction of the Middle Ages.
That's just my opinion, but it seems to me more consistent with this period and the geography of this village. 😁
That makes sense may make the white clay pillars and then paint with a sandstone colour to blend in.  Thanks
36 minutes ago, Ekis said:
This is also exactly how I treated the larger doors with a pointed arch. Mounting the stones on a separate cardboard box on the facade allows the arch to be properly aligned and sanded quietly.
Your door with the 2 columns looks great ! 😉
Ah ha, the apprentice learns from the master, was wondering how you got them so well aligned now the secret is out
Yes, the age old tried and true method... Wonder first, figure it out next and remember forever...... No secrets, just discoveries to be made.... It's what makes this fun...
44 minutes ago, Ekis said:
Yes, but just the gate of the watchtower and the gate of the current dwelling ... The fortified gate of the village for example is made of arches glued on the whole structure... 😁
And sometimes, in some situations, just doing it the straight up way is best.... rather than the extended exploratory attempt/learning experience.....
It's very very interesting to see that even in scale, masonry is still the same ancient trade..... Learning the art of stacking blocks...... and the skills needed to do it correctly....
Well done guys....
Quote:
Great work  coming along here  - just cant beat these simulated brick builds   - by the way  is that Prussian Blue  I see in your paints  behind  - how do you find it regarding  its Flat Matt  finish?
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Hi,
no no it is the royal blue, it’s a Matt and I have found it covers quite well, been watching your build and really impressed with the quality of the painting.  You can always join in the fun once you have finished your current build but need to warn you this can get quite addictive.
...a glimpse of how good that's gonna look ;)    very nice.....
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Waitoa,
Are you starting to put in vegetation before finishing the roofs of your cloister?
Not putting them in place just building them from kits for a change of scenery..... My plan, which I am failing miserably on is to, finish the courtyard area and then start to brick the monks accommodation.  Most likely will tile the roof of the cloister while I do the main building and will at least layout the garden area.  Given the amount of dust I crest the actual plants and flowers will be at the end.
gonna look great when you get to that point  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Good Morning Waitoa
just been through your build, and i am learning by my mistakes just as you did, however a few of my mistakes could have been avoided by looking through the instructions, oh hum, a good example is the filing of each layer to keep a constant level, i am now doing that, but have more than one wall going on at the same time to allow more building,
my success with corners is hit and miss, the 90 degree ones are not to bad, its the ones where cutting different angles is required
loving your work
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Thanks Kevin, I try to lay a complete row of bricks and then sand it down so it is more level.  My corners are bit rough but have often carved bricks so the joins match where the levels are out.  This gives the brickwork more of a rustic look and using the bricks of the old kit means that with the differing colours highlights this.  The effect is kind of growing on me.
most recent update with inner courtyard finished and now onto the outer walls.
That is looking so good.
OC.
Current builds
Completed works.
Interested in how Kevin and Ekis do their walls.  I tend to zig zag my bricks laying a course of bricks for each length of wall.  This means that different parts of the walls are at different heights which hopefully shows what I mean.  This stops me from getting bored but also allows me to run a file across the top so it is relatively flat for the next layer.  Also it has allowed me to weave the various bricks in on the corners and has made it quite strong.  Accidentally dropped it and other than a few bricks it held together.
Ekis and Kevin - your thoughts?
